Sadly, the new version is still not flashing
There are indeed three options, but the eMMC flasher was already in the previous lrelease, wasn’t it ( root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0 init=/usr/sbin/init-beagle-flasher)
When I choose option 2 to flash, it stops partway in the boot sequence and doesn’t look like it even gets to the flasher:
U-Boot SPL 2021.01-gea96725b (Sep 02 2023 - 15:57:35 +0000)
Model: BeagleBoard.org BeagleBone AI-64 R5
Board: BBONEAI-64-B0- rev B0
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE: BL31: v2.9(release):v2.9.0
NOTICE: BL31: Built : 15:57:35, Sep 2 2023
I/TC:
I/TC: OP-TEE version: 3.22.0 (gcc version 12.2.0 (Debian 12.2.0-14)) #1 Sat Sep 2 15:57:35 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
Model: Texas Instruments K3 J721E SoC
U-Boot 2021.01-gea96725b (Sep 02 2023 - 15:57:35 +0000)
SoC: J721E SR1.1 GP
DRAM: 4 GiB
Flash: 0 Bytes
MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Net: eth0: ethernet@46000000port@1
Press SPACE to abort autoboot in 2 seconds
board_name=[BBONEAI-64-B0-] ...
name_fdt=[k3-j721e-beagleboneai64.dtb] ...
i2c_write: error waiting for data ACK (status=0x116)
pca953x gpio@22: Error reading output register
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
740 bytes read in 7 ms (102.5 KiB/s)
BeagleBone AI-64 microSD (extlinux.conf) Options
1: BeagleBone AI-64 microSD Recovery
2: BeagleBone AI-64 copy microSD to eMMC
3: BeagleBone AI-64 microSD (default)
Enter choice: 2
Retrieving file: /initrd.img
9584432 bytes read in 409 ms (22.3 MiB/s)
Retrieving file: /Image
29417984 bytes read in 1239 ms (22.6 MiB/s)
append: root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0 init=/usr/sbin/init-beagle-flasher
Retrieving file: /k3-j721e-beagleboneai64.dtb
226922 bytes read in 17 ms (12.7 MiB/s)
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8f6dc000, end 8fffff30 ... OK
Loading Device Tree to 000000008f6a1000, end 000000008f6db669 ... OK
Starting kernel ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.168-ti-arm64-r110 (voodoo@rpi4b8g-18) (gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1bookworm SMP Fri Sep 1 21:28:03 UTC 2023
[ 0.000000] Machine model: BeagleBoard.org BeagleBone AI-64
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 560 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@fb000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb800000, size 24 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@fb800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af000000-0x00000000afffffff]
[ 0.000000] node 0: [mem 0x00000000b0000000-0x00000000b7ffffff]
[ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000fcffffff]
[ 0.000000] node 0: [mem 0x00000000fd000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x000000088fffffff]
[ 0.000000] node 0: [mem 0x0000000890000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] cma: Reserved 144 MiB at 0x0000000095800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s92824 r8192 d30056 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] Kernel command line: root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0 init=/usr/sbin/init-beagle-flasher
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000091800000-0x0000000095800000] (64MB)
[ 0.000000] Memory: 2069204K/4194304K available (17152K kernel code, 2296K rwdata, 5412K rodata, 3776K init, 722K bss, 1977644K reserved, 147456K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @890800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008900d0000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008900e0000
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000384] Console: colour dummy device 80x25
[ 0.000704] printk: console [tty0] enabled
[ 0.000733] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.000744] pid_max: default: 32768 minimum: 301
[ 0.000886] LSM: Security Framework initializing
[ 0.000913] Yama: becoming mindful.
[ 0.000986] AppArmor: AppArmor initialized
[ 0.000993] TOMOYO Linux initialized
[ 0.001070] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.001095] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002140] rcu: Hierarchical SRCU implementation.
[ 0.002708] Platform MSI: msi-controller@1820000 domain created
[ 0.003171] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.003323] EFI services will not be available.
[ 0.003582] smp: Bringing up secondary CPUs ...
