I am using Beagleboard xm.
I followed the instructions on this site: http://elinux.org/BeagleBoardUbuntu#Demo_Image
to install Maverik on the board.
The board boots up, but I am not able to configure my network (in
order to install the GUI)
I use:
sudo ifconfig -a and sudo dhclient usb1
by running ifconfig, i see lo, usb0 and usb1.
by using dhclient usb1, i get:
No DHCPOFFERS received.
No working leases in persistent database -sleeping.
Please help me!!
Now that's a first..
I'd almost want to blame your dhcp server... Any errors seen thru
dmesg? "dmesg | pastebinit"
dmesg | pastebinit gives:
IOError: [Errno socket error] [Errno -3] Temporary failure in name
resolution
Yeah i realized after i sent that message, it would probably be
impossible as pastebinit requires a network connection... I kinda
figured you'd had figured that out and just copied dmesg to another
computer and upload from there..
so do:
sudo ifconfig -a
sudo dhclient usb1 (let it fail)
dmesg > log.txt
copy log.txt from sd card to computer, upload to pastebin.com
[ 615.561126] smsc95xx 1-2.1:1.0: eth0: link down
[ 639.841918] smsc95xx 1-2.1:1.0: eth0: link up, 100Mbps,
full-duplex, lpa 0x45E1
[ 1162.285583] smsc95xx 1-2.1:1.0: eth0: link down
[ 1217.370941] smsc95xx 1-2.1:1.0: eth0: link up, 100Mbps,
This looks like a router problem.. Are you by chance on a campus the
limits internet connections via MAC address's?
I see nothing else in the log that would point to anything.. It works
here on my xM C..
