I’m having the exact same issue. With the BeagleBone Blue running Buster IoT Image 2020-04-06.
This seems to ONLY happen once you go to the browser and run the cloud9 IDE. If you SSH into the board this doesn’t happen.
Very annoying error - is this a hardware issue or software issue?
Here’s the output that contains the errors from journalctl:
Jun 07 07:47:34 beaglebone kernel: wl1271_sdio mmc2:0001:2: sdio read failed (-84)
Jun 07 07:47:34 beaglebone kernel: ------------[ cut here ]------------
Jun 07 07:47:34 beaglebone kernel: WARNING: CPU: 0 PID: 1322 at drivers/net/wireless/ti/wlcore/main.c:808 wl12xx_queue_recovery_work+0x64/0x68 [wlcore]
Jun 07 07:47:34 beaglebone kernel: Modules linked in: xt_state xt_conntrack nft_counter nft_chain_nat_ipv4 ipt_MASQUERADE nft_compat aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 rfco
Jun 07 07:47:34 beaglebone kernel: CPU: 0 PID: 1322 Comm: irq/85-wl18xx Tainted: G W 4.19.94-ti-r42 #1buster
Jun 07 07:47:34 beaglebone kernel: Hardware name: Generic AM33XX (Flattened Device Tree)
Jun 07 07:47:34 beaglebone kernel: [] (unwind_backtrace) from [] (show_stack+0x20/0x24)
Jun 07 07:47:34 beaglebone kernel: [] (show_stack) from [] (dump_stack+0x8c/0xa0)
Jun 07 07:47:34 beaglebone kernel: [] (dump_stack) from [] (__warn.part.3+0xcc/0xe8)
Jun 07 07:47:34 beaglebone kernel: [] (__warn.part.3) from [] (warn_slowpath_null+0x54/0x5c)
Jun 07 07:47:34 beaglebone kernel: [] (warn_slowpath_null) from [] (wl12xx_queue_recovery_work+0x64/0x68 [wlcore])
Jun 07 07:47:34 beaglebone kernel: [] (wl12xx_queue_recovery_work [wlcore]) from [] (wlcore_irq+0x118/0x188 [wlcore])
Jun 07 07:47:34 beaglebone kernel: [] (wlcore_irq [wlcore]) from [] (irq_thread_fn+0x2c/0x88)
Jun 07 07:47:34 beaglebone kernel: [] (irq_thread_fn) from [] (irq_thread+0x164/0x234)
Jun 07 07:47:34 beaglebone kernel: [] (irq_thread) from [] (kthread+0x16c/0x174)
Jun 07 07:47:34 beaglebone kernel: [] (kthread) from [] (ret_from_fork+0x14/0x2c)
Jun 07 07:47:34 beaglebone kernel: Exception stack(0xdb393fb0 to 0xdb393ff8)
Jun 07 07:47:34 beaglebone kernel: 3fa0: 00000000 00000000 00000000 00000000
Jun 07 07:47:34 beaglebone kernel: 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Jun 07 07:47:34 beaglebone kernel: 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
Jun 07 07:47:34 beaglebone kernel: —[ end trace 7cc048638202656d ]—
Jun 07 07:47:34 beaglebone kernel: wlcore: Hardware recovery in progress. FW ver: Rev 8.9.0.0.79
Jun 07 07:47:34 beaglebone kernel: wlcore: down
Jun 07 07:47:34 beaglebone kernel: ieee80211 phy0: Hardware restart was requested
Jun 07 07:47:34 beaglebone kernel: mmc1: tried to HW reset card, got error -110
Jun 07 07:47:34 beaglebone kernel: mmcblk1: recovery failed!
Jun 07 07:47:34 beaglebone kernel: print_req_error: I/O error, dev mmcblk1, sector 3221504
Jun 07 07:47:34 beaglebone kernel: omap_hsmmc 481d8000.mmc: error -110 requesting status
Jun 07 07:47:34 beaglebone kernel: print_req_error: I/O error, dev mmcblk1, sector 3221760
Jun 07 07:47:34 beaglebone kernel: print_req_error: I/O error, dev mmcblk1, sector 3221544
Jun 07 07:47:34 beaglebone cloud9ide[1435]: Error: EIO: i/o error, read
Jun 07 07:47:35 beaglebone kernel: wlcore: PHY firmware version: Rev 8.2.0.0.242
Jun 07 07:47:35 beaglebone kernel: wlcore: firmware booted (Rev 8.9.0.0.79)
Jun 07 07:47:35 beaglebone kernel: wlcore: Association completed.