[ 0.012285] Detected PIPT I-cache on CPU1
[ 0.012307] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.012317] GICv3: CPU1: using allocated LPI pending table @0x00000008900f0000
[ 0.012352] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.012406] smp: Brought up 1 node, 2 CPUs
[ 0.012425] SMP: Total of 2 processors activated.
[ 0.012431] CPU features: detected: 32-bit EL0 Support
[ 0.012436] CPU features: detected: CRC32 instructions
[ 0.012440] CPU features: detected: 32-bit EL1 Support
[ 0.032185] CPU: All CPU(s) started at EL2
[ 0.032236] alternatives: patching kernel code
[ 0.032909] devtmpfs: initialized
[ 0.046159] KASLR disabled due to lack of seed
[ 0.046314] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.046345] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.048760] pinctrl core: initialized pinctrl subsystem
[ 0.049096] DMI not present or invalid.
[ 0.049483] NET: Registered protocol family 16
[ 0.050210] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.050316] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.050457] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.050483] audit: initializing netlink subsys (disabled)
[ 0.050673] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
[ 0.050931] thermal_sys: Registered thermal governor 'fair_share'
[ 0.050933] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.050940] thermal_sys: Registered thermal governor 'step_wise'
[ 0.050944] thermal_sys: Registered thermal governor 'user_space'
[ 0.050949] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.051595] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.051647] ASID allocator initialised with 65536 entries
[ 0.075244] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.075261] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.075266] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.075271] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.077338] cryptd: max_cpu_qlen set to 1000
[ 0.079023] raid6: skip pq benchmark and using algorithm neonx8
[ 0.079039] raid6: using neon recovery algorithm
[ 0.079494] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.079789] vsys_3v3: supplied by evm_12v0
[ 0.079943] vsys_5v0: supplied by evm_12v0
[ 0.080380] iommu: Default domain type: Translated
[ 0.080680] SCSI subsystem initialized
[ 0.080771] usbcore: registered new interface driver usbfs
[ 0.080794] usbcore: registered new interface driver hub
[ 0.080809] usbcore: registered new device driver usb
[ 0.081095] mc: Linux media interface: v0.10
[ 0.081109] videodev: Linux video capture interface: v2.00
[ 0.081147] pps_core: LinuxPPS API ver. 1 registered
[ 0.081152] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.081160] PTP clock support registered
[ 0.081180] EDAC MC: Ver: 3.0.0
[ 0.082134] NetLabel: Initializing
[ 0.082146] NetLabel: domain hash size = 128
[ 0.082151] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.082182] NetLabel: unlabeled traffic allowed by default
[ 0.082519] clocksource: Switched to clocksource arch_sys_counter
[ 0.403232] VFS: Disk quotas dquot_6.6.0
[ 0.403288] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.403381] FS-Cache: Loaded
[ 0.403576] CacheFiles: Loaded
[ 0.403822] AppArmor: AppArmor Filesystem Enabled
[ 0.407070] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[ 0.407196] NET: Registered protocol family 2
[ 0.407503] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.408626] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.408920] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.409258] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.409527] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.409816] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.409936] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.410014] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.410149] NET: Registered protocol family 1
[ 0.410706] RPC: Registered named UNIX socket transport module.
[ 0.410718] RPC: Registered udp transport module.
[ 0.410722] RPC: Registered tcp transport module.
[ 0.410726] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.410734] NET: Registered protocol family 44
[ 0.410749] PCI: CLS 0 bytes, default 64
[ 0.410865] Trying to unpack rootfs image as initramfs...
