@RobertCNelson ,
Okay…I will get on it shortly (for the boot log)…
Also…I was receiving errors on USB issues on this desktop I am using now. The reason being is that my USB C has USB 2.0 capabilities and my USB 3.0 ports are USB 2.0. Not an issue for you but I have errored out on this desktop w/ the BBAI-64 due to those reasons.
Now, onto the boot log…
Oh! Could it be that when I boot the SD Card image or eMMC on the target (BBAI-64), I am faltering due to the, in this instance, the Servo Cape already being attached before the image loads?
Boot log on the way and boot log:
U-Boot SPL 2021.01-gea96725b (Sep 02 2023 - 15:57:35 +0000)
Model: BeagleBoard.org BeagleBone AI-64 R5
EEPROM not available at 0x50, trying to read at 0x51
Board: BBONEAI-64-B0- rev B0
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE: BL31: v2.9(release):v2.9.0
NOTICE: BL31: Built : 15:57:35, Sep 2 2023
I/TC:
I/TC: OP-TEE version: 3.22.0 (gcc version 10.2.1 20210110 (Debian 10.2.1-6)) #1 Sat Sep 2 15:57:35 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
I/TC:
Model: Texas Instruments K3 J721E SoC
ti_i2c_eeprom_am6_parse_record: Ignoring record id 17
U-Boot 2021.01-gea96725b (Sep 02 2023 - 15:57:35 +0000)
SoC: J721E SR1.1 GP
DRAM: 4 GiB
Flash: 0 Bytes
MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from FAT... ** No partition table - mmc 0 **
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Net: eth0: ethernet@46000000port@1
Press SPACE to abort autoboot in 2 seconds
board_name=[BBONEAI-64-B0-] ...
name_fdt=[k3-j721e-beagleboneai64.dtb] ...
i2c_write: error waiting for data ACK (status=0x116)
pca953x gpio@22: Error reading output register
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
740 bytes read in 9 ms (80.1 KiB/s)
BeagleBone AI-64 microSD (extlinux.conf) Options
1: BeagleBone AI-64 microSD Recovery
2: BeagleBone AI-64 copy microSD to eMMC
3: BeagleBone AI-64 microSD (default)
Enter choice: 3
Retrieving file: /initrd.img
9150156 bytes read in 396 ms (22 MiB/s)
Retrieving file: /Image
29616640 bytes read in 1259 ms (22.4 MiB/s)
append: root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0 quiet init=/usr/sbin/init-beagle-flasher
Retrieving file: /k3-j721e-beagleboneai64.dtb
226922 bytes read in 19 ms (11.4 MiB/s)
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8f746000, end 8ffffecc ... OK
Loading Device Tree to 000000008f70b000, end 000000008f745669 ... OK
Starting kernel ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[ 0.598780] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.599000] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.599140] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.599259] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.599405] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 1.118333] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@1 error retrieving port phy: -19
[ 2.233551] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 3.013509] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[ 3.020769] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[ 3.029309] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 3.036626] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 3.043951] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 3.051257] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 3.213560] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 4.134495] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 4.143101] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 4.149525] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 4.155948] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 4.162371] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 4.168793] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 4.175215] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 4.181638] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 4.188060] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 4.194482] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 4.200904] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 4.207326] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 4.213748] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 4.220171] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x00e7177f
[ 4.226593] mmc1: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00000900
[ 4.233015] mmc1: sdhci: Host ctl2: 0x0000000c
[ 4.237444] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089452b20c
[ 4.244558] mmc1: sdhci: ============================================
[ 4.253613] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 4.262216] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 4.268638] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 4.275061] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 4.281483] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 4.287906] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 4.294328] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 4.300750] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 4.307172] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 4.313595] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 4.320017] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[ 4.326439] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 4.332862] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 4.339284] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x00e7177f
[ 4.345706] mmc1: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00000900
[ 4.352128] mmc1: sdhci: Host ctl2: 0x0000000c
[ 4.356557] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089452b20c
[ 4.363672] mmc1: sdhci: ============================================
[ 4.370285] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 4.503361] blk_update_request: I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.516071] blk_update_request: I/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.528826] blk_update_request: I/O error, dev mmcblk1, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.541504] blk_update_request: I/O error, dev mmcblk1, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.554474] blk_update_request: I/O error, dev mmcblk1, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.567376] blk_update_request: I/O error, dev mmcblk1, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.580384] blk_update_request: I/O error, dev mmcblk1, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.593387] blk_update_request: I/O error, dev mmcblk1, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.603607] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 4.611638] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 4.620244] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 4.626668] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 4.633093] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 4.639516] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 4.645939] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 4.652364] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 4.658789] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 4.665212] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 4.671638] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 4.678063] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 4.684487] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 4.690911] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 4.697335] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 4.703761] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 4.710184] mmc1: sdhci: Host ctl2: 0x0000000c
[ 4.714615] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089452b20c
[ 4.721733] mmc1: sdhci: ============================================
[ 4.731073] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 4.739680] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 4.746105] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 4.752530] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 4.758954] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 4.765380] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 4.771805] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 4.778229] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 4.784653] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 4.791078] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 4.797503] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[ 4.803928] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 4.810353] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 4.816778] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 4.823203] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 4.829628] mmc1: sdhci: Host ctl2: 0x0000000c
[ 4.834058] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089452b20c
[ 4.841176] mmc1: sdhci: ============================================
[ 4.852386] blk_update_request: I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.865200] blk_update_request: I/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 4.888110] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 4.896194] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 4.904801] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 4.911228] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 4.917653] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 4.924080] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 4.930506] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 4.936932] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 4.943358] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 4.949783] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 4.956210] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 4.962634] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 4.969059] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 4.975483] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 4.981909] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 4.988335] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 4.994758] mmc1: sdhci: Host ctl2: 0x0000000c
[ 4.999187] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089452b20c
[ 5.006301] mmc1: sdhci: ============================================
