Hi all,
I am running 2.6.39-rc7 kernel on Beagleboard-XM rev A
board. Despite whatever configuration i give, the enthernet is not
working. I enabled inet,ip and in drivers->networkdevices-
smsc911x[5678] as suggestged in wiki. But i am unable to get the
ethernet .I am totally struck in it. Could you please help me guys?
Here is the console log..
** Unable to read "rootfs.ext2" from mmc 1:1 **
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-2.6.39-rc7+
Data Size: 3254708 Bytes = 3.1 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Linux version 2.6.39-rc7+ (abhishek@abhishek-desktop)
(gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #2 PREEMPT Fri Sep
23 10:55:21 IST 2011
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7),
cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing
instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Reserving 12582912 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3630 ES1.1 (l2cache iva sgx neon isp 192mhz_clk )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size:
0x10000
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pages: 119552
[ 0.000000] Kernel command line: console=ttyO2,115200n8 mpurate=800
mem=99M@0x80000000 mem=384M@0x88000000 camera=lbcm5m1 vram=12M
omapfb.mode=dvi:1280x720MR-16@60 omapdss.def_disp=dvi root=/dev/
mmcblk0p2 rootfstype=ext3 rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6,
262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072
bytes)
[ 0.000000] Memory: 99MB 372MB = 471MB total
[ 0.000000] Memory: 471260k/471260k available, 23332k reserved, 0K
highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xe0800000 - 0xf8000000 ( 376 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc0037000 ( 188 kB)
[ 0.000000] .text : 0xc0037000 - 0xc060b958 (5971 kB)
[ 0.000000] .data : 0xc060c000 - 0xc065c700 ( 322 kB)
[ 0.000000] Preemptable hierarchical RCU implementation.
[ 0.000000] RCU-based detection of stalled CPUs is disabled.
[ 0.000000] Verbose stalled-CPUs detection is disabled.
[ 0.000000] NR_IRQS:410
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96
interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] omap_hwmod: gpt12_fck: missing clockdomain for
gpt12_fck.
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns,
wraps every 131071999ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000213] Calibrating delay loop... 493.67 BogoMIPS (lpj=1929216)
[ 0.038818] pid_max: default: 32768 minimum: 301
[ 0.039062] Mount-cache hash table entries: 512
[ 0.039520] CPU: Testing write buffer coherency: ok
[ 0.040222] devtmpfs: initialized
[ 0.041442] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va
for l4_core
for l4_per
[ 0.041473] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va
for l4_wkup
[ 0.054992] omap_hwmod: i2c1: softreset failed (waited 10000 usec)
[ 0.067260] omap_hwmod: i2c2: softreset failed (waited 10000 usec)
[ 0.079498] omap_hwmod: i2c3: softreset failed (waited 10000 usec)
[ 0.080749] print_constraints: dummy:
[ 0.080963] NET: Registered protocol family 16
[ 0.081146] GPMC revision 5.0
[ 0.082214] OMAP GPIO hardware version 2.5
[ 0.082336] OMAP GPIO hardware version 2.5
[ 0.082489] OMAP GPIO hardware version 2.5
[ 0.082519] omap_device: omap_gpio.3: new worst case activate
latency 0: 30517
[ 0.082611] OMAP GPIO hardware version 2.5
[ 0.082733] OMAP GPIO hardware version 2.5
[ 0.082885] OMAP GPIO hardware version 2.5
[ 0.083984] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.084167] OMAP3 Beagle Rev: xM
[ 0.085235] omap_device: omap_uart.0: new worst case activate
latency 0: 30517
[ 0.097259] omap_device: omap_uart.1: new worst case deactivate
latency 0: 30517
[ 0.135772] Found NAND on CS0
