Okay, I got my board and the bunch of peripherals that go with it (excluding the monitor). I eagerly powered it on and hit my first problem. Garbage hex numbers on my CuteCom terminal. Ok, here’s the setup:
Host:
Laptop running Win 7 with Ubuntu 9.10 running inside VMWare.
USB-RS232 dongle <–> Null Modem Cable <–> IDC10-DB9
With no SD card, I get the following output when I power on the board using a 5v 1A supply.
Assuming, there might be some issue with the IDC10-DB9 cable (since all odd pins on header side were mapped to the first five pins of the DB9 and all 4 even pins were mapped to the pins 6-9 on DB9), I individually connected RX, TX and GND of headers (pins 2,3,5) to corresponding pins on DB9 (2,3,5), yet I see the same issue.
I am unable to find any previous record of this issue in the mailing list archives. I verified the cabling, settings (115200,8,N,1) and did a loop back test to eliminate setup issues. What else could go wrong? Any pointers?
Best regards,
Scott.
\0x00
bb\0x80\0x86\0x85\0xe2\0x85\0x85\0x86\0x87\0x85\0xc2\0xe2\0x84\0xa4\0x84\0x87\0xa7\0xc4\0x81\0x85\0xc4\0xa4\0x84\0x86\0x86\0xa4\0x87\0xe4\0x85F\0xf3\0x81\0x84\0xe6\0x85\0xe5\0x87\0xa4\0xa4\0xe4E\0xf3\0xa0\0xe5\0xe5\0xa4\0x84\0xc4\0xa7\0xa4\0xe7\0x84\0x85\0x85\0xa7b\0xe2\0x84\0xe6
\0x85\0xc4\0xe5\0x87\0xa7\0xe6\0xa4\0xe5\0x86\0x87\0x87bbb\0xc0\0xe1\0x87\0xa4\0x84\0xe6\0x84\0xa6\0x85\0x86\0xa4\0x84\0xa6\0x85\0x84\0x85\0x84f\0xe4\0x84\0x84\0x85\0x84\0xc4\0xa4\0xe4\0xa4\0xa7\0xc6bbC\0x00\0x85\0x85&\0x80 \0xe5\0xc4$\0x00f\0x00\0x85\0xa2\0x86\0x85BGc\0x02\0xa0$\0x84\0xc5\0x84\0xe5
\0xa4\0x84\0x87\0x02\0x00\0xe1\0x03\0x03b\0xa2\0xe1\0x84\0xf4\0x85\0x84F\0x03\0x01\0xe2\0x84\0x85\0x85"b\0x03\0x03\0x87\0xf4\0x85\0x85\0xc2A\0xf3\0xe7\0x87\0x81\0xe5\0xe6\0x85\0x86\0x85\0x84!\0x81\0xa7d`\0xc0\0x84\0xc5\0xa7\0x84\0xa4\0x84\0x86\0x84\0xa7\0xa6\0xe7\0x86\0x87bb\0xe2\0x87\0x84\0xa4\0xa4\0x86Fc\0x84\0x87\0x84\0x85\0xc5\0xc4b\0xa0\0xe5\0x84\0xa4\0xa4\0x86F\0xf3\0xe1\0xa4\0x84\0x85\0xc5\0xc5\0xe7
$D\0xf3
\0xc0\0x84\0x02\0xa4\0x84\0x84\0x84\0x84\0x84\0x84\0x84\0x84\0x84\0xa4\0x85\0x85\0xa4\0x84\0x85\0xa4b\0xc2\0x84\0xe4\0x86\0x87\0x86\0xe4\0xa4\0xe4\0x84\0x84\0xe4\0xe5\0x87\0x87\0x84\0xf4
B\0x82\0x86
B\0x82\0x86
B\0x82\0x85
B\0x82\0x85
B\0x82\0x84
B\0x82\0x84
B\0x82\0x84bC\0x00\0x85\0x85\0xa4\0x86\0xe5\0xa4\0xe4\0xa7\0x85\0x85\0xabc\0xff
00\0x94\0xf1\0xab\0x10\0xf1\0x10\0x10\0x10\0x10\0x10\0x10\0x10\0x10\0x10\0x10\0xd00\0x10\0x10\0x10\0x10\0x10\0x10\0x10\0x10\0x10\0x10
bb\0x80\0x86\0x85\0xe2\0x85\0x85\0x86\0x87\0x85\0xc2\0xe2\0x84\0xa4\0x84\0x87\0xa7\0xc4\0x81\0x85\0xc4\0xa4\0x84\0x86\0x86\0xa4\0x87\0xe4\0x85F\0xf3\0x81\0x84\0xe6\0x85\0xe5\0x87\0xa4\0xa4\0xe4E\0xf3\0xa0\0xe5\0xe5\0xa4\0x84\0xc4\0xa7\0xa4\0xe7\0x84\0x85\0x85\0xa7b\0xe2\0x84\0xe6\0x85