Jun 07 07:47:35 beaglebone kernel: ------------[ cut here ]------------
Jun 07 07:47:35 beaglebone kernel: WARNING: CPU: 0 PID: 1494 at drivers/net/wireless/ti/wlcore/sdio.c:145 wl12xx_sdio_raw_write+0x148/0x1b4 [wlcore_sdio]
Jun 07 07:47:35 beaglebone kernel: Modules linked in: xt_state xt_conntrack nft_counter nft_chain_nat_ipv4 ipt_MASQUERADE nft_compat aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 rfco
Jun 07 07:47:35 beaglebone kernel: CPU: 0 PID: 1494 Comm: kworker/u2:0 Tainted: G W 4.19.94-ti-r42 #1buster
Jun 07 07:47:35 beaglebone kernel: Hardware name: Generic AM33XX (Flattened Device Tree)
Jun 07 07:47:35 beaglebone kernel: Workqueue: phy0 wl1271_tx_work [wlcore]
Jun 07 07:47:35 beaglebone kernel: [] (unwind_backtrace) from [] (show_stack+0x20/0x24)
Jun 07 07:47:35 beaglebone kernel: [] (show_stack) from [] (dump_stack+0x8c/0xa0)
Jun 07 07:47:35 beaglebone kernel: [] (dump_stack) from [] (__warn.part.3+0xcc/0xe8)
Jun 07 07:47:35 beaglebone kernel: [] (__warn.part.3) from [] (warn_slowpath_null+0x54/0x5c)
Jun 07 07:47:35 beaglebone kernel: [] (warn_slowpath_null) from [] (wl12xx_sdio_raw_write+0x148/0x1b4 [wlcore_sdio])
Jun 07 07:47:35 beaglebone kernel: [] (wl12xx_sdio_raw_write [wlcore_sdio]) from [] (wlcore_tx_work_locked+0x750/0xf30 [wlcore])
Jun 07 07:47:35 beaglebone kernel: [] (wlcore_tx_work_locked [wlcore]) from [] (wl1271_tx_work+0x44/0xc8 [wlcore])
Jun 07 07:47:35 beaglebone kernel: [] (wl1271_tx_work [wlcore]) from [] (process_one_work+0x1b4/0x504)
Jun 07 07:47:35 beaglebone kernel: [] (process_one_work) from [] (worker_thread+0x60/0x508)
Jun 07 07:47:35 beaglebone kernel: [] (worker_thread) from [] (kthread+0x16c/0x174)
Jun 07 07:47:35 beaglebone kernel: [] (kthread) from [] (ret_from_fork+0x14/0x2c)
Jun 07 07:47:35 beaglebone kernel: Exception stack(0xd5e73fb0 to 0xd5e73ff8)
Jun 07 07:47:35 beaglebone kernel: 3fa0: 00000000 00000000 00000000 00000000
Jun 07 07:47:35 beaglebone kernel: 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Jun 07 07:47:35 beaglebone kernel: 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
Jun 07 07:47:35 beaglebone kernel: —[ end trace 7cc048638202656e ]—
Jun 07 07:47:35 beaglebone kernel: wl1271_sdio mmc2:0001:2: sdio write failed (-84)
Jun 07 07:47:35 beaglebone kernel: WARNING: CPU: 0 PID: 1494 at drivers/net/wireless/ti/wlcore/main.c:808 wl12xx_queue_recovery_work+0x64/0x68 [wlcore]
Jun 07 07:47:35 beaglebone kernel: [] (warn_slowpath_null) from [] (wl12xx_queue_recovery_work+0x64/0x68 [wlcore])
Jun 07 07:47:35 beaglebone kernel: [] (wl12xx_queue_recovery_work [wlcore]) from [] (wl1271_tx_work+0xc4/0xc8 [wlcore])
Jun 07 07:47:35 beaglebone kernel: —[ end trace 7cc048638202656f ]—
Jun 07 07:47:35 beaglebone kernel: wlcore: Hardware recovery in progress. FW ver: Rev 8.9.0.0.79
Jun 07 07:47:35 beaglebone kernel: wlcore: down
Jun 07 07:47:35 beaglebone kernel: ieee80211 phy0: Hardware restart was requested
Jun 07 07:47:35 beaglebone kernel: omap_hsmmc 481d8000.mmc: error -110 requesting status
Jun 07 07:47:37 beaglebone wpa_supplicant[593]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-46 noise=9999 txrate=52000
Jun 07 07:47:39 beaglebone kernel: omap_hsmmc 481d8000.mmc: error -110 requesting status
Jun 07 07:47:39 beaglebone kernel: mmcblk1: recovery failed!
