I have just installed the new Debian 8.2 via the flasher image on a BeagleboneBlack Rev C with 4DCape. I have changed the uEnv.txt file to disable HDMI. I get the following errors on install: (Even when I dont change the uEnv.txt file from default)
[ 1113.740804] systemd[1]: Job console-setup.service/start deleted to break ordering cycle starting with basic.target/start
[ SKIP ] Ordering cycle found, skipping LSB: Set console font and keymap
[ 1114.681515] systemd[1]: systemd-modules-load.service: main process exited, code=exited, status=1/FAILURE
[FAILED] Failed to start Load Kernel Modules.
See ‘systemctl status systemd-modules-load.service’ for details.
[FAILED] Failed to start Store Sound Card State.
See ‘systemctl status alsa-store.service’ for details.
Then when I boot the new image I get the error:
Then I do apt-get update.
Then when I do apt-get upgrade I get the following errors:
WARNING: missing /lib/modules/4.2.2-armv7-x2
Ensure all necessary drivers are built into the linux image!
depmod: ERROR: could not open directory /lib/modules/4.2.2-armv7-x2: No such file or directory
depmod: FATAL: could not search modules: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_0Ayicd/lib/modules/4.2.2-armv7-x2/modules.order: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_0Ayicd/lib/modules/4.2.2-armv7-x2/modules.builtin: No such file or directory
Warning: Unit file of cloud9.socket changed on disk, ‘systemctl daemon-reload’ recommended.
c9-core-installer:Installing nak
npm WARN excluding symbolic link tests/filelist_fixtures/symlink-to-1.txt → 1.txt
npm WARN excluding symbolic link tests/filelist_fixtures/symlink-to-nowhere.txt → nowhere.txt
npm WARN excluding symbolic link tests/search_fixtures/symlink-to-file1.txt → file1.txt
Any ideas why this is occuring and how the problem can be fixed ?
Lachlan
