Hi
I am using BeagleBoard Rev C3 runnign Ubuntu. I need to rebuild the kernel in order to enable the i2c-2 channel. So I did the following changes to ‘arch/arm/mach-omap2/board-omap3beagle.c’ file.
a) in omap3_beagle_i2c_init(), added:
omap_register_i2c_bus(2, 400, NULL, 0);
b) in board_mux, added:
static struct omap_board_mux board_mux __initdata = {
OMAP3_MUX(I2C2_SCL, OMAP_MUX_MODE0),
OMAP3_MUX(I2C2_SDA, OMAP_MUX_MODE0),
{ .reg_offset = OMAP_MUX_TERMINATOR },
But while building the kernel by using build_kernel.sh form
https:``//github.com/RobertCNelson/stable-kernel
I am getting the following error.
git tree is clean…
error: invalid object 100644 7247178ac9ddf2fa53e7619865b423461545394d for ‘arch/arm/mach-omap2/board-omap3beagle.c’
error: Error building trees
How would I solve it? Please help me
Hi
'arch/arm/mach-omap2/board-omap3beagle.c' file.
GitHub - RobertCNelson/stable-kernel
Ah.. so it's been awhile (more then a year) since i've personally
booted any of those kernels... But you shouldn't have to patch that
file, i usually enabled that i2c port by default.. Note this is only
in reference to v3.7.x branches, as everything else is foggy and too
"old" for me..
git tree is clean...
Looks like you corrupted the ./KERNEL directory or the orignal git
clone.. First try deleting the ./KERNEL directory, if that doesn't fix
it you may have disconnected the git objects..