Jun 07 07:47:39 beaglebone kernel: print_req_error: I/O error, dev mmcblk1, sector 3420440
Jun 07 07:47:39 beaglebone kernel: Aborting journal on device mmcblk1p1-8.
Jun 07 07:47:39 beaglebone rsyslogd[591]: file ‘7’ write error: Read-only file system [v8.1901.0 try https://www.rsyslog.com/e/2027 ]
Jun 07 07:47:39 beaglebone kernel: print_req_error: I/O error, dev mmcblk1, sector 3416064
Jun 07 07:47:39 beaglebone kernel: Buffer I/O error on dev mmcblk1p1, logical block 425984, lost sync page write
Jun 07 07:47:39 beaglebone kernel: print_req_error: I/O error, dev mmcblk1, sector 8192
Jun 07 07:47:39 beaglebone kernel: Buffer I/O error on dev mmcblk1p1, logical block 0, lost sync page write
Jun 07 07:47:39 beaglebone kernel: JBD2: Error -5 detected when updating journal superblock for mmcblk1p1-8.
Jun 07 07:47:39 beaglebone kernel: EXT4-fs (mmcblk1p1): I/O error while writing superblock
Jun 07 07:47:39 beaglebone kernel: EXT4-fs error (device mmcblk1p1): ext4_journal_check_start:61: Detected aborted journal
Jun 07 07:47:39 beaglebone rsyslogd[591]: action ‘action-1-builtin:omfile’ (module ‘builtin:omfile’) message lost, could not be processed. Check for additional error messages before this one
Jun 07 07:47:39 beaglebone rsyslogd[591]: file ‘9’ write error: Read-only file system [v8.1901.0 try https://www.rsyslog.com/e/2027 ]
Jun 07 07:47:39 beaglebone rsyslogd[591]: action ‘action-3-builtin:omfile’ (module ‘builtin:omfile’) message lost, could not be processed. Check for additional error messages before this one
Jun 07 07:47:39 beaglebone kernel: EXT4-fs (mmcblk1p1): Remounting filesystem read-only
Jun 07 07:47:40 beaglebone kernel: omap_hsmmc 481d8000.mmc: error -110 requesting status
Jun 07 07:47:40 beaglebone kernel: mmcblk1: recovery failed!
Jun 07 07:47:40 beaglebone kernel: print_req_error: I/O error, dev mmcblk1, sector 8192
Jun 07 07:47:40 beaglebone kernel: Buffer I/O error on dev mmcblk1p1, logical block 0, lost sync page write
Jun 07 07:47:40 beaglebone kernel: EXT4-fs (mmcblk1p1): I/O error while writing superblock
Jun 07 07:47:40 beaglebone rsyslogd[591]: file ‘7’ write error: Read-only file system [v8.1901.0 try https://www.rsyslog.com/e/2027 ]
Jun 07 07:47:40 beaglebone rsyslogd[591]: action ‘action-1-builtin:omfile’ (module ‘builtin:omfile’) message lost, could not be processed. Check for additional error messages before this one
Jun 07 07:47:40 beaglebone rsyslogd[591]: file ‘8’ write error: Read-only file system [v8.1901.0 try https://www.rsyslog.com/e/2027 ]
Jun 07 07:47:40 beaglebone rsyslogd[591]: action ‘action-2-builtin:omfile’ (module ‘builtin:omfile’) message lost, could not be processed. Check for additional error messages before this one
Jun 07 07:47:40 beaglebone rsyslogd[591]: file ‘9’ write error: Read-only file system [v8.1901.0 try https://www.rsyslog.com/e/2027 ]
Jun 07 07:47:40 beaglebone rsyslogd[591]: action ‘action-3-builtin:omfile’ (module ‘builtin:omfile’) message lost, could not be processed. Check for additional error messages before this one
Jun 07 07:47:40 beaglebone rsyslogd[591]: file ‘11’ write error: Read-only file system [v8.1901.0 try https://www.rsyslog.com/e/2027 ]
