full-hd support
Hi folks!
I wonder if it possible to drive Full-HD display from the Beagleboard?
The OMAP3530 specification says:
Programmable display size supported:
• XGA - 1024x768 VESA Timings at 60 fps (pixel clock = 63.5 MHz )
• WXGA - 1280x800 VESA timings at 59.91 fps (pixel clock = 71MHz)
• SXGA+ - 1400x1050 Direct drive of LCD with minimal blanking at 50 fps (pixel clock =
75MHz)
• HD 720p - 1280x720 CEA 861-D TIMINGS at 60 fps (pixel clock = 74.25 MHz)
I’m sure that 1024x768 is supported in Angstrom linux which I use for testing (stable branch). However I want to drive 1920x1080 Toshiba TV. Is it possible? Does Angstrom from feeds or stable branch support this resolution?
regards,
Max
Maxim Podbereznyi wrote:
Hi folks!
[snip]
I'm sure that 1024x768 is supported in Angstrom linux which I use for testing (stable branch). However I want to drive 1920x1080 Toshiba TV. Is it possible?
  Not at a sensible frame rate; you can't make your pixel clock fast
enough. The best you can do is 960 x 1080 and horizontally pixel-double
in hardware later on,
  A better question is perhaps why do you want to do this? Your TV
presumably supports 1080i and 720p as well and its scaler will be
better than yours,
R
Maxim Podbereznyi <lisarden@gmail.com> writes:
Hi folks!
~ XGA - 1024x768 VESA Timings at 60 fps (pixel clock = 63.5 MHz )
~ WXGA - 1280x800 VESA timings at 59.91 fps (pixel clock = 71MHz)
~ SXGA+ - 1400x1050 Direct drive of LCD with minimal blanking at 50 fps
(pixel clock =
75MHz)
~ HD 720p - 1280x720 CEA 861-D TIMINGS at 60 fps (pixel clock = 74.25 MHz)
It is possible to do 1920x1080 at 24/25/30Hz.
What parameters should write in bootargs to enable the mode 1920x1080 at 24?
2010/3/13 Måns Rullgård <mans@mansr.com>
omapfb.mode=dvi:1920x1080MR-16@24
More info here: http://elinux.org/BeagleBoardFAQ#Display_resolutions_.231