[ 0.632408] Freeing initrd memory: 9356K
[ 0.632778] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.633122] kvm [1]: IPA Size Limit: 44 bits
[ 0.633510] kvm [1]: vgic-v2@6f020000
[ 0.633533] kvm [1]: GIC system register CPU interface enabled
[ 0.633572] kvm [1]: vgic interrupt IRQ9
[ 0.633666] kvm [1]: Hyp mode initialized successfully
[ 0.635952] Initialise system trusted keyrings
[ 0.636068] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.638180] zbud: loaded
[ 0.639467] NFS: Registering the id_resolver key type
[ 0.639496] Key type id_resolver registered
[ 0.639501] Key type id_legacy registered
[ 0.639547] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.639555] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.639572] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.639968] fuse: init (API version 7.32)
[ 0.660982] xor: measuring software checksum speed
[ 0.662268] 8regs : 7787 MB/sec
[ 0.663364] 32regs : 9085 MB/sec
[ 0.664601] arm64_neon : 7996 MB/sec
[ 0.664605] xor: using function: 32regs (9085 MB/sec)
[ 0.664616] Key type asymmetric registered
[ 0.664622] Asymmetric key parser 'x509' registered
[ 0.664652] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.664731] io scheduler mq-deadline registered
[ 0.666415] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.666766] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.670205] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.670238] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.670442] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.670459] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.670606] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.670634] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.670769] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.670786] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.670906] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.670924] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 0.672775] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.674954] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.675326] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[ 0.675521] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[ 0.677183] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.681827] brd: module loaded
[ 0.810573] loop: module loaded
[ 0.811231] megasas: 07.714.04.00-rc1
[ 0.813627] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.813640] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.813676] sky2: driver version 1.30
[ 0.814360] VFIO - User Level meta-driver version: 0.3
[ 0.814889] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.814909] ehci-pci: EHCI PCI platform driver
[ 0.815858] i2c /dev entries driver
[ 0.815988] Driver for 1-wire Dallas network protocol.
[ 0.816020] DS1WM w1 busmaster driver - (c) 2004 Szabolcs Gyurko
[ 0.817018] sdhci: Secure Digital Host Controller Interface driver
[ 0.817023] sdhci: Copyright(c) Pierre Ossman
[ 0.817216] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.818061] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.818279] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.818433] hid: raw HID events driver (C) Jiri Kosina
[ 0.818645] usbcore: registered new interface driver usbhid
[ 0.818651] usbhid: USB HID core driver
[ 0.819117] optee: probing for conduit method.
[ 0.819138] optee: revision 3.22 (001ace66)
[ 0.835553] optee: dynamic shared memory is enabled
[ 0.835767] optee: initialized driver
[ 0.837297] NET: Registered protocol family 10
[ 0.856075] Segment Routing with IPv6
[ 0.856145] mip6: Mobile IPv6
[ 0.856153] NET: Registered protocol family 17
[ 0.856259] Key type dns_resolver registered
[ 0.856266] mpls_gso: MPLS GSO support
[ 0.856461] registered taskstats version 1
[ 0.856470] Loading compiled-in X.509 certificates
[ 0.856531] zswap: loaded using pool lzo/zbud
[ 0.856668] Key type .fscrypt registered
[ 0.856674] Key type fscrypt-provisioning registered
[ 0.860585] Btrfs loaded, crc32c=crc32c-generic
[ 0.860665] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.868095] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
[ 0.917699] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.918140] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.919093] omap_i2c 42120000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.919658] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.920448] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.920958] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[ 0.921384] omap_i2c 2050000.i2c: bus 6 rev0.12 at 400 kHz
