Hi all,
Need some help regarding how to use gdb with open ocd for remote debugging a program on beaglebone.
Firstly I followed these link to get started with open ocd!!
http://www.mattlmassey.com/2012/04/26/using-openocd-with-the-beaglebone/
http://elinux.org/Running_OpenOCD_on_Linux_with_the_Beaglebone
And it seems to be worked to get
connect with beaglebone using gdb through open ocd. even able to get connected using telnet!!
following are the steps I’m following>>
1st)
sudo openocd -f board/ti_beaglebone.cfg -c init -c “reset init”
2nd) I can connect to the beaglebone by telnet as
sudo telnet localhost 4444
when I get connected I can halt, resume the cpu and I can see the effect of it on board!!
3rd)I can connect to the beaglebone by gdb as
arm-argo-linux-gnueabi-gdb
4th)On the other side on target beaglebone I’m setting the gdbserver to debug the hello word program as
gdbserver /dev/ttyO0 hello
as I’m not using the ethernet connection for it.
5th)on host side I’m doing this>
i.arm-argo-linux-gnueabi-gdb hello
ii.set sysroot /path/to/copy/of/rootfs
iii.target remote localhost:3333
iv.b main
v.continue
and when I say
continue it says this>>
on host side>>
