On Thu, 28 Feb 2019 03:15:15 -0800 (PST),
erikbozelie@gmail.com declaimed the
following:
debian@beaglebone:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk1 179:0 0 3.6G 0 disk
??mmcblk1p1 179:1 0 3.6G 0 part /
mmcblk1boot0 179:8 0 2M 1 disk
mmcblk1boot1 179:16 0 2M 1 disk
mmcblk1rpmb 179:24 0 128K 0 disk
debian@beaglebone:~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 215M 0 215M 0% /dev
tmpfs 49M 5.5M 43M 12% /run
/dev/mmcblk1p1 3.5G 3.2G 116M 97% /
tmpfs 242M 0 242M 0% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 242M 0 242M 0% /sys/fs/cgroup
tmpfs 49M 4.0K 49M 1% /run/user/1000
Am i doing something wrong?
Well, the LXQT image I have installed shows
debian@beaglebone:~$ uname -a
Linux beaglebone 4.14.49-ti-r54 #1 SMP PREEMPT Fri Jun 15 22:14:13 UTC 2018
armv7l GNU/Linux
mmcblk1 179:0 0 3.7G 0 disk
+-mmcblk1p1 179:1 0 3.7G 0 part /
mmcblk1boot0 179:8 0 1M 1 disk
mmcblk1boot1 179:16 0 1M 1 disk
udev 216M 0 216M 0% /dev
tmpfs 49M 5.2M 44M 11% /run
/dev/mmcblk1p1 3.6G 2.9G 455M 87% /
tmpfs 49M 0 49M 0% /run/user/1000
I'd have expected the IoT build to have more free space than the LXQT.
After all, the compressed download IoT file is half the size of the
download LXQT file. I do note that my eMMC shows up as 3.7G, not 3.6G (so
there's 100M <G>).
No problem running apt-get update/apt-get upgrade on this system.
I've never tried flashing the eMMC using an expanded SD card. If that
is safe, I'd suggest writing the image to the SD card, expand the
partition, do the update/upgrade on the SD card, and THEN convert the card
to flash mode, to update the eMMC -- that might handle the situation where
the initial upgrade needs tons of files (the current cycle I'm running
fetched 102MB -- so upgrading often after the main upgrade may not pull as
many files).