[ 0.922159] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 0.922269] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 0.922358] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 0.922543] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 0.937932] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 0.937962] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 0.937975] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 0.937988] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 0.938917] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 0.938930] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 0.938936] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 0.940679] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 0.940692] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 0.940698] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 0.941216] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[ 0.941771] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 30, base_baud = 3000000) is a 8250
[ 2.894713] printk: console [ttyS2] enabled
[ 2.899875] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 31, base_baud = 3000000) is a 8250
[ 2.908915] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 32, base_baud = 3000000) is a 8250
[ 2.925858] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[ 2.933040] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
[ 2.943362] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 2.986521] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.999244] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 3.007597] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 3.020412] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 3.027623] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 3.033970] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 3.044278] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
[ 3.090521] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 3.098078] davinci_mdio c000f00.mdio: no live phy, scanning all
[ 3.246195] davinci_mdio c000f00.mdio: phy[0]: device c000f00.mdio:00, driver unknown
[ 3.254044] davinci_mdio c000f00.mdio: phy[1]: device c000f00.mdio:01, driver unknown
[ 3.261901] davinci_mdio c000f00.mdio: phy[2]: device c000f00.mdio:02, driver unknown
[ 3.269716] davinci_mdio c000f00.mdio: phy[3]: device c000f00.mdio:03, driver unknown
[ 3.277535] davinci_mdio c000f00.mdio: phy[4]: device c000f00.mdio:04, driver unknown
[ 3.285350] davinci_mdio c000f00.mdio: phy[5]: device c000f00.mdio:05, driver unknown
[ 3.293164] davinci_mdio c000f00.mdio: phy[6]: device c000f00.mdio:06, driver unknown
[ 3.300977] davinci_mdio c000f00.mdio: phy[7]: device c000f00.mdio:07, driver unknown
[ 3.308792] davinci_mdio c000f00.mdio: phy[8]: device c000f00.mdio:08, driver unknown
[ 3.316606] davinci_mdio c000f00.mdio: phy[9]: device c000f00.mdio:09, driver unknown
[ 3.324419] davinci_mdio c000f00.mdio: phy[10]: device c000f00.mdio:0a, driver unknown
[ 3.332320] davinci_mdio c000f00.mdio: phy[11]: device c000f00.mdio:0b, driver unknown
[ 3.340223] davinci_mdio c000f00.mdio: phy[12]: device c000f00.mdio:0c, driver unknown
[ 3.348126] davinci_mdio c000f00.mdio: phy[13]: device c000f00.mdio:0d, driver unknown
[ 3.356027] davinci_mdio c000f00.mdio: phy[14]: device c000f00.mdio:0e, driver unknown
[ 3.363928] davinci_mdio c000f00.mdio: phy[15]: device c000f00.mdio:0f, driver unknown
[ 3.371829] davinci_mdio c000f00.mdio: phy[16]: device c000f00.mdio:10, driver unknown
[ 3.379730] davinci_mdio c000f00.mdio: phy[17]: device c000f00.mdio:11, driver unknown
[ 3.387630] davinci_mdio c000f00.mdio: phy[18]: device c000f00.mdio:12, driver unknown
[ 3.395531] davinci_mdio c000f00.mdio: phy[19]: device c000f00.mdio:13, driver unknown
[ 3.403433] davinci_mdio c000f00.mdio: phy[20]: device c000f00.mdio:14, driver unknown
[ 3.411334] davinci_mdio c000f00.mdio: phy[21]: device c000f00.mdio:15, driver unknown
[ 3.419235] davinci_mdio c000f00.mdio: phy[22]: device c000f00.mdio:16, driver unknown
[ 3.427135] davinci_mdio c000f00.mdio: phy[23]: device c000f00.mdio:17, driver unknown
[ 3.435036] davinci_mdio c000f00.mdio: phy[24]: device c000f00.mdio:18, driver unknown
[ 3.442936] davinci_mdio c000f00.mdio: phy[25]: device c000f00.mdio:19, driver unknown
[ 3.450837] davinci_mdio c000f00.mdio: phy[26]: device c000f00.mdio:1a, driver unknown
[ 3.458737] davinci_mdio c000f00.mdio: phy[27]: device c000f00.mdio:1b, driver unknown
[ 3.466639] davinci_mdio c000f00.mdio: phy[28]: device c000f00.mdio:1c, driver unknown
[ 3.474541] davinci_mdio c000f00.mdio: phy[29]: device c000f00.mdio:1d, driver unknown
[ 3.482441] davinci_mdio c000f00.mdio: phy[30]: device c000f00.mdio:1e, driver unknown
[ 3.490341] davinci_mdio c000f00.mdio: phy[31]: device c000f00.mdio:1f, driver unknown
[ 3.498313] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA01901, cpsw version 0x6BA80101 Ports: 9 quirks:00000000
[ 3.510994] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@1 error retrieving port phy: -19
[ 3.524452] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 3.535872] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.541370] xhci-hcd xhci-hc
I/TC:
SoC: J721E SR1.1 GP
DRAM: 4 GiB
Flash: 0 Bytes
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Scanning mmc 1:1...
Enter choice:
The boot sequence always seems to crash around USB / xhci, not always the exact same spot but close.
Back to reading about uboot and how to flash from there (assuming thats possible?)
Thank you!
