I have a PWM Driver and I was testing it for fading a LED.
#!/usr/bin/python3
from time import sleep
import signal
import sys
from pwm_driver import Pwm
LED = Pwm(path="/sys/class/pwm/pwmchip0/pwm0/", enabled=False, period=100000, duty_cycle=85000)
Duty = 0
low = 0.8 # Smallest angle (in ms)
hi = 2.4 # Largest angle (in ms)
pos = 1.5 # Current position, about middle ms)
step = 0.4 # Step size to next position
try:
LED.enabled=True
while True:
pos += step # Take a step
if(pos > hi or pos < low):
step *= -1
Duty = LED.duty_cycle
Duty = str(pos)
print('pos = ' + str(pos) + ' duty_cycle = ' + Duty)
(LED.duty_cycle)
sleep(0.2)
except KeyboardInterrupt:
LED.enabled=False
pass
# Trying to fade a LED
# This is from your (@zmatt) PWM driver written a while back and some code from docs.beagleboard.org
The driver allows for setting (path=’/sys/class/pwm/pwmchip0/pwm0/”, enabled=False, period=100000, duty_cycle=85000) and I was using the above code to handle this effort.
Does anyone see an error or how the above code from the driver may or may not work as intended?
That is where I got the code for the back and forth motion…
Why do you only want to set LED.enabled = False, when the user presses Ctrl+C ? Surely that should be in a finally: so it’s put back after any Exception at all, no matter what type it is. The pass is pointless too.
try:
LED.enabled=False
pass
Does activating the PWM driver really only need LED.enabled = True, not some method call?
What’s the point in reassigning Duty, and the duplicating str(pos)? I don’t really understand the point of pos at all, other than the code’s best guess at what LED is doing. Isn’t there anything available in the pwm_driver API to introspect LED to get definitive information from?
If the sleep was explcitly related to step, that would at least make more sense as a time tracker.
No…LED is made by me to call it later. Pwm is the class.
There is no point in reassigning Duty. I just figured it would make it easier. True and False for .enabled is how the code works that is being called.
while True:
step *= -1
duty_cycle = str(round(pos*1000000)) # Convert ms to ns
# print('pos = ' + str(pos) + ' duty_cycle = ' + duty_cycle)
f.seek(0)
f.write(duty_cycle)
time.sleep(ms/1000)
That is some original code from the docs. pages: Motors — BeagleBoard Documentation
So, I could in fact add the sleep(ms/1000) code back to the source but I figured I could get away without it.
Also. I found this lib for PWM along with other peripheral accessing. See here: GitHub - linux4sam/mpio: Microchip Peripheral I/O Python Package · GitHub
Right now, I may be able to get it to work but came across some issues after changing the library up some.