Jun 07 07:47:40 beaglebone rsyslogd[591]: action ‘action-11-builtin:omfile’ (module ‘builtin:omfile’) message lost, could not be processed. Check for additional error messages before this on
Jun 07 07:49:56 beaglebone kernel: ------------[ cut here ]------------
Jun 07 07:49:56 beaglebone kernel: WARNING: CPU: 0 PID: 1561 at drivers/net/wireless/ti/wlcore/sdio.c:145 wl12xx_sdio_raw_write+0x148/0x1b4 [wlcore_sdio]
Jun 07 07:49:56 beaglebone kernel: Modules linked in: xt_state xt_conntrack nft_counter nft_chain_nat_ipv4 ipt_MASQUERADE nft_compat aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 rfco
Jun 07 07:49:56 beaglebone kernel: CPU: 0 PID: 1561 Comm: kworker/u2:3 Tainted: G W 4.19.94-ti-r42 #1buster
Jun 07 07:49:56 beaglebone kernel: Hardware name: Generic AM33XX (Flattened Device Tree)
Jun 07 07:49:56 beaglebone kernel: Workqueue: phy0 wl1271_tx_work [wlcore]
Jun 07 07:49:56 beaglebone kernel: [] (unwind_backtrace) from [] (show_stack+0x20/0x24)
Jun 07 07:49:56 beaglebone kernel: [] (show_stack) from [] (dump_stack+0x8c/0xa0)
Jun 07 07:49:56 beaglebone kernel: [] (dump_stack) from [] (__warn.part.3+0xcc/0xe8)
Jun 07 07:49:56 beaglebone kernel: [] (__warn.part.3) from [] (warn_slowpath_null+0x54/0x5c)
Jun 07 07:49:56 beaglebone kernel: [] (warn_slowpath_null) from [] (wl12xx_sdio_raw_write+0x148/0x1b4 [wlcore_sdio])
Jun 07 07:49:56 beaglebone kernel: [] (wl12xx_sdio_raw_write [wlcore_sdio]) from [] (wlcore_tx_work_locked+0x750/0xf30 [wlcore])
Jun 07 07:49:56 beaglebone kernel: [] (wlcore_tx_work_locked [wlcore]) from [] (wl1271_tx_work+0x44/0xc8 [wlcore])
Jun 07 07:49:56 beaglebone kernel: [] (wl1271_tx_work [wlcore]) from [] (process_one_work+0x1b4/0x504)
Jun 07 07:49:56 beaglebone kernel: [] (process_one_work) from [] (worker_thread+0x60/0x508)
Jun 07 07:49:56 beaglebone kernel: [] (worker_thread) from [] (kthread+0x16c/0x174)
Jun 07 07:49:56 beaglebone kernel: [] (kthread) from [] (ret_from_fork+0x14/0x2c)
Jun 07 07:49:56 beaglebone kernel: Exception stack(0xd5ea1fb0 to 0xd5ea1ff8)
Jun 07 07:49:56 beaglebone kernel: 1fa0: 00000000 00000000 00000000 00000000
Jun 07 07:49:56 beaglebone kernel: 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Jun 07 07:49:56 beaglebone kernel: 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000
Jun 07 07:49:56 beaglebone kernel: —[ end trace 7cc0486382026570 ]—
Jun 07 07:49:56 beaglebone kernel: wl1271_sdio mmc2:0001:2: sdio write failed (-84)
Jun 07 07:49:56 beaglebone kernel: WARNING: CPU: 0 PID: 1561 at drivers/net/wireless/ti/wlcore/main.c:808 wl12xx_queue_recovery_work+0x64/0x68 [wlcore]
Jun 07 07:49:56 beaglebone kernel: [] (warn_slowpath_null) from [] (wl12xx_queue_recovery_work+0x64/0x68 [wlcore])
Jun 07 07:49:56 beaglebone kernel: [] (wl12xx_queue_recovery_work [wlcore]) from [] (wl1271_tx_work+0xc4/0xc8 [wlcore])
Jun 07 07:49:56 beaglebone kernel: —[ end trace 7cc0486382026571 ]—
Jun 07 07:49:56 beaglebone kernel: wlcore: Hardware recovery in progress. FW ver: Rev 8.9.0.0.79
Jun 07 07:49:56 beaglebone kernel: wlcore: down
Jun 07 07:49:56 beaglebone kernel: ieee80211 phy0: Hardware restart was requested
Jun 07 07:49:56 beaglebone rsyslogd[591]: file ‘7’ write error: Read-only file system [v8.1901.0 try https://www.rsyslog.com/e/2027 ]
Jun 07 07:49:56 beaglebone rsyslogd[591]: rsyslogd[internal_messages]: 649 messages lost due to rate-limiting