[ 5.015555] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 5.024162] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 5.030589] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 5.037015] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 5.043441] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 5.049868] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 5.056292] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 5.062718] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 5.069144] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 5.075569] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 5.081996] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 5.088422] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 5.094846] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 5.101271] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 5.107697] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 5.114120] mmc1: sdhci: Host ctl2: 0x0000000c
[ 5.118554] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089452b20c
[ 5.125671] mmc1: sdhci: ============================================
[ 5.153009] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 5.421810] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 5.430418] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 5.436843] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 5.443266] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 5.449689] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 5.456111] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 5.462533] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 5.468955] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 5.475377] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 5.481800] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 5.488222] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 5.494644] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 5.501066] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 5.507488] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 5.513910] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 5.520332] mmc1: sdhci: Host ctl2: 0x0000000c
[ 5.524761] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089452b20c
[ 5.531876] mmc1: sdhci: ============================================
[ 5.539840] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 5.546596] usb usb1-port1: unable to enumerate USB device
[ 5.554789] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 5.563396] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 5.569822] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 5.576247] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 5.582672] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 5.589098] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 5.595522] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 5.601946] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 5.601948] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 5.601950] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 5.601952] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 5.601954] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 5.601957] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 5.601959] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 5.601961] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 5.601963] mmc1: sdhci: Host ctl2: 0x0000000c
[ 5.601966] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089452b20c
[ 5.601967] mmc1: sdhci: ============================================
[ 5.621973] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 5.634156] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 5.634159] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 5.634161] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 5.634163] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 5.634166] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 5.634169] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 5.647011] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 5.647013] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 5.647015] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 5.647017] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 5.647020] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 5.647022] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 5.657871] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 5.657873] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 5.657875] mmc1: sdhci: Host ctl2: 0x0000000c
[ 5.657877] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089452b20c
[ 5.671412] mmc1: sdhci: ============================================
[ 5.674187] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 5.686436] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 5.686439] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 5.686441] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 5.686443] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 5.686445] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 5.686449] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 5.699291] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 5.699293] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 5.699295] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 5.699297] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 5.699299] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 5.699301] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 5.699303] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 5.699306] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 5.712148] mmc1: sdhci: Host ctl2: 0x0000000c
[ 5.712151] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089452b20c
[ 5.712152] mmc1: sdhci: ============================================
[ 5.731490] Buffer I/O error on dev mmcblk1, logical block 7572464, async page read
[ 6.043006] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 6.051611] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 6.058034] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 6.064458] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 6.070880] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 6.077303] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 6.083725] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 6.090147] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 6.096569] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 6.102991] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 6.109414] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 6.115836] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 6.122257] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 6.128680] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 6.135102] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 6.141524] mmc1: sdhci: Host ctl2: 0x0000000c
[ 6.145952] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089452b20c
[ 6.153067] mmc1: sdhci: ============================================
[ 6.161999] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 6.170589] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 6.177011] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 6.183434] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 6.189856] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 6.196278] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 6.202700] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 6.209122] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 6.215544] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 6.221966] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 6.228388] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 6.234811] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 6.241233] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 6.247655] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 6.254077] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 6.260498] mmc1: sdhci: Host ctl2: 0x0000000c
[ 6.264927] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089452b20c
[ 6.272041] mmc1: sdhci: ============================================
[ 6.296151] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 6.304742] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 6.311164] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 6.317586] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 6.324008] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 6.330430] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 6.336852] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 6.343274] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 6.349696] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 6.356119] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 6.362541] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 6.368962] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 6.375384] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 6.381806] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 6.388228] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 6.394650] mmc1: sdhci: Host ctl2: 0x0000000c
[ 6.399079] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089452b20c
[ 6.406193] mmc1: sdhci: ============================================
[ 6.415167] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 6.423757] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 6.430180] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 6.436601] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 6.443024] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 6.449446] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 6.455868] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 6.462290] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 6.468712] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 6.475134] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 6.481556] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 6.487978] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 6.494400] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 6.500822] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 6.507244] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 6.513666] mmc1: sdhci: Host ctl2: 0x0000000c
[ 6.518095] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000089452b20c
[ 6.525209] mmc1: sdhci: ============================================
[ 6.549196] Buffer I/O error on dev mmcblk1, logical block 7572464, async page read
Gave up waiting for root file system device. Common problems:
- Boot args (cat /proc/cmdline)
- Check rootdelay= (did the system wait long enough?)