[ 0.135803] Registering NAND on CS0
[ 0.135925] Unable to get DVI reset GPIO
[ 0.213012] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.251892] Switched to new clocking rate (Crystal/Core/MPU):
26.0/332/800 MHz
[ 0.252044] OMAP DMA hardware revision 5.0
[ 0.258392] bio: create slab <bio-0> at 0
[ 0.259277] SCSI subsystem initialized
[ 0.260437] usbcore: registered new interface driver usbfs
[ 0.260559] usbcore: registered new interface driver hub
[ 0.260711] usbcore: registered new device driver usb
[ 0.260955] omap_device: omap_i2c.1: new worst case activate
latency 0: 30517
[ 0.271148] omap_i2c omap_i2c.1: bus 1 rev4.0 at 2600 kHz
[ 0.285949] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 0.285980] twl4030: power (irq 373) chaining IRQs 376..383
[ 0.286376] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 0.287567] beagle_twl_gpio_setup: unable to configure DVI_LDO_EN
[ 0.297241] print_constraints: VUSB1V5: 1500 mV normal standby
[ 0.297576] print_constraints: VUSB1V8: 1800 mV normal standby
[ 0.297882] print_constraints: VUSB3V1: 3100 mV normal standby
[ 0.311309] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 0.323242] print_constraints: VMMC1: 1850 <--> 3150 mV at 3000 mV
normal standby
[ 0.323608] print_constraints: VDAC: 1800 mV normal standby
[ 0.323944] print_constraints: VDVI: 1800 mV normal standby
[ 0.324371] print_constraints: VSIM: 1800 <--> 3000 mV at 1800 mV
normal standby
[ 0.324768] print_constraints: VAUX3: 1800 mV normal standby
[ 0.325164] print_constraints: VAUX4: 1800 mV normal standby
[ 0.335662] omap_i2c omap_i2c.3: bus 3 rev4.0 at 100 kHz
[ 0.336242] Advanced Linux Sound Architecture Driver Version
1.0.24.
[ 0.336761] Switching to clocksource 32k_counter
[ 0.342254] Switched to NOHz mode on CPU #0
[ 0.346221] musb-hdrc: version 6.0, tusb-omap-dma, otg (peripheral
+host), debug=0
[ 0.346588] NET: Registered protocol family 2
[ 0.346771] IP route cache hash table entries: 4096 (order: 2,
16384 bytes)
[ 0.347137] TCP established hash table entries: 16384 (order: 5,
131072 bytes)
[ 0.347442] TCP bind hash table entries: 16384 (order: 4, 65536
bytes)
[ 0.347686] TCP: Hash tables configured (established 16384 bind
16384)
[ 0.347686] TCP reno registered
[ 0.347717] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.347717] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.348052] NET: Registered protocol family 1
[ 0.348419] RPC: Registered udp transport module.
[ 0.348449] RPC: Registered tcp transport module.
[ 0.348449] RPC: Registered tcp NFSv4.1 backchannel transport
module.
[ 0.349182] omap-iommu omap-iommu.0: isp registered
[ 0.350585] VFS: Disk quotas dquot_6.5.2
[ 0.350646] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 0.351226] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.351593] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red
Hat, Inc.
[ 0.351959] msgmni has been set to 920
[ 0.353363] Block layer SCSI generic (bsg) driver version 0.4
loaded (major 254)
[ 0.353393] io scheduler noop registered
[ 0.353393] io scheduler deadline registered
[ 0.353454] io scheduler cfq registered (default)
[ 0.415039] OMAP DSS rev 2.0
[ 0.579528] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.704284] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a
OMAP UART0
[ 0.735351] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a
OMAP UART1
[ 0.766601] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a
OMAP UART2
[ 1.487823] console [ttyO2] enabled
[ 1.516632] omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a
OMAP UART3
[ 1.553527] brd: module loaded
[ 1.559661] loop: module loaded
[ 1.564239] omap2-nand driver initializing
[ 1.568847] No NAND device found.
[ 1.572601] No NAND device found.
