I'm trying to write a recipe for a project that's still in
development, and when I start a fresh setup-tools run, it fails saying :
--------8<----------------8<----------------8<---------------8<--------
ERROR: Unable to parse /home/angstrom/setup-scripts/sources/meta-hackabledevices/recipes-hackabledevices/myl33tproject/myl33tproject_v0.bb
Traceback (most recent call last):
File "<string>", line 10, in <module>
File "__anon_80__home_angstrom_setup_scripts_sources_meta_openembedded_meta_oe_classes_gitver_bbclass", line 2, in __anon_80__home_angstrom_setup_scripts_sources_meta_openembedded_meta_oe_classes_gitver_bbclass(d=<bb.data_smart.DataSmart object at 0x77dab50>)
File "gitver.bbclass", line 8, in mark_recipe_dependencies(path='/home/angstrom/setup-scripts/build/tmp-angstrom_v2012_05-eglibc/work/armv7a-angstrom-linux-gnueabi/myl33tproject-r0/myrepository', d=<bb.data_smart.DataSmart object at 0x77dab50>)
File "/home/angstrom/setup-scripts/sources/bitbake/lib/bb/parse/__init__.py", line 77, in mark_dependency(d=<bb.data_smart.DataSmart object at 0x77dab50>, f='/home/angstrom/setup-scripts/build/tmp-angstrom_v2012_05-eglibc/work/armv7a-angstrom-linux-gnueabi/myl33tproject-r0/myrepository/.git/HEAD'):
deps = d.getVar('__depends') or set()
> deps.update([(f, cached_mtime(f))])
d.setVar('__depends', deps)
File "/home/angstrom/setup-scripts/sources/bitbake/lib/bb/parse/__init__.py", line 58, in cached_mtime(f='/home/angstrom/setup-scripts/build/tmp-angstrom_v2012_05-eglibc/work/armv7a-angstrom-linux-gnueabi/myl33tproject-r0/myrepository/.git/HEAD'):
if f not in __mtime_cache:
> __mtime_cache[f] = os.stat(f)[stat.ST_MTIME]
return __mtime_cache[f]
OSError: [Errno 2] No such file or directory: '/home/angstrom/setup-scripts/build/tmp-angstrom_v2012_05-eglibc/work/armv7a-angstrom-linux-gnueabi/myl33tproject-r0/myrepository/.git/HEAD'
-------->8---------------->8---------------->8--------------->8--------
I then have to manually clone my git repository where it is looking
for it, and rerun bitbake, which works it out perfectly:
cd /home/angstrom/setup-scripts/build/tmp-angstrom_v2012_05-eglibc/work/armv7a-angstrom-linux-gnueabi/myl33tproject-r0/
git clone guyzmo@myrepositoryserver.com:myrepository.git myrepository
cd -
bitbake myl33tproject_v0.bb
So there's definitely something wrong with my recipe, but reading 50
times each bit of documentation I could find on the web, I can't find
what's wrong. I did not dug into the sources of bitbake or gitver,
though.
DESCRIPTION = "My l33t project"
HOMEPAGE = "http://hackable-devices.org"
LICENSE = "GPLv3"
SECTION = "console/utils"
DEPENDS = "curl libjson libgcrypt python-nativesdk"
RDEPENDS = "python-nativesdk-core python-nativesdk-lang"
PROVIDES = "myl33tproject"
SRC_URI = "git://myrepositoryserver.com/myrepository.git;branch=master;protocol=ssh;user=guyzmo"
SRCREV = "HEAD"
LIC_FILES_CHKSUM = "file://LICENSE;md5=d41d8cd98f00b204e9800998ecf8427e"
inherit systemd gitver
PR = "r0"
# For tarball packages (as opposed to git / svn which include the commit in the URI)
SRC_URI[md5sum] = ""
SRC_URI[sha256sum] = ""
S = "${WORKDIR}/"
do_configure() {
do_compile () {
oe_runmake all
do_install () {
oe_runmake install
SYSTEMD_PACKAGES = "${PN}-systemd"
SYSTEMD_SERVICE = "${PN}.service"
cheers,