- Missing modules (cat /proc/modules; ls /dev)
ALERT! /dev/mmcblk1p2 does not exist. Dropping to a shell!
BusyBox v1.30.1 (Debian 1:1.30.1-6+b3) built-in shell (ash)
Enter 'help' for a list of built-in commands.
(initramfs)
Anyway, thank you for looking into this idea…
@RobertCNelson , also…
Another interesting fact here… As soon as I booted the Yocto image, I started to have concerns w/ not being able to use beagleboard.org images w/ success 100% of the time when before the Yocto builds, the board (BBAI-64) booted w/out error.
And to say this…
I will test the boot process w/out the Cape onboard the BBAI-64 and return service. Sir, the first boot log is number 3. This next boot log is when I pick number 2.
I/TC:
SoC: J721E SR1.1 GP
DRAM: 4 GiB
Flash: 0 Bytes
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Scanning mmc 1:1...
740 bytes read in 8 ms (89.8 KiB/s)
Enter choice: 2
9150156 bytes read in 395 ms (22.1 MiB/s)
29616640 bytes read in 1258 ms (22.5 MiB/s)
append: root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0 init=/usr/sbin/init-beagle-flasher
226922 bytes read in 18 ms (12 MiB/s)
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.168-ti-arm64-r111 (voodoo@AM69-SK-32g-01) (gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1bullseye SMP Tue Sep 26 14:22:20 UTC 2023
[ 0.000000] Machine model: BeagleBoard.org BeagleBone AI-64
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 560 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@fb000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb800000, size 24 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@fb800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af000000-0x00000000afffffff]
[ 0.000000] node 0: [mem 0x00000000b0000000-0x00000000b7ffffff]
[ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000fcffffff]
[ 0.000000] node 0: [mem 0x00000000fd000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x000000088fffffff]
[ 0.000000] node 0: [mem 0x0000000890000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] cma: Reserved 144 MiB at 0x0000000095800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s92824 r8192 d30056 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] Kernel command line: root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0 init=/usr/sbin/init-beagle-flasher
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000091800000-0x0000000095800000] (64MB)
[ 0.000000] Memory: 2069440K/4194304K available (17280K kernel code, 2298K rwdata, 5420K rodata, 3776K init, 720K bss, 1977408K reserved, 147456K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @890800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008900d0000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008900e0000
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000409] Console: colour dummy device 80x25
[ 0.000717] printk: console [tty0] enabled
[ 0.000747] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.000756] pid_max: default: 32768 minimum: 301
[ 0.000894] LSM: Security Framework initializing
[ 0.000921] Yama: becoming mindful.
[ 0.000993] AppArmor: AppArmor initialized
[ 0.001000] TOMOYO Linux initialized
[ 0.001077] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.001103] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002166] rcu: Hierarchical SRCU implementation.
[ 0.002729] Platform MSI: msi-controller@1820000 domain created
[ 0.003193] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.003338] EFI services will not be available.
[ 0.003598] smp: Bringing up secondary CPUs ...
[ 0.012301] Detected PIPT I-cache on CPU1
[ 0.012324] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.012334] GICv3: CPU1: using allocated LPI pending table @0x00000008900f0000
[ 0.012371] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.012429] smp: Brought up 1 node, 2 CPUs
[ 0.012446] SMP: Total of 2 processors activated.
[ 0.012452] CPU features: detected: 32-bit EL0 Support
[ 0.012457] CPU features: detected: CRC32 instructions
[ 0.012462] CPU features: detected: 32-bit EL1 Support
[ 0.032274] CPU: All CPU(s) started at EL2
[ 0.032324] alternatives: patching kernel code
[ 0.033029] devtmpfs: initialized
[ 0.046272] KASLR disabled due to lack of seed
[ 0.046426] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.046457] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.048733] pinctrl core: initialized pinctrl subsystem
[ 0.049069] DMI not present or invalid.
