Maybe this will help:
Here’s what the serial debug output looks like when it doesn’t work.
I need some help interpreting it.
U-Boot SPL 2013.04 (Sep 25 2013 - 00:49:30)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2013.04 (Sep 25 2013 - 00:49:30)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
mmc0 is current device
SD/MMC found on device 0
reading uEnv.txt
236 bytes read in 7 ms (32.2 KiB/s)
Running uenvcmd …
reading uImage
11748096 bytes read in 1322 ms (8.5 MiB/s)
reading /am335x-boneblack.dtb
24884 bytes read in 12 ms (2 MiB/s)
Booting kernel from Legacy Image at 80200000 …
Image Name: Linux-3.8.13
Data Size: 11748032 Bytes = 11.2 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Flattened Device Tree blob at 81ff0000
Booting using the fdt blob at 0x81ff0000
Loading Kernel Image … OK
OK
Using Device Tree in place at 81ff0000, end 81ff9133
Starting kernel …
[ 1.368993] omap2_mbox_probe: platform not supported
[ 1.380022] tps65217-bl tps65217-bl: no platform data provided
[ 1.456012] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 1.493120] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 1.530230] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 1.567340] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 1.594051] omap_hsmmc mmc.5: of_parse_phandle_with_args of ‘reset’ failed
[ 1.659528] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[ 1.671234] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 1.678546] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
Starting logging: OK
Initializing random number generator… done.
Starting network…
/etc/init.d/S93-am335x-pm-firmware-load: line 4: can’t create /sys/devices/ocp.2/44d00000.wkup_m3/firmware/am335x-pm-firmware.bin/loading: nonexistent directory
/etc/init.d/S93-am335x-pm-firmware-load: line 5: can’t create /sys/devices/ocp.2/44d00000.wkup_m3/firmware/am335x-pm-firmware.bin/data: nonexistent directory
/etc/init.d/S93-am335x-pm-firmware-load: line 6: can’t create /sys/devices/ocp.2/44d00000.wkup_m3/firmware/am335x-pm-firmware.bin/loading: nonexistent directory
Running /dev/mmcblk0p1/autorun.sh…
dd: can’t open ‘/dev/mmcblk1’: No such file or directory
Welcome to Buildroot
beaglebone login:
beaglebone login:
