Hi All,
Seems my BBB has been corrupted, as I have below logs on console:
U-Boot SPL 2018.09-00002-g0b54a51eee (Sep 10 2018 - 19:41:39 -0500)
Trying to boot from MMC2
Loading Environment from EXT4... Card did not respond to voltage select!
U-Boot 2018.09-00002-g0b54a51eee (Sep 10 2018 - 19:41:39 -0500), Build: jenkins-github_Bootloader-Builder-65
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
RTC 32KCLK Source: External.
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
Model: Element14 BeagleBone Black Industrial:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
board_name=[A335BNLT] ...
board_rev=[EIA0] ...
switch to partitions #0, OK
Scanning mmc 1:1...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
2041 bytes read in 7 ms (284.2 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-4.14.71-ti-r80 ...
10416640 bytes read in 664 ms (15 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=1] ...
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb ...
loading /boot/dtbs/4.14.71-ti-r80/am335x-boneblack-uboot-univ.dtb ...
161723 bytes read in 26 ms (5.9 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: loading /lib/firmware/BB-BONE-eMMC1-01-00A0.dtbo ...
1440 bytes read in 142 ms (9.8 KiB/s)
uboot_overlays: loading /lib/firmware/BB-HDMI-TDA998x-00A0.dtbo ...
5127 bytes read in 96 ms (51.8 KiB/s)
uboot_overlays: loading /lib/firmware/BB-ADC-00A0.dtbo ...
711 bytes read in 53 ms (12.7 KiB/s)
uboot_overlays: loading /lib/firmware/AM335X-PRU-RPROC-4-14-TI-00A0.dtbo ...
3513 bytes read in 153 ms (21.5 KiB/s)
loading /boot/initrd.img-4.14.71-ti-r80 ...
4530240 bytes read in 293 ms (14.7 MiB/s)
debug: [console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait init=/opt/scripts/tools/eMMC/init.
debug: [bootz 0x82000000 0x88080000:452040 88000000] ...
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8fbad000, end 8ffff040 ... OK
reserving fdt memory region: addr=88000000 size=89000
Loading Device Tree to 8fb21000, end 8fbacfff ... OK
Starting kernel ...
[ 0.000000] Linux version 4.14.71-ti-r80 (root@b2-am57xx-beagle-x15-2gb) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1)) #1 SMP PREEMPT Fri 8
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x9c800000
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] random: get_random_bytes called from start_kernel+0xac/0x458 with crng_init=0
[ 0.000000] percpu: Embedded 18 pages/cpu @df8e7000 s41548 r8192 d23988 u73728
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129412
[ 0.000000] Kernel command line: console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait init=h
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 440272K/522240K available (13312K kernel code, 1169K rwdata, 4364K rodata, 1024K init, 361K bss, 32816K reserved, 49152K cma-r)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0000000 - 0xff800000 ( 504 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdfe00000 ( 510 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0e00000 (14304 kB)
[ 0.000000] .init : 0xc1400000 - 0xc1500000 (1024 kB)
[ 0.000000] .data : 0xc1500000 - 0xc1624498 (1170 kB)
[ 0.000000] .bss : 0xc162eb2c - 0xc1689000 ( 362 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] ftrace: allocating 42734 entries in 126 pages
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000024] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000053] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000068] OMAP clocksource: timer1 at 24000000 Hz
[ 0.002111] timer_probe: no matching timers found
[ 0.002450] Console: colour dummy device 80x30
[ 0.002486] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.002494] This ensures that you still see kernel messages. Please
[ 0.002501] update your kernel commandline.
[ 0.002531] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[ 0.021099] pid_max: default: 32768 minimum: 301
[ 0.021374] Security Framework initialized
[ 0.021394] Yama: becoming mindful.
[ 0.021436] AppArmor: AppArmor disabled by boot time parameter
[ 0.021517] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.021532] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.022554] CPU: Testing write buffer coherency: ok
[ 0.023079] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.037183] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.045095] Hierarchical SRCU implementation.
[ 0.056218] EFI services will not be available.
[ 0.061100] smp: Bringing up secondary CPUs ...