[ 0.049455] NET: Registered protocol family 16
[ 0.050184] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.050288] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.050428] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.050454] audit: initializing netlink subsys (disabled)
[ 0.050638] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
[ 0.050894] thermal_sys: Registered thermal governor 'fair_share'
[ 0.050897] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.050904] thermal_sys: Registered thermal governor 'step_wise'
[ 0.050909] thermal_sys: Registered thermal governor 'user_space'
[ 0.050913] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.051542] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.051595] ASID allocator initialised with 65536 entries
[ 0.074897] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.074916] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.074921] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.074925] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.077069] cryptd: max_cpu_qlen set to 1000
[ 0.078853] raid6: skip pq benchmark and using algorithm neonx8
[ 0.078869] raid6: using neon recovery algorithm
[ 0.079339] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.079624] vsys_3v3: supplied by evm_12v0
[ 0.079778] vsys_5v0: supplied by evm_12v0
[ 0.080214] iommu: Default domain type: Translated
[ 0.080504] SCSI subsystem initialized
[ 0.080601] usbcore: registered new interface driver usbfs
[ 0.080619] usbcore: registered new interface driver hub
[ 0.080661] usbcore: registered new device driver usb
[ 0.080965] mc: Linux media interface: v0.10
[ 0.080979] videodev: Linux video capture interface: v2.00
[ 0.081019] pps_core: LinuxPPS API ver. 1 registered
[ 0.081024] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.081034] PTP clock support registered
[ 0.081054] EDAC MC: Ver: 3.0.0
[ 0.082016] NetLabel: Initializing
[ 0.082027] NetLabel: domain hash size = 128
[ 0.082031] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.082061] NetLabel: unlabeled traffic allowed by default
[ 0.082385] clocksource: Switched to clocksource arch_sys_counter
[ 0.400996] VFS: Disk quotas dquot_6.6.0
[ 0.401053] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.401141] FS-Cache: Loaded
[ 0.401337] CacheFiles: Loaded
[ 0.401582] AppArmor: AppArmor Filesystem Enabled
[ 0.404802] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[ 0.404925] NET: Registered protocol family 2
[ 0.405233] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.406505] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.406794] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.407135] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.407397] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.407674] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.407788] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.407870] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.408014] NET: Registered protocol family 1
[ 0.408593] RPC: Registered named UNIX socket transport module.
[ 0.408605] RPC: Registered udp transport module.
[ 0.408609] RPC: Registered tcp transport module.
[ 0.408613] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.408619] NET: Registered protocol family 44
[ 0.408629] PCI: CLS 0 bytes, default 64
[ 0.408740] Trying to unpack rootfs image as initramfs...
[ 0.563554] Freeing initrd memory: 8932K
[ 0.564228] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.564586] kvm [1]: IPA Size Limit: 44 bits
[ 0.564979] kvm [1]: vgic-v2@6f020000
[ 0.565003] kvm [1]: GIC system register CPU interface enabled
[ 0.565042] kvm [1]: vgic interrupt IRQ9
[ 0.565114] kvm [1]: Hyp mode initialized successfully
[ 0.567393] Initialise system trusted keyrings
[ 0.567496] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.569629] zbud: loaded
[ 0.570902] NFS: Registering the id_resolver key type
[ 0.570925] Key type id_resolver registered
[ 0.570930] Key type id_legacy registered
[ 0.570985] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.570993] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.571011] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.571422] fuse: init (API version 7.32)
[ 0.593214] NET: Registered protocol family 38
[ 0.593242] xor: measuring software checksum speed
[ 0.594527] 8regs : 7753 MB/sec
[ 0.595612] 32regs : 9101 MB/sec
[ 0.596834] arm64_neon : 8088 MB/sec
[ 0.596837] xor: using function: 32regs (9101 MB/sec)
[ 0.596848] Key type asymmetric registered
[ 0.596852] Asymmetric key parser 'x509' registered
[ 0.596889] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.596964] io scheduler mq-deadline registered
[ 0.598698] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.598960] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.602501] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.602530] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.602716] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.602733] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.602859] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.602876] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.603003] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.603021] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.603159] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.603172] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 0.605023] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.607253] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.607621] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[ 0.607823] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[ 0.609492] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.614090] brd: module loaded
[ 0.742446] loop: module loaded
[ 0.743116] megasas: 07.714.04.00-rc1
[ 0.745639] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.745653] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.745689] sky2: driver version 1.30
[ 0.746442] VFIO - User Level meta-driver version: 0.3
[ 0.746942] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.746963] ehci-pci: EHCI PCI platform driver
[ 0.747882] i2c /dev entries driver
[ 0.748013] Driver for 1-wire Dallas network protocol.
