Hello all
I have a TFT with 1920x720, and I try to control this with the HDMI from my BBB.
I am trying with cmdline
cmdline=coherent_pool=1M quiet cape_universal=enable video=HDMI-A-1:1920x720M@30e
this disable the hdmi-output
but i think the output is randomly… actually the resolution is 640x480, it seems that my BBB takes the resolution from previous adjustment in the uEnv.txt. But now the resolution that i have adjust is 800x480… and it takes 640?? why
anyway how can I know which resolution works surely?
thanks
i am also trying this, but always “no protocol specified” … i am frustated
root@beaglebone:/# export XAUTHORITY=‘ls /var/run/gdm/auth-for-root-*/database’
root@beaglebone:/# export DISPLAY=:0.0
root@beaglebone:/# xrandr --ouptut HDMI-0 --mode 720x480 --rate 60
xrandr: unrecognized option ‘–ouptut’
Try ‘xrandr --help’ for more information.
root@beaglebone:/# xrandr --output HDMI-0 --mode 720x480 --rate 60
No protocol specified
Can’t open display :0.0
root@beaglebone:/# export DISPLAY=:‘0.0’
root@beaglebone:/# xrandr --output HDMI-0 --mode 1280x800 --rate 60
with raspberry it’s really much simpler!!
=> I was successfully set up the output by simply adding a command"hdmi_cvt=1920 720 60 0 0 0 0" in config.txt