[ 1.576629] PPP generic driver version 2.4.2
[ 1.581359] NET: Registered protocol family 24
[ 1.586303] usbcore: registered new interface driver catc
[ 1.591979] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 1.598266] usbcore: registered new interface driver kaweth
[ 1.604125] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB
Ethernet driver
[ 1.612030] usbcore: registered new interface driver pegasus
[ 1.617950] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet
driver
[ 1.625244] usbcore: registered new interface driver rtl8150
[ 1.631225] usbcore: registered new interface driver asix
[ 1.636962] usbcore: registered new interface driver cdc_ether
[ 1.643127] usbcore: registered new interface driver cdc_eem
[ 1.649108] usbcore: registered new interface driver dm9601
[ 1.655029] usbcore: registered new interface driver smsc95xx
[ 1.661132] usbcore: registered new interface driver gl620a
[ 1.667022] usbcore: registered new interface driver net1080
[ 1.673034] usbcore: registered new interface driver plusb
[ 1.678833] usbcore: registered new interface driver rndis_host
[ 1.685089] usbcore: registered new interface driver cdc_subset
[ 1.691345] usbcore: registered new interface driver zaurus
[ 1.697265] usbcore: registered new interface driver MOSCHIP usb-
ethernet driver
[ 1.705047] cdc_ncm: 23-Apr-2011
[ 1.708496] usbcore: registered new interface driver cdc_ncm
[ 1.714843] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 3.735290] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 3.741516] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus number 1
[ 3.758819] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 3.774383] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 3.780487] usb usb1: New USB device found, idVendor=1d6b,
idProduct=0002
[ 3.787628] usb usb1: New USB device strings: Mfr=3, Product=2,
SerialNumber=1
[ 3.795196] usb usb1: Product: OMAP-EHCI Host Controller
[ 3.800781] usb usb1: Manufacturer: Linux 2.6.39-rc7+ ehci_hcd
[ 3.806915] usb usb1: SerialNumber: ehci-omap.0
[ 3.812225] hub 1-0:1.0: USB hub found
[ 3.816192] hub 1-0:1.0: 3 ports detected
[ 3.844696] Initializing USB Mass Storage driver...
[ 3.849914] usbcore: registered new interface driver usb-storage
[ 3.856231] USB Mass Storage support registered.
[ 3.861419] mousedev: PS/2 mouse device common for all mice
[ 3.867645] input: gpio-keys as /devices/platform/gpio-keys/input/
input0
[ 3.884521] omap_device: omap_i2c.1: new worst case deactivate
latency 0: 30517
[ 3.892425] input: twl4030_pwrbutton as /devices/platform/omap/
omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input1
[ 3.904052] i2c /dev entries driver
[ 3.908081] Linux media interface: v0.10
[ 3.912322] lirc_dev: IR Remote Control driver registered, major
250
[ 3.919219] IR NEC protocol handler initialized
[ 3.923980] IR RC5(x) protocol handler initialized
[ 3.928985] IR RC6 protocol handler initialized
[ 3.933746] IR JVC protocol handler initialized
[ 3.938659] IR Sony protocol handler initialized
[ 3.943481] IR RC5 (streamzap) protocol handler initialized
[ 3.949371] IR LIRC bridge handler initialized
[ 3.954040] Linux video capture interface: v2.00
[ 3.959075] vpfe_init
[ 3.962097] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 3.972961] usbcore: registered new interface driver usbhid
[ 3.978851] usbhid: USB HID core driver
[ 3.983337] usbcore: registered new interface driver snd-usb-audio
[ 3.990325] OMAP3 Beagle/Devkit8000 SoC init
[ 4.003387] asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
[ 4.012451] ALSA device list:
[ 4.015594] #0: omap3beagle
[ 4.018737] oprofile: hardware counters not available
[ 4.024017] oprofile: using timer interrupt.
[ 4.028686] TCP cubic registered
[ 4.032073] NET: Registered protocol family 17
[ 4.036804] NET: Registered protocol family 15
[ 4.041534] lib80211: common routines for IEEE802.11 drivers
[ 4.047454] Registering the dns_resolver key type
[ 4.052459] VFP support v0.3: implementor 41 architecture 3 part 30
variant c rev 3
[ 4.060607] ThumbEE CPU extension supported.
[ 4.066467] Power Management for TI OMAP3.