[ 0.748045] DS1WM w1 busmaster driver - (c) 2004 Szabolcs Gyurko
[ 0.749045] sdhci: Secure Digital Host Controller Interface driver
[ 0.749051] sdhci: Copyright(c) Pierre Ossman
[ 0.749239] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.750076] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.750297] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.750497] hid: raw HID events driver (C) Jiri Kosina
[ 0.750681] usbcore: registered new interface driver usbhid
[ 0.750687] usbhid: USB HID core driver
[ 0.751163] optee: probing for conduit method.
[ 0.751185] optee: revision 3.22 (001ace66)
[ 0.767597] optee: dynamic shared memory is enabled
[ 0.767825] optee: initialized driver
[ 0.769376] NET: Registered protocol family 10
[ 0.784791] Segment Routing with IPv6
[ 0.784860] mip6: Mobile IPv6
[ 0.784868] NET: Registered protocol family 17
[ 0.784980] Key type dns_resolver registered
[ 0.784987] mpls_gso: MPLS GSO support
[ 0.785164] registered taskstats version 1
[ 0.785175] Loading compiled-in X.509 certificates
[ 0.785234] zswap: loaded using pool lzo/zbud
[ 0.785363] Key type .fscrypt registered
[ 0.785370] Key type fscrypt-provisioning registered
[ 0.789162] Btrfs loaded, crc32c=crc32c-generic
[ 0.789259] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.797080] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
[ 0.847324] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.847795] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.848768] omap_i2c 42120000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.849372] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.850213] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.850786] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[ 0.851234] omap_i2c 2050000.i2c: bus 6 rev0.12 at 400 kHz
[ 0.852041] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 0.852142] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 0.852244] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 0.852409] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 0.867892] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 0.867922] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 0.867936] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 0.867949] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 0.868868] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 0.868880] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 0.868885] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 0.870629] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 0.870643] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 0.870648] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 0.871199] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[ 0.871765] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 30, base_baud = 3000000) is a 8250
[ 2.830560] printk: console [ttyS2] enabled
[ 2.835740] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 31, base_baud = 3000000) is a 8250
[ 2.844808] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 32, base_baud = 3000000) is a 8250
[ 2.861810] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[ 2.868992] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
[ 2.879373] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 2.922387] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.934272] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 2.942619] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 2.955433] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 2.962641] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 2.969015] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 2.979334] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
[ 3.022385] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 3.029942] davinci_mdio c000f00.mdio: no live phy, scanning all
[ 3.152677] davinci_mdio c000f00.mdio: phy[0]: device c000f00.mdio:00, driver unknown
[ 3.160531] davinci_mdio c000f00.mdio: phy[1]: device c000f00.mdio:01, driver unknown
[ 3.168392] davinci_mdio c000f00.mdio: phy[2]: device c000f00.mdio:02, driver unknown
[ 3.176208] davinci_mdio c000f00.mdio: phy[3]: device c000f00.mdio:03, driver unknown
[ 3.184022] davinci_mdio c000f00.mdio: phy[4]: device c000f00.mdio:04, driver unknown
[ 3.191837] davinci_mdio c000f00.mdio: phy[5]: device c000f00.mdio:05, driver unknown
[ 3.199650] davinci_mdio c000f00.mdio: phy[6]: device c000f00.mdio:06, driver unknown
[ 3.207467] davinci_mdio c000f00.mdio: phy[7]: device c000f00.mdio:07, driver unknown
[ 3.215281] davinci_mdio c000f00.mdio: phy[8]: device c000f00.mdio:08, driver unknown
[ 3.223094] davinci_mdio c000f00.mdio: phy[9]: device c000f00.mdio:09, driver unknown
[ 3.230909] davinci_mdio c000f00.mdio: phy[10]: device c000f00.mdio:0a, driver unknown
[ 3.238810] davinci_mdio c000f00.mdio: phy[11]: device c000f00.mdio:0b, driver unknown
[ 3.246710] davinci_mdio c000f00.mdio: phy[12]: device c000f00.mdio:0c, driver unknown
[ 3.254610] davinci_mdio c000f00.mdio: phy[13]: device c000f00.mdio:0d, driver unknown
[ 3.262511] davinci_mdio c000f00.mdio: phy[14]: device c000f00.mdio:0e, driver unknown
[ 3.270417] davinci_mdio c000f00.mdio: phy[15]: device c000f00.mdio:0f, driver unknown
[ 3.278318] davinci_mdio c000f00.mdio: phy[16]: device c000f00.mdio:10, driver unknown
[ 3.286218] davinci_mdio c000f00.mdio: phy[17]: device c000f00.mdio:11, driver unknown
[ 3.294119] davinci_mdio c000f00.mdio: phy[18]: device c000f00.mdio:12, driver unknown
[ 3.302019] davinci_mdio c000f00.mdio: phy[19]: device c000f00.mdio:13, driver unknown
[ 3.309919] davinci_mdio c000f00.mdio: phy[20]: device c000f00.mdio:14, driver unknown
[ 3.317820] davinci_mdio c000f00.mdio: phy[21]: device c000f00.mdio:15, driver unknown
[ 3.325720] davinci_mdio c000f00.mdio: phy[22]: device c000f00.mdio:16, driver unknown
[ 3.333623] davinci_mdio c000f00.mdio: phy[23]: device c000f00.mdio:17, driver unknown
[ 3.341523] davinci_mdio c000f00.mdio: phy[24]: device c000f00.mdio:18, driver unknown
[ 3.349423] davinci_mdio c000f00.mdio: phy[25]: device c000f00.mdio:19, driver unknown
[ 3.357324] davinci_mdio c000f00.mdio: phy[26]: device c000f00.mdio:1a, driver unknown
[ 3.365224] davinci_mdio c000f00.mdio: phy[27]: device c000f00.mdio:1b, driver unknown
[ 3.373124] davinci_mdio c000f00.mdio: phy[28]: device c000f00.mdio:1c, driver unknown
[ 3.381026] davinci_mdio c000f00.mdio: phy[29]: device c000f00.mdio:1d, driver unknown
[ 3.388926] davinci_mdio c000f00.mdio: phy[30]: device c000f00.mdio:1e, driver unknown
[ 3.396829] davinci_mdio c000f00.mdio: phy[31]: device c000f00.mdio:1f, driver unknown
[ 3.404802] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA01901, cpsw version 0x6BA80101 Ports: 9 quirks:00000000
[ 3.417484] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@1 error retrieving port phy: -19
[ 3.430894] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 3.442690] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.448196] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 3.455946] xhci-hcd xhci-hcd.0.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[ 3.465340] xhci-hcd xhci-hcd.0.auto: irq 230, io mem 0x06410000
[ 3.471440] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.476916] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 3.484567] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 3.491180] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 3.499429] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.506640] usb usb1: Product: xHCI Host Controller
[ 3.511506] usb usb1: Manufacturer: Linux 5.10.168-ti-arm64-r111 xhci-hcd
[ 3.518278] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 3.523365] hub 1-0:1.0: USB hub found
