Hello
i have beaglebone black Rev A5C that works correctly with the Serial debug header
yesterday i have bought a new beaglebone black Rev A6A (new BBB) , but when i connect the serial FTDI debugger it didn’t work at all
there is nothing displayed on the host terminal when the new BBB boot up
i have tried to connect TX with RX from the debug header of the new BBB and used minicom on the new BBB using with the following settings :
ttyO0
115200N1
no hardware flow control
and try to write some chars , but nothing received , i think that the FTDI debug header is not connected with the ttyO0 , i think that there is a hardware bug from the BBB factory .
if what i think is true so , i have to redirect the u-boot console output to another tty like ttyO4 , but i don’t know how to do that .
Hello
header
i connect the serial FTDI debugger it didn't work at all
ttyO0
115200N1
Are you certain you've got the hardware still setup properly (cable
plugged in right direction, terminal software configured the same,
etc)?
If you have access to a scope, I suggest monitoring the line.
Do you see the LEDs blink? Have you tried booting off of uSD?
another tty like ttyO4 , but i don't know how to do that .
It might work to specify ttyO4 in the uenv.txt console= command line
argument and add the config enablement to the device tree. If you are
serious about this, I can break down a few of those steps for you. Of
course, that would just move the kernel output, not the u-boot output.
Much of the relevant config info is in:
(It is a bit of an odd legacy that the config is in am335x_evm, but it
was to make the code common with several other boards.)
i am sure the the cable is pluged in in the right way , cause when i connect my old BBB (Rev A5C) with the same cable and same settings it works properly .
so the problem is with my new BBB it self .
if there is a way to change the u-boot console output to ttyO4 this will be great , cause sending back my new BBB will cost me more than buying a new one .
The A6A is an old revision board. We have not made that one for a while. If you just got it, that causes me some concern. Where did you get this board?
one .
You can successfully boot and log in, yes? LEDs blinking and all?
If you are having boot problems, simply start you work from a
known-good image and then work your way into something custom, rather
than starting from an unknown point.
as a first step i try to enable the UART4 from the uEnv.txt and change the console to ttyO4 :
this is my full uEnv.txt :
optargs=quiet drm.debug=7 capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN capemgr.enable_partno=BB-UART4 console=ttyO4,115200n8 mmcargs=setenv bootargs console=${console}
run mmcargs;
there is nothing appear in the terminal .
when the BBB has finished from booting operation , i make ssh connection with it , and check the loaded overlays
cat /sys/devices/bone_capemgr.8/slots
the result is UART4 overlay is loaded correctly , so i don’t know why there is nothing appear in my terminal from the kernel console output
Hello
ttyO0
115200N1
I am having the same problem. Is it solved or the A6A is flawed for serial ftdi by default and requires further to do something?