[ 0.061124] smp: Brought up 1 node, 1 CPU
[ 0.061136] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[ 0.061148] CPU: All CPU(s) started in SVC mode.
[ 0.062736] devtmpfs: initialized
[ 0.101365] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.101852] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.101883] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.105852] xor: measuring software checksum speed
[ 0.145113] arm4regs : 1200.000 MB/sec
[ 0.185071] 8regs : 1075.000 MB/sec
[ 0.225070] 32regs : 988.000 MB/sec
[ 0.265069] neon : 1624.000 MB/sec
[ 0.265080] xor: using function: neon (1624.000 MB/sec)
[ 0.265101] pinctrl core: initialized pinctrl subsystem
[ 0.266335] NET: Registered protocol family 16
[ 0.269342] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.360120] omap_hwmod: debugss: _wait_target_disable failed
[ 0.400796] cpuidle: using governor menu
[ 0.407249] OMAP GPIO hardware version 0.1
[ 0.432848] No ATAGs?
[ 0.432867] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.434482] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.434516] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.529127] raid6: neonx2 gen() 1883 MB/s
[ 0.597094] raid6: neonx2 xor() 1497 MB/s
[ 0.597106] raid6: using algorithm neonx2 gen() 1883 MB/s
[ 0.597115] raid6: .... xor() 1497 MB/s, rmw enabled
[ 0.597125] raid6: using neon recovery algorithm
[ 0.604900] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.611757] SCSI subsystem initialized
[ 0.613569] usbcore: registered new interface driver usbfs
[ 0.613644] usbcore: registered new interface driver hub
[ 0.613765] usbcore: registered new device driver usb
[ 0.614682] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.615673] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.616970] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 0.617502] media: Linux media interface: v0.10
[ 0.617567] Linux video capture interface: v2.00
[ 0.617755] pps_core: LinuxPPS API ver. 1 registered
[ 0.617768] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.617795] PTP clock support registered
[ 0.618443] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.621460] Advanced Linux Sound Architecture Driver Initialized.
[ 0.622179] NetLabel: Initializing
[ 0.622196] NetLabel: domain hash size = 128
[ 0.622206] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.622296] NetLabel: unlabeled traffic allowed by default
[ 0.625525] clocksource: Switched to clocksource timer1
[ 0.789310] VFS: Disk quotas dquot_6.6.0
[ 0.789453] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.802255] NET: Registered protocol family 2
[ 0.803203] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.803255] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.803317] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.803441] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.803466] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.803677] NET: Registered protocol family 1
[ 0.812633] RPC: Registered named UNIX socket transport module.
[ 0.812655] RPC: Registered udp transport module.
[ 0.812664] RPC: Registered tcp transport module.
[ 0.812672] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.813457] Unpacking initramfs...
[ 1.017589] random: fast init done
[ 1.060801] Freeing initrd memory: 4428K
[ 1.061389] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 1.061799] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 1.063885] audit: initializing netlink subsys (disabled)
[ 1.065152] audit: type=2000 audit(1.064:1): state=initialized audit_enabled=0 res=1
[ 1.065296] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 1.071377] zbud: loaded
[ 1.079028] NFS: Registering the id_resolver key type
[ 1.079079] Key type id_resolver registered
[ 1.079090] Key type id_legacy registered
[ 1.079111] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.079493] fuse init (API version 7.26)
[ 1.080099] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 1.099237] Key type asymmetric registered
[ 1.099266] Asymmetric key parser 'x509' registered
[ 1.099397] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 1.103739] io scheduler noop registered
[ 1.103758] io scheduler deadline registered
[ 1.104161] io scheduler cfq registered (default)
[ 1.104175] io scheduler mq-deadline registered
[ 1.106889] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 1.118753] gpio-of-helper ocp:cape-universal: ready
[ 1.129669] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 1.131945] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 1.135668] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250
[ 1.987350] console [ttyS0] enabled
[ 1.992062] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 31, base_baud = 3000000) is a 8250
[ 2.002050] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 32, base_baud = 3000000) is a 8250
[ 2.011899] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 33, base_baud = 3000000) is a 8250
[ 2.021843] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 34, base_baud = 3000000) is a 8250
[ 2.031636] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 35, base_baud = 3000000) is a 8250
[ 2.043879] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 2.051513] [drm] Initialized vgem 1.0.0 20120112 for virtual device on minor 0
[ 2.059141] usbcore: registered new interface driver udl
[ 2.072193] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.079508] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.086696] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.093869] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.101348] eqep 48300180.eqep: ver. 1.0
[ 2.105578] eqep 48300180.eqep: count_mode:0
[ 2.109906] eqep 48300180.eqep: invert_qa:1
[ 2.114135] eqep 48300180.eqep: invert_qb:1
[ 2.118361] eqep 48300180.eqep: invert_qi:0
[ 2.122588] eqep 48300180.eqep: invert_qs:0
[ 2.126813] eqep 48300180.eqep: swap_inputs:0
[ 2.131213] eqep 48300180.eqep: QDECCTL:0x0180
[ 2.135709] eqep 48300180.eqep: QPOSINIT:0x00000000
[ 2.140632] eqep 48300180.eqep: QPOSMAX:0xffffffff
[ 2.145466] eqep 48300180.eqep: QPOSCNT:0x00000000
[ 2.150305] eqep 48300180.eqep: omit_interrupt:0
[ 2.154965] eqep 48300180.eqep: QEINT:0x0800
[ 2.159277] eqep 48300180.eqep: QUPRD:0x05f5e100
[ 2.163938] eqep 48300180.eqep: QEPCTL:0x009e write
[ 2.168858] eqep 48300180.eqep: QEPCTL:0x009e read
[ 2.173711] eqep 48300180.eqep: irq:135, clk_rate:100000000
[ 2.179570] eqep 48302180.eqep: ver. 1.0
[ 2.183691] eqep 48302180.eqep: count_mode:0
[ 2.188024] eqep 48302180.eqep: invert_qa:1
[ 2.192252] eqep 48302180.eqep: invert_qb:1
[ 2.196479] eqep 48302180.eqep: invert_qi:0
[ 2.200705] eqep 48302180.eqep: invert_qs:0
[ 2.204931] eqep 48302180.eqep: swap_inputs:0
[ 2.209331] eqep 48302180.eqep: QDECCTL:0x0180
[ 2.213819] eqep 48302180.eqep: QPOSINIT:0x00000000
[ 2.218742] eqep 48302180.eqep: QPOSMAX:0xffffffff
[ 2.223577] eqep 48302180.eqep: QPOSCNT:0x00000000
[ 2.228412] eqep 48302180.eqep: omit_interrupt:0
[ 2.233072] eqep 48302180.eqep: QEINT:0x0800
[ 2.237384] eqep 48302180.eqep: QUPRD:0x05f5e100
[ 2.242045] eqep 48302180.eqep: QEPCTL:0x009e write
[ 2.246967] eqep 48302180.eqep: QEPCTL:0x009e read
[ 2.251813] eqep 48302180.eqep: irq:137, clk_rate:100000000
[ 2.257663] eqep 48304180.eqep: ver. 1.0
[ 2.261756] eqep 48304180.eqep: count_mode:0
[ 2.266084] eqep 48304180.eqep: invert_qa:1
[ 2.270313] eqep 48304180.eqep: invert_qb:1
[ 2.274538] eqep 48304180.eqep: invert_qi:0
[ 2.278764] eqep 48304180.eqep: invert_qs:0
[ 2.282990] eqep 48304180.eqep: swap_inputs:0
[ 2.287388] eqep 48304180.eqep: QDECCTL:0x0180
[ 2.291875] eqep 48304180.eqep: QPOSINIT:0x00000000
[ 2.296796] eqep 48304180.eqep: QPOSMAX:0xffffffff
[ 2.301632] eqep 48304180.eqep: QPOSCNT:0x00000000
[ 2.306467] eqep 48304180.eqep: omit_interrupt:0
[ 2.311127] eqep 48304180.eqep: QEINT:0x0800
[ 2.315438] eqep 48304180.eqep: QUPRD:0x05f5e100
[ 2.320098] eqep 48304180.eqep: QEPCTL:0x009e write
[ 2.325020] eqep 48304180.eqep: QEPCTL:0x009e read
[ 2.329867] eqep 48304180.eqep: irq:139, clk_rate:100000000
[ 2.364502] libphy: Fixed MDIO Bus: probed
[ 2.369700] CAN device driver interface
[ 2.374871] c_can_platform 481cc000.can: c_can_platform device registered (regs=fa1cc000, irq=42)
[ 2.384838] c_can_platform 481d0000.can: c_can_platform device registered (regs=fa1d0000, irq=43)
[ 2.449640] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 2.457392] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 2.464642] MDIO: davinci_mdio: dt: updated phy_id[0] from phy_mask[fffffffe]
[ 2.486568] libphy: 4a101000.mdio: probed
[ 2.490903] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 2.501412] cpsw 4a100000.ethernet: Detected MACID = 00:35:ff:90:27:1e
[ 2.508272] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[ 2.514756] cpsw 4a100000.ethernet: ALE Table size 1024
[ 2.520096] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[ 2.530940] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.537625] ehci-platform: EHCI generic platform driver
[ 2.543292] ehci-omap: OMAP-EHCI Host Controller driver
[ 2.549583] usbcore: registered new interface driver usb-storage
[ 2.558938] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
[ 2.572384] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 2.586898] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 2.592339] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 2.600122] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.606991] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.614272] usb usb1: Product: MUSB HDRC host driver
[ 2.619283] usb usb1: Manufacturer: Linux 4.14.71-ti-r80 musb-hcd
[ 2.625426] usb usb1: SerialNumber: musb-hdrc.1
[ 2.630932] hub 1-0:1.0: USB hub found
[ 2.634911] hub 1-0:1.0: 1 port detected
[ 2.651120] omap_rtc 44e3e000.rtc: registered as rtc0
[ 2.657844] i2c /dev entries driver
[ 2.662587] Driver for 1-wire Dallas network protocol.
[ 2.671173] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 2.678789] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[ 2.688849] cpuidle: enable-method property 'ti,am3352' found operations
[ 2.696558] sdhci: Secure Digital Host Controller Interface driver
[ 2.702849] sdhci: Copyright(c) Pierre Ossman
[ 2.708120] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 2.794210] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.806028] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.812829] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 2.819016] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 2.829351] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 2.842606] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.848989] usbcore: registered new interface driver usbhid
[ 2.854874] usbhid: USB HID core driver
[ 2.859409] remoteproc remoteproc0: wkup_m3 is available
[ 2.874944] wireguard: WireGuard 0.0.20180925 loaded. See www.wireguard.com for information.
[ 2.883764] wireguard: Copyright (C) 2015-2018 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[ 2.894585] NET: Registered protocol family 10
[ 2.901743] mmc1: new high speed MMC card at address 0001
[ 2.907824] Segment Routing with IPv6
[ 2.907908] mip6: Mobile IPv6
[ 2.907925] NET: Registered protocol family 17
[ 2.907947] can: controller area network core (rev 20170425 abi 9)
[ 2.908036] NET: Registered protocol family 29
[ 2.908166] Key type dns_resolver registered
[ 2.908171] mpls_gso: MPLS GSO support
[ 2.908406] omap_voltage_late_init: Voltage driver support not added
[ 2.908878] PM: Cannot get wkup_m3_ipc handle
[ 2.909072] ThumbEE CPU extension supported.
[ 2.909094] Registering SWP/SWPB emulation handler
[ 2.910296] registered taskstats version 1
[ 2.910421] zswap: loaded using pool lzo/zbud
[ 2.916602] Btrfs loaded, crc32c=crc32c-generic
[ 2.916702] ima: No TPM chip found, activating TPM-bypass! (rc=-19)
[ 2.916723] ima: Allocated hash algorithm: sha256
[ 2.996792] mmcblk1: mmc1:0001 M62704 3.53 GiB
[ 3.004367] mmcblk1boot0: mmc1:0001 M62704 partition 1 2.00 MiB
[ 3.010985] mmcblk1boot1: mmc1:0001 M62704 partition 2 2.00 MiB
[ 3.018231] mmcblk1rpmb: mmc1:0001 M62704 partition 3 512 KiB
[ 3.025705] mmcblk1: p1
[ 3.164285] tda998x 0-0070: found TDA19988
[ 3.170225] tilcdc 4830e000.lcdc: bound 0-0070 (ops tda998x_ops)
[ 3.176385] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.183063] [drm] No driver support for vblank timestamp query.
