Errors during install php5-json on bbb revB
I am getting this error when trying to run my php script:
PHP Fatal error: Call to undefined function json_encode()
It turned out that the root cause is php not supporting json extensions, I did some googling and found the fix, but the fix is not working:
sudo apt-get install php5-json
Reading package lists… Done
Building dependency tree
The following NEW packages will be installed:
php5-json
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 17.2 kB of archives.
After this operation, 105 kB of additional disk space will be used.
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/universe php5-json armhf 1.3.1+dfsg-2
404 Not Found [IP: 91.189.88.151 80]
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/universe/p/php-json/php5-json_1.3.1+dfsg-2_armhf.deb 404 Not Found [IP: 91.189.88.151 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I checked that url and the file is not there. I am completely stuck at this point.
does anyone know how to install php5-json?
Saucy went eol a few months ago… So long the repo has been removed…
Upgrade to trusty…
