Hi Chris et al.,
Thanks for following up. I was able to begin the evaluation. There was a driver issue where windows (7) would not load the CDC serial driver. I could not follow the start procedure then as the pc could not communicate with the Beaglebone. I tried it on my Macbook Pro and was able to get it to work. I did perform the update and wrote the update FW to the eMMC. This resolved many of the issues. The serial driver still does not load properly on windows (7) but I was able to run the getting started steps. I followed the advice and tried on a windows 10 pc. While it did work there is still a message that drivers were not loaded (CDC ECM). The elements on the (Beaglebone 101) page do work. My next step was to try and attach the BBONE-GATEWAY-CAPE. Following the steps in the Readme I have not been able to get that up and running. First problem is the root password. This is not accepted - says access denied. I was able to get in by SSH/PuTTY and used the username Debian and password temppwd. I tried setting a root password with sudo but after a restart root still won’t work - not sure that is a problem since I can proceed with the Debian username. It would be nice if the documentation reflected the actual experience.
What exactly needs to be done to enable the wireless cape. The readme instructions are either not correct or not enough explanation for me to make the changes needed to enable it. Perhaps I am not as versed in what needs to be done and it is an insufficiency on my part.
The uEnv.txt from the /boot and the latest firmware is:
