/etc/machine-id is not unique!
I have some software that uses the unique /etc/machine-id as a key. But I just noticed tonight that the machine-id is exactly the same on all beaglebones!
If this has been fixed recently, let me know. The builds I’m using are from January 2017, though I don’t recall exactly when.
All of the devices I have seem to be using this ID:
$ cat /etc/machine-id
31ed5be0bb5b4026a4c72cfcfe792e44
I tried to run the command I found online, but…:
$ sudo systemd-machine-id-setup
Initializing machine ID from D-Bus machine ID.
Does that mean the D-Bus machine ID should be unique and somehow isn’t?
What is the correct way to generate a new machine-id and/or a D-Bus machine ID?
Stéphane
I think I figured it out. Robert, is this something that should be part of an image? Either deleting the files from the image so new ones are auto-generated, or ensuring unique IDs are created?
Here is how I generated unique ID on each of my beaglebone devices:
sudo rm -f /var/lib/dbus/machine-id
sudo rm -f /etc/machine-id
sudo dbus-uuidgen --ensure
Stéphane