[ 3.527123] hub 1-0:1.0: 1 port detected
[ 3.531213] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.539348] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 3.547598] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.554810] usb usb2: Product: xHCI Host Controller
[ 3.559675] usb usb2: Manufacturer: Linux 5.10.168-ti-arm64-r111 xhci-hcd
[ 3.566459] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 3.571518] hub 2-0:1.0: USB hub found
[ 3.575274] hub 2-0:1.0: 1 port detected
[ 3.681847] mmc0: CQHCI version 5.10
[ 3.690779] gpio gpiochip2: gpio-line-names is length 37 but should be at most length 36
[ 3.699849] vdd_mmc1: supplied by vsys_3v3
[ 3.704839] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 3.711707] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 3.718583] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 3.725411] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 3.729469] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 3.732233] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 3.749674] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 3.757188] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 3.765277] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 3.773369] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.838688] mmc0: Command Queue Engine enabled
[ 3.843134] mmc0: new HS200 MMC card at address 0001
[ 3.848452] mmcblk0: mmc0:0001 TB2916 14.6 GiB
[ 3.853092] mmcblk0boot0: mmc0:0001 TB2916 partition 1 4.00 MiB
[ 3.859115] mmcblk0boot1: mmc0:0001 TB2916 partition 2 4.00 MiB
[ 3.865119] mmcblk0rpmb: mmc0:0001 TB2916 partition 3 4.00 MiB, chardev (236:0)
[ 4.626406] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 4.774557] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
[ 4.780822] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 4.786299] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x18001000-0x18010fff])
[ 4.795760] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 4.802646] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[ 4.808641] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 4.818339] pci 0000:00:00.0: supports D1
[ 4.822338] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 4.832314] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.844192] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 4.850819] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 4.856124] pcieport 0000:00:00.0: PME: Signaling with IRQ 504
[ 4.862148] pcieport 0000:00:00.0: AER: enabled with IRQ 504
[ 4.868753] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 4.879677] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[ 4.892505] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 4.938482] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 4.950304] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 4.958646] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 4.971457] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 4.978665] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 4.984988] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 4.995366] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 5.598405] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 5.605041] usb usb1-port1: attempt power cycle
[ 5.734354] mmc1: CQHCI version 5.10
[ 5.734465] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[ 5.745160] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[ 5.745191] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[ 5.760721] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 5.768063] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 5.775372] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 5.782725] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 5.790262] usb 2-1: New USB device found, idVendor=0451, idProduct=8140, bcdDevice= 1.00
[ 5.791378] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 5.798460] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.805340] of_cfs_init
[ 5.814773] of_cfs_init: OK
[ 5.817686] hub 2-1:1.0: USB hub found
[ 5.821489] hub 2-1:1.0: 4 ports detected
[ 6.754403] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 6.800952] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 6.810865] Freeing unused kernel memory: 3776K
[ 6.843876] Checked W+X mappings: passed, no W+X pages found
[ 6.849555] Run /init as init process
[ 6.865226] mmc1: new ultra high speed DDR50 SDHC card at address 5048
Loading, please wait...[ 6.872342] mmcblk1: mmc1:5048 SD32G 28.9 GiB
[ 6.879934] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 6.888537] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 6.894961] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 6.901384] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 6.907807] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 6.914230] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 6.920652] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 6.927074] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 6.933496] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 6.939918] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 6.946341] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[ 6.952763] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 6.959185] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 6.965607] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x00e7177f
[ 6.972029] mmc1: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00000900
[ 6.978451] mmc1: sdhci: Host ctl2: 0x0000000c
[ 6.982880] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008944c320c
[ 6.989994] mmc1: sdhci: ============================================
[ 6.999225] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 7.007827] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 7.014250] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 7.020673] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 7.027096] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 7.033518] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 7.039940] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 7.046363] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 7.052785] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 7.059207] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 7.065629] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[ 7.072051] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 7.078474] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 7.084896] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x00e7177f
[ 7.091318] mmc1: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00000900
[ 7.097740] mmc1: sdhci: Host ctl2: 0x0000000c
[ 7.102169] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008944c320c
[ 7.109283] mmc1: sdhci: ============================================
Starting version 247.3-7+deb11u4
