FLASHING IMAGES BEAGLEBONE AI-64 [12.7, 12.6, 11.7]
Hi Community.
Im facing a Critical issue with trying to flash the image of the version of BBAI-64 using balena into the sd card, it constanty fails. ive tryed on Windows, linux and mac, more than 5 devices and no success, my colleague is facing exactly the same issue. Is there anyone with the same problem that was able to fix it? could it be a problem with the downloading method or link of the distros?
i’ve done this process successfully serveral times with 11.3 and 11.7 in the past. i got no problems before and i do it with my raspi aswell.
While trying to debug Balena this is the error i get serveral lines of errors that i cant paste bc of lack of space here:
command failed: cmd /c “C:\Users\FABRIC~1.AQU\AppData\Local\Temp\etcher\balena-etcher-electron-978097218a53.cmd”
C:\Users\fabricio.aquije\AppData\Local\Programs\balena-etcher\resources\app\generated\child-writer.js:1
(()=>{var webpack_modules=[,(__unused_webpack_module,exports,webpack_require)=>{“use strict”;Object.defineProperty(exports,“__esModule”,{value:true});const tslib_1=webpack_require(2);tslib_1.__exportStar(webpack_require(3),exports);tslib_1.__exportStar(webpack_require(114),exports);tslib_1.__exportStar(webpack_require(122),exports);tslib_1.__exportStar(webpack_require(118),exports);tslib_1.__exportStar(webpack_require(149),exports);tslib_1.__exportStar(webpack_require(179),exports);tslib_1.__exportStar(webpack_require(180),exports);tslib_1.__exportStar(webpack_require(68),exports);tslib_1.__exportStar(webpack_require(181),exports);tslib_1.__exportStar(webpack_require(234),exports);tslib_1.__exportStar(webpack_require(235),exports);tslib_1.__exportStar(webpack_require(28),exports);tslib_1.__exportStar(webpack_require(236),exports);tslib_1.__exportStar(webpack_require(293),exports);tslib_1.__exportStar(webpack_require(69),exports);tslib_1.__exportStar(webpack_require(121),exports);tslib_1.__exportStar(webpack_require(322),exports);tslib_1.__exportStar(webpack_require(323),exports);tslib_1.__exportStar(webpack_require(324),exports);tslib_1.__exportStar(webpack_require(325),exports);tslib_1.__exportStar(webpack_require(259),exports)},(__unused_webpack_module,webpack_exports,webpack_require)=>{“use strict”;webpack_require.r(webpack_exports);webpack_require.d(webpack_exports,{__assign:()=>__assign,__asyncDelegator:()=>__asyncDelegator,__asyncGenerator:()=>__asyncGenerator,__asyncValues:()=>__asyncValues,__await:()=>__await,__awaiter:()=>__awaiter,__classPrivateFieldGet:()=>__classPrivateFieldGet,__classPrivateFieldIn:()=>__classPrivateFieldIn,__classPrivateFieldSet:()=>__classPrivateFieldSet,__createBinding:()=>__createBinding,__decorate:()=>__decorate,__exportStar:()=>__exportStar,__extends:()=>__extends,__generator:()=>__generator,__importDefault:()=>__importDefault,__importStar:()=>__importStar,__makeTemplateObject:()=>__makeTemplateObject,__metadata:()=>__metadata,__param:()=>__param,__read:()=>__read,__rest:()=>__rest,__spread:()=>__spread,__spreadArray:()=>__spreadArray,__spreadArrays:()=>__spreadArrays,__values:()=>__values});var extendStatics=function(d,b)
Error: Error invoking remote method ‘enable-screensaver’: No handler registered for ‘enable-screensaver’
at o.invoke
Use the raspberry pi-imager, go into custom and select your BB image.
https://downloads.raspberrypi.org/imager/imager_latest.exe
If you have a native ubuntu box install the ubuntu version and use it, windows???
Hi @foxsquirrel , thanks for the reply ive burned the 12.7 XFCE flasher image successfully into the SD card and flashed the emmc but now at the moment of booting. the graphic interface doesnt show up on default, instead it show the bash, ask for me changing the password and doesnt initialize the graphic interface by default. Ive tried with the raspi imager and Rufus, both same results with 2 different computers.
It has an issue with the u-boot config and it hangs on boot randomly, if you have a ttl adapter connected you will see it hangs at a setup menu.
I had a similar problem and fixed it with the following:
sudo systemctl enable lightdm