[ 4.071044] sr_init: No PMIC hook to init smartreflex
[ 4.076538] smartreflex smartreflex.0: omap_sr_probe: SmartReflex
driver initialized
[ 4.084838] smartreflex smartreflex.1: omap_sr_probe: SmartReflex
driver initialized
[ 4.102783] omap_i2c omap_i2c.2: bus 2 rev4.0 at 100 kHz
[ 4.109069] omap3isp omap3isp: Revision 15.0 found
[ 4.114166] omap-iommu omap-iommu.0: isp: version 1.1
[ 4.121337] _MT9D131_DRIVER:
[ 4.121337] In probe *************
[ 4.128021] _MT9D131_DRIVER:
[ 4.128021] registered HERE
[ 4.134399] In set power
[ 4.137725] _MT9D131_DRIVER:
[ 4.137725] set power HERE 1
[ 4.145721] _MT9D131_DRIVER:
[ 4.145721] power on HERE
[ 4.181762] _MT9D131_DRIVER:
[ 4.181762] s_ctrl HERE id = 9963797 vflip = 9963797 hflip =
9963796 zoom = 10094861 pan = 10094856
[ 4.194458] _MT9D131_DRIVER:
[ 4.194458] V4L2_CID_VFLIP HERE val = 0
[ 4.201873] _MT9D131_DRIVER:
[ 4.201873] s_ctrl HERE id = 9963796 vflip = 9963797 hflip =
[ 4.214569] _MT9D131_DRIVER:
[ 4.214569] V4L2_CID_VFLIP HERE val = 0
[ 4.221984] _MT9D131_DRIVER:
[ 4.221984] s_ctrl HERE id = 10094861 vflip = 9963797 hflip =
[ 4.234741] _MT9D131_DRIVER:
[ 4.234741] s_ctrl HERE id = 10094856 vflip = 9963797 hflip =
[ 4.248260] mt9d131 2-0048: Detected a MT9D131 chip ID 1519
[ 4.254302] In set power
[ 4.256774] _MT9D131_DRIVER:
[ 4.256774] set power HERE 0
[ 4.263092] _MT9D131_DRIVER:
[ 4.263092] power off HERE
[ 4.288696] clock: disabling unused clocks to save power
[ 4.295074] registered taskstats version 1
[ 4.300140] omapfb omapfb: no driver for display
[ 4.305023] omapfb omapfb: failed to setup omapfb
[ 4.310333] regulator_init_complete: VDVI: incomplete constraints,
leaving on
[ 4.317932] regulator_init_complete: VDAC: incomplete constraints,
leaving on
[ 4.325866] omap_vout omap_vout: probed for an unknown device
[ 4.332580] Waiting for root device /dev/mmcblk0p2...
[ 6.657196] mmc0: error -110 whilst initialising SD card
[ 6.947570] mmc0: host does not support reading read-only switch.
assuming write-enable.
[ 6.969757] mmc0: new SDHC card at address e624
[ 6.974945] mmcblk0: mmc0:e624 SU04G 3.69 GiB
[ 6.987335] mmcblk0: p1 p2
[ 7.076263] EXT3-fs: barriers not enabled
[ 7.604309] kjournald starting. Commit interval 5 seconds
[ 7.611389] EXT3-fs (mmcblk0p2): using internal journal
[ 7.616851] EXT3-fs (mmcblk0p2): recovery complete
[ 7.629425] EXT3-fs (mmcblk0p2): mounted filesystem with writeback
data mode
[ 7.636901] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 7.648651] devtmpfs: mounted
[ 7.651885] Freeing init memory: 188K
INIT: version 2.86 booting
Error opening /dev/fb0: No such file or directory
Please wait: booting...
Starting udev
[ 8.508148] udev: starting version 151
[ 8.512664] udevd (81): /proc/81/oom_adj is deprecated, please use /
proc/81/oom_score_adj instead.
Remounting root file system...
Caching udev devnodes
Populating dev cache
ALSA: Restoring mixer settings...
Configuring network interfaces... ifconfig: SIOCGIFFLAGS: No such
device
ifconfig: SIOCSIFADDR: No such device
route: SIOCADDRT: No such device
ifconfig: SIOCGIFFLAGS: No such device
usb0 No such device
done.
Starting portmap daemon: portmap.
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
hwclock: can't open '/dev/misc/rtc': No such file or directory
Tue Jan 11 10:14:00 GMT 2011
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting Hardware abstraction layer hald
[ 20.256378] _MT9D131_DRIVER:
[ 20.256378] open HERE
[ 20.295623] In set power
[ 20.306457] _MT9D131_DRIVER:
[ 20.306488] set power HERE 1
[ 20.312774] _MT9D131_DRIVER:
[ 20.312805] power on HERE
[ 20.377319] _MT9D131_DRIVER:
[ 20.377319] s_ctrl HERE id = 9963797 vflip = 9963797 hflip =
[ 20.422943] _MT9D131_DRIVER:
[ 20.422943] V4L2_CID_VFLIP HERE val = 0
[ 20.430358] _MT9D131_DRIVER:
[ 20.430358] s_ctrl HERE id = 9963796 vflip = 9963797 hflip =
[ 20.460998] _MT9D131_DRIVER:
[ 20.460998] V4L2_CID_VFLIP HERE val = 0
[ 20.484436] _MT9D131_DRIVER:
[ 20.484466] s_ctrl HERE id = 10094861 vflip = 9963797 hflip =
[ 20.517761] _MT9D131_DRIVER:
[ 20.517761] s_ctrl HERE id = 10094856 vflip = 9963797 hflip =
[ 20.543914] _MT9D131_DRIVER:
[ 20.543945] HERE
[ 20.551025] In set power
[ 20.561706] _MT9D131_DRIVER:
[ 20.561706] set power HERE 0
[ 20.592803] _MT9D131_DRIVER:
[ 20.592834] power off HERE
Starting Dropbear SSH server: dropbear.