[ 3.189572] [drm] Cannot find any crtc or sizes
[ 3.194875] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 1
[ 3.217069] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 3.228519] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 3.234411] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 3.241487] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
Starting eMMC Flasher from microSD media
Version: [1.20180412: all ssh regneration override...]
Prepare environment for flashing
Starting at Sat Jan 1 00:00:26 UTC 2000
==> Giving system time to stablize...
5 4 3 2 1
==> Preparing /tmp
==> Preparing sysctl
==> sysctl: vm.min_free_kbytes=[2654]
==> sysctl: setting: [sysctl -w vm.min_free_kbytes=16384]
vm.min_free_kbytes = 16384
==> Determining root drive
==> console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait init=/opt/scripts/tools/eMMC/init-eMMh
==> root_drive=[/dev/mmcblk1p1]
====> Root drive identified at [/dev/mmcblk1p1]
==> Boot Drive [/dev/mmcblk1p1]
==> Figuring out Source and Destination devices
====> Source identified: [/dev/mmcblk1]
====> Destination identified: [/dev/mmcblk0]
==> Figuring out machine
====> Machine is TI_AM335x_BeagleBone_Black
====> Machine is compatible with BeagleBone Black
5 4 3 2 1
Checking for Valid bbb-eeprom header
==> Valid bbb-eeprom header found [335]
Checking running system
==> Copying: [/dev/mmcblk1] -> [/dev/mmcblk0]
==> lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk1 179:0 0 3.5G 0 disk
`-mmcblk1p1 179:1 0 3.5G 0 part /
mmcblk1boot0 179:8 0 2M 1 disk
mmcblk1boot1 179:16 0 2M 1 disk
mmcblk1rpmb 179:24 0 512K 0 disk
==> df -h | grep rootfs:
!==> Error: [/dev/mmcblk0] does not exist
writing to [/dev/mmcblk0] failed...
==> Stopping Cylon LEDs ...
Traceback (last called is first):
reset_leds() in /opt/scripts/tools/eMMC/functions.sh:433
write_failure() in /opt/scripts/tools/eMMC/functions.sh:451
check_running_system() in /opt/scripts/tools/eMMC/functions.sh:614
main() in /opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh:47
The command kill $CYLON_PID > /dev/null 2>&1 exited with exit code 2.
Tearing Down script environment
==> Unmounting /tmp
blockdev: cannot open /dev/mmcblk0: No such file or directory
==> Setting LEDs to
[ 39.338018] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
[ 39.338018]
[ 39.347223] CPU: 0 PID: 1 Comm: init-eMMC-flash Not tainted 4.14.71-ti-r80 #1
[ 39.354391] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 39.360560] [<c0113910>] (unwind_backtrace) from [<c010debc>] (show_stack+0x20/0x24)
[ 39.368348] [<c010debc>] (show_stack) from [<c0d9ca74>] (dump_stack+0x80/0x94)
[ 39.375623] [<c0d9ca74>] (dump_stack) from [<c013fb20>] (panic+0x100/0x284)
[ 39.382626] [<c013fb20>] (panic) from [<c0145920>] (complete_and_exit+0x0/0x2c)
[ 39.389973] [<c0145920>] (complete_and_exit) from [<c01459bc>] (do_group_exit+0x50/0xd0)
[ 39.398104] [<c01459bc>] (do_group_exit) from [<c0145a5c>] (__wake_up_parent+0x0/0x30)
[ 39.406068] [<c0145a5c>] (__wake_up_parent) from [<c0108f00>] (ret_fast_syscall+0x0/0x54)
[ 39.414306] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
[ 39.414306]
[ 50.597557] random: crng init done
[ 50.600979] random: 7 urandom warning(s) missed due to ratelimiting
CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7.1 | VT102 | Offline | ttyUSB0
KIndly share the detailed steps to revcover, I want to restabilize the board, then I will make my testbed to for further skillup.
Regards.
Ankur
