Using these instructions I did the following:
Used dd to clear the first 64 MB of a 16 GB SD card to zeros.
Used sfdisk to create a single bootable Linux partition from 64 MB to the end of the disk.
Used dd to place MLO at 128 kB and U-Boot at 384 kB.
I formatted the partition to EXT4 and installed the root filesystem.
I’m using Yocto/Poky (Pyro branch) which is building U-Boot 2017.01.
When I boot it seems to find the SPL/MLO and load/run U-Boot:
U-Boot SPL 2017.01 (Jun 28 2017 - 23:47:37)
Trying to boot from MMC1MMC partition switch failed
*** Warning - MMC partition switch failed, using default environment
U-Boot 2017.01 (Jun 28 2017 - 23:47:37 +0000)
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
** First descriptor is NOT a primary desc on 1:1 **
*** Warning - bad CRC, using default environment
not set. Validating first E-fuse MAC
Net: cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
When I naively boot I get the following:
=> boot
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** File not found boot.scr **
** Unrecognized filesystem type **
Scanning mmc 0:1…
** Invalid partition 2 **
** No partition table - mmc 1 **
SD/MMC found on device 1
Error: “bootcmd_nand0” not defined
starting USB…
USB0: Port not available.
cpsw Waiting for PHY auto negotiation to complete…
What is U-Boot trying to do here? Is it trying to locate the uEnv? The kernel? Is it trying to mount the partition and search for /boot?
I can tell that is searching for something but can only understand about half of these messages. What is a descriptor? What is a primary desc? Why are partitions referred to as 0 rather than 1-4? What does “switch to partitions #0” mean?