[ 7.243136] blk_update_request: I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 7.256029] blk_update_request: I/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 7.268840] blk_update_request: I/O error, dev mmcblk1, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 7.281532] blk_update_request: I/O error, dev mmcblk1, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 7.294647] blk_update_request: I/O error, dev mmcblk1, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 7.307451] blk_update_request: I/O error, dev mmcblk1, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 7.322525] blk_update_request: I/O error, dev mmcblk1, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 7.335511] blk_update_request: I/O error, dev mmcblk1, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 7.345767] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 7.353779] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 7.362387] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 7.368813] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 7.375240] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 7.381665] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 7.388089] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 7.394512] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 7.400938] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 7.407362] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 7.413787] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 7.420211] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 7.426635] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 7.433060] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 7.439483] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 7.445906] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 7.452332] mmc1: sdhci: Host ctl2: 0x0000000c
[ 7.456762] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008944c320c
[ 7.463880] mmc1: sdhci: ============================================
[ 7.472968] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 7.481574] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 7.487999] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 7.494424] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 7.500849] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 7.507273] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 7.513696] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 7.520118] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 7.526540] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 7.532963] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 7.539385] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 7.545807] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 7.552230] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 7.558652] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 7.565074] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 7.571496] mmc1: sdhci: Host ctl2: 0x0000000c
[ 7.575925] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008944c320c
[ 7.583039] mmc1: sdhci: ============================================
[ 7.593820] blk_update_request: I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 7.606713] blk_update_request: I/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 7.629167] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 7.637219] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 7.645822] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 7.652246] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 7.658671] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 7.665097] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 7.671520] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 7.677945] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 7.684371] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 7.690795] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 7.697218] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 7.703642] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 7.710067] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 7.716491] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 7.722917] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 7.729343] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 7.735765] mmc1: sdhci: Host ctl2: 0x0000000c
[ 7.740197] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008944c320c
[ 7.747314] mmc1: sdhci: ============================================
[ 7.756578] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 7.765184] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 7.771610] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 7.778034] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 7.784458] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 7.790883] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 7.797308] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 7.803733] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 7.810157] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 7.816583] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 7.823006] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001
[ 7.829429] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 7.835852] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 7.842274] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 7.848696] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 7.855118] mmc1: sdhci: Host ctl2: 0x0000000c
[ 7.859547] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008944c320c
[ 7.866662] mmc1: sdhci: ============================================
[ 7.886463] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 7.894269] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 7.895195] usb usb1-port1: unable to enumerate USB device
[ 7.907008] mmcblk1: unable to read partition table
[ 8.361503] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 8.370115] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 8.376541] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 8.382967] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 8.389392] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 8.395817] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 8.402243] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 8.408669] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 8.415094] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 8.421517] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 8.427939] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 8.434361] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 8.440784] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 8.447206] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 8.453628] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 8.460050] mmc1: sdhci: Host ctl2: 0x0000000c
[ 8.464479] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008944c320c
[ 8.471593] mmc1: sdhci: ============================================
[ 8.478958] remoteproc remoteproc0: b034000.pru is available
[ 8.481034] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 8.484887] remoteproc remoteproc1: b004000.rtu is available
[ 8.493209] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 8.493211] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 8.493213] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 8.493216] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 8.493219] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 8.498984] remoteproc remoteproc2: b00a000.txpru is available
[ 8.505282] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 8.505284] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 8.505286] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 8.505288] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 8.511842] remoteproc remoteproc3: b038000.pru is available
[ 8.518129] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 8.518131] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 8.518134] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 8.518136] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 8.524705] remoteproc remoteproc4: b006000.rtu is available
[ 8.530978] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 8.530980] mmc1: sdhci: Host ctl2: 0x0000000c
[ 8.530982] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008944c320c
[ 8.530983] mmc1: sdhci: ============================================
[ 8.563435] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 8.568432] remoteproc remoteproc5: b00c000.txpru is available
