My Beaglebone White seems to be fried. I have a spare so I popped the
SD card into that one and it works fine. Can I send it in for
replacement?
- Grant
replacement?
- Grant
You should use the RMA form on the on beagleboard.org site. I would post
a link but beagleboard.org seems down right now and cant get the actual
link without the long google search stuff added on. So just google
beagleboard RMA and should be the first result.
HTH
Beagleboard.org is working fine. Follow the process.
The little guy seems to have magically healed himself! Is this sort
of thing fairly common?
- Grant
Unfortunately it has crapped out again in the middle of operation.
I'll submit the RMA form. Out of curiosity, is the Black designed
with higher tolerances?
- Grant
What sort of tolerances? Higher than what?
Not knocking it, just looking for info.
- Grant
Well, I would love to answer you, but I am not sure what you are asking for.
Just wondering if a Black is less likely to die than a White.
- Grant
Same basic design.
Same basic design.
Gmail is coming back with "Connection timed out" after emailing the
RMA. I couldn't submit the form since I use Gmail so I emailed
directly with the email address from the page source.
- Grant