Starting advanced power management daemon: No APM support in kernel
(failed.)
Starting Vixie-cron.
Starting Samba: smbd nmbd.
Starting syslogd/klogd: done
Starting internet superserver: xinetd.
* Starting Avahi mDNS/DNS-SD Daemon: avahi-
daemon [ ok ]
Starting Network connection manager daemon: NetworkManager.
Loading kernel modules for gstreamer-ti...
Running /usr/share/ti/gst/omap3530/loadmodules.shFATAL: Module cmemk
not found.
FATAL: Module dsplinkk not found.
FATAL: Module lpm_omap3530 not found.
FATAL: Module sdmak not found.
done
open /dev/fb0: No such file or directory
expr: syntax error
Linux Frame Buffer Device Configuration Version 2.1 (23/06/1999)
(C) Copyright 1995-1999 by Geert Uytterhoeven
Usage: fbset [options] [mode]
Valid options:
General options:
-h, --help : display this usage information
--test : don't change, just test whether the mode is
valid
-s, --show : display video mode settings
-i, --info : display all frame buffer information
-v, --verbose : verbose mode
-V, --version : print version information
-x, --xfree86 : XFree86 compatibility mode
-a, --all : change all virtual consoles on this device
Frame buffer special device nodes:
-fb <device> : processed frame buffer device
(default is /dev/fb0)
Video mode database:
-db <file> : video mode database file
(default is /etc/fb.modes)
Display geometry:
-xres <value> : horizontal resolution (in pixels)
-yres <value> : vertical resolution (in pixels)
-vxres <value> : virtual horizontal resolution (in pixels)
-vyres <value> : virtual vertical resolution (in pixels)
-depth <value> : display depth (in bits per pixel)
-nonstd <value> : select nonstandard video mode
-g, --geometry ... : set all geometry parameters at once
-match : set virtual vertical resolution by virtual
resolution
Display timings:
-pixclock <value> : pixel clock (in picoseconds)
-left <value> : left margin (in pixels)
-right <value> : right margin (in pixels)
-upper <value> : upper margin (in pixel lines)
-lower <value> : lower margin (in pixel lines)
-hslen <value> : horizontal sync length (in pixels)
-vslen <value> : vertical sync length (in pixel lines)
-t, --timings ... : set all timing parameters at once
Display flags:
-accel <value> : hardware text acceleration enable (false or
true)
-hsync <value> : horizontal sync polarity (low or high)
-vsync <value> : vertical sync polarity (low or high)
-csync <value> : composite sync polarity (low or high)
-gsync <value> : synch on green (false or true)
-extsync <value> : external sync enable (false or true)
-bcast <value> : broadcast enable (false or true)
-laced <value> : interlace enable (false or true)
-double <value> : doublescan enable (false or true)
-rgba <r,g,b,a> : recommended length of color entries
-grayscale <value> : grayscale enable (false or true)
Display positioning:
-move <direction> : move the visible part (left, right, up or
down)
-step <value> : step increment (in pixels or pixel lines)
(default is 8 horizontal, 2 vertical)
Starting PVR
Usage: insmod filename [args]
FATAL: Module omaplfb not found.
FATAL: Module bufferclass_ti not found.
BusyBox v1.13.2 (2011-01-04 12:34:55 CET) multi-call binary
Usage: mknod [OPTIONS] NAME TYPE MAJOR MINOR
Create a special file (block, character, or pipe)
Options:
-m Create the special file using the specified mode
(default a=rw)
TYPEs include:
b: Make a block device
c or u: Make a character device
p: Make a named pipe (MAJOR and MINOR are ignored)
chmod: /dev/pvrsrvkm: No such file or directory
Starting GNOME Display Manager gdm
> > __ | ---'| '--.| .-'| | |
The Angstrom Distribution beagleboard ttyO2
Angstrom 2010.7-test-20110104 beagleboard ttyO2