[ 8.574623] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 8.574626] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 8.574628] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 8.574631] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 8.574633] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 8.574637] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 8.581215] remoteproc remoteproc6: b134000.pru is available
[ 8.587481] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 8.587483] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 8.587485] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 8.587488] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 8.594046] remoteproc remoteproc7: b104000.rtu is available
[ 8.599548] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 8.599550] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 8.599552] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 8.599554] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 8.599556] mmc1: sdhci: Host ctl2: 0x0000000c
[ 8.606122] remoteproc remoteproc8: b10a000.txpru is available
[ 8.610406] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008944c320c
[ 8.610407] mmc1: sdhci: ============================================
[ 8.613184] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 8.617715] remoteproc remoteproc9: b138000.pru is available
[ 8.623956] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 8.623959] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 8.623960] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 8.623962] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 8.623965] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 8.623966] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 8.623969] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 8.632716] remoteproc remoteproc10: b106000.rtu is available
[ 8.638372] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 8.638374] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 8.638375] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 8.638378] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 8.638380] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 8.644931] remoteproc remoteproc11: b10c000.txpru is available
[ 8.651223] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 8.651225] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 8.651227] mmc1: sdhci: Host ctl2: 0x0000000c
[ 8.651230] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008944c320c
[ 8.890668] mmc1: sdhci: ============================================
[ 8.916284] Buffer I/O error on dev mmcblk1, logical block 7572464, async page read
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
[ 8.980032] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 8.988636] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 8.995060] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 9.001483] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 9.007905] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 9.014329] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 9.020751] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 9.027174] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 9.033596] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 9.040018] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 9.046440] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 9.052863] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 9.059285] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 9.065707] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 9.072129] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 9.078551] mmc1: sdhci: Host ctl2: 0x0000000c
[ 9.082980] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008944c320c
[ 9.090094] mmc1: sdhci: ============================================
[ 9.099123] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 9.107713] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 9.114135] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 9.120558] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 9.126980] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 9.133402] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 9.139824] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 9.146246] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 9.152669] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 9.159091] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 9.165513] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 9.171935] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 9.178357] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 9.184779] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 9.191201] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 9.197623] mmc1: sdhci: Host ctl2: 0x0000000c
[ 9.202051] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008944c320c
[ 9.209166] mmc1: sdhci: ============================================
[ 9.233421] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 9.242013] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 9.248435] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 9.254857] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 9.261279] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 9.267702] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 9.274124] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 9.280546] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 9.286968] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 9.293390] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 9.299812] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 9.306234] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 9.312656] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 9.319078] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 9.325501] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 9.331922] mmc1: sdhci: Host ctl2: 0x0000000c
[ 9.336351] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008944c320c
[ 9.343465] mmc1: sdhci: ============================================
[ 9.352414] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 9.361004] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 9.367426] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00001004
[ 9.373848] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 9.380270] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 9.386692] mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001e
[ 9.393114] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 9.399537] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 9.405959] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 9.412380] mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 9.418802] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 9.425224] mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18002407
[ 9.431646] mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 9.438068] mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x47606cc0
[ 9.444490] mmc1: sdhci: Resp[2]: 0x53443332 | Resp[3]: 0x00000900
[ 9.450912] mmc1: sdhci: Host ctl2: 0x0000000c
[ 9.455341] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008944c320c
[ 9.462456] mmc1: sdhci: ============================================
[ 9.486447] Buffer I/O error on dev mmcblk1, logical block 7572464, async page read
done.
Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done.
done.
(initramfs)
Anyway, I will wait. No rush. I am sure you have bigger fish to fry. I just think since booting the Yocto image, I am somehow messing w/ volumes and partitions that were not supposed to be used. Argh.
