Hold the shift key down does not seem to work to get to menu to run fsck. Is there a way?
I also note it boots to gui as debian with no password when using with monitor, keyboard and mouse.
This is a feature of GRUB on x86… For us, this feature would have to be implemented in u-boot…
We use lightdm, you can find this autologin enabled in one of two possible locations:
Newer versions:
/etc/lightdm/lightdm.conf.d/<username>.conf
or older images
autologin-user=<username>
/dev/mmcblk1p1 is on the booted sd?
[10.958495] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
/dev/mmcblk1 should be the microSD on the Play…
It’s fat based, so they corrupt easily, Windows/Mac/Linux will auto-mount it… so easy to accidentally set a un-clean removal bit…
should I fsck it and and how?
Something like:
fsck.fat -aw /mmcblk1p1
Thanks!
sudo fsck.fat -aw /dev/mmcblk1p1
fsck.fat 4.2 (2021-01-31)
There are differences between boot sector and its backup.
This is mostly harmless. Differences: (offset:original/backup)
65:01/00
Not automatically fixing this.
Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
Automatically removing dirty bit.
/dev/mmcblk1p1: 94 files, 100222/258078 clusters