Jun 07 07:49:56 beaglebone rsyslogd[591]: action ‘action-1-builtin:omfile’ (module ‘builtin:omfile’) message lost, could not be processed. Check for additional error messages before this one
/var/log/syslog
Jun 7 07:47:35 beaglebone kernel: [ 928.891260] ------------[ cut here ]------------
Jun 7 07:47:35 beaglebone kernel: [ 928.891558] WARNING: CPU: 0 PID: 1494 at drivers/net/wireless/ti/wlcore/main.c:808 wl12xx_queue_recovery_work+0x64/0x68 [wlcore]
Jun 7 07:47:35 beaglebone kernel: [ 928.891565] Modules linked in: xt_state xt_conntrack nft_counter nft_chain_nat_ipv4 ipt_MASQUERADE nft_compat aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 rfcomm cfg80211 bnep hci_uart bluetooth ecdh_generic pm33xx wkup_m3_ipc wkup_m3_rproc wlcore_sdio usb_f_acm u_serial usb_f_ecm usb_f_mass_storage usb_f_rndis u_ether libcomposite uio_pdrv_genirq uio pruss_soc_bus pru_rproc pruss irq_pruss_intc remoteproc virtio virtio_ring spidev
Jun 7 07:47:35 beaglebone kernel: [ 928.891664] CPU: 0 PID: 1494 Comm: kworker/u2:0 Tainted: G W 4.19.94-ti-r42 #1buster
Jun 7 07:47:35 beaglebone kernel: [ 928.891670] Hardware name: Generic AM33XX (Flattened Device Tree)
Jun 7 07:47:35 beaglebone kernel: [ 928.891792] Workqueue: phy0 wl1271_tx_work [wlcore]
Jun 7 07:47:35 beaglebone kernel: [ 928.891839] [] (unwind_backtrace) from [] (show_stack+0x20/0x24)
Jun 7 07:47:35 beaglebone kernel: [ 928.891863] [] (show_stack) from [] (dump_stack+0x8c/0xa0)
Jun 7 07:47:35 beaglebone kernel: [ 928.891881] [] (dump_stack) from [] (__warn.part.3+0xcc/0xe8)
Jun 7 07:47:35 beaglebone kernel: [ 928.891894] [] (__warn.part.3) from [] (warn_slowpath_null+0x54/0x5c)
Jun 7 07:47:35 beaglebone kernel: [ 928.892000] [] (warn_slowpath_null) from [] (wl12xx_queue_recovery_work+0x64/0x68 [wlcore])
Jun 7 07:47:35 beaglebone kernel: [ 928.892180] [] (wl12xx_queue_recovery_work [wlcore]) from [] (wl1271_tx_work+0xc4/0xc8 [wlcore])
Jun 7 07:47:35 beaglebone kernel: [ 928.892280] [] (wl1271_tx_work [wlcore]) from [] (process_one_work+0x1b4/0x504)
Jun 7 07:47:35 beaglebone kernel: [ 928.892294] [] (process_one_work) from [] (worker_thread+0x60/0x508)
Jun 7 07:47:35 beaglebone kernel: [ 928.892307] [] (worker_thread) from [] (kthread+0x16c/0x174)
Jun 7 07:47:35 beaglebone kernel: [ 928.892320] [] (kthread) from [] (ret_from_fork+0x14/0x2c)
Jun 7 07:47:35 beaglebone kernel: [ 928.892327] Exception stack(0xd5e73fb0 to 0xd5e73ff8)
Jun 7 07:47:35 beaglebone kernel: [ 928.892337] 3fa0: 00000000 00000000 00000000 00000000
Jun 7 07:47:35 beaglebone kernel: [ 928.892348] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Jun 7 07:47:35 beaglebone kernel: [ 928.892358] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
Jun 7 07:47:35 beaglebone kernel: [ 928.892366] —[ end trace 7cc048638202656f ]—
Jun 7 07:47:35 beaglebone kernel: [ 928.892459] wlcore: Hardware recovery in progress. FW ver: Rev 8.9.0.0.79
Jun 7 07:47:35 beaglebone kernel: [ 928.892486] wlcore: down
Jun 7 07:47:35 beaglebone kernel: [ 928.892530] wlcore: down
Jun 7 07:47:35 beaglebone kernel: [ 928.892546] wlcore: down
Jun 7 07:47:35 beaglebone kernel: [ 928.893083] ieee80211 phy0: Hardware restart was requested
Jun 7 07:47:35 beaglebone kernel: [ 929.311844] wlcore: PHY firmware version: Rev 8.2.0.0.242
