root@beaglebone:~# uname -ar
Linux beaglebone 4.9.78-ti-r94 #1 SMP PREEMPT Fri Jan 26 21:26:24 UTC 2018 armv7l GNU/Linux
root@beaglebone:~# lscpu
Architecture: armv7l
Byte Order: Little Endian
CPU(s): 1
On-line CPU(s) list: 0
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 1
Model: 2
Model name: ARMv7 Processor rev 2 (v7l)
CPU max MHz: 1000.0000
CPU min MHz: 300.0000
BogoMIPS: 995.32
Flags: half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpd32
I used the latest image: “Debian 9.5 2018-10-07 4GB SD IoT”
here are the errors when I tried to install gdbserver:
root@beaglebone:~# apt-get install gdbserver
Reading package lists… Done
Building dependency tree
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
gdbserver:i386 : Depends: libc6:i386 (>= 2.15) but it is not going to be installed
ti-opencl : Depends: libtiopencl1 (= 01.01.17.01-git20181129.0-0rcnee0~stretch+20190103) but it is not going to be installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
root@beaglebone:~#
root@beaglebone:~#
root@beaglebone:~# apt --fix-broken install
Correcting dependencies… Done
The following packages were automatically installed and are no longer required:
libgpiod0 libllvm5.0 ti-c6000-cgt-v8.1.x-installer
Use ‘apt autoremove’ to remove them.
The following additional packages will be installed:
libtiopencl1
The following NEW packages will be installed:
libtiopencl1
0 upgraded, 1 newly installed, 0 to remove and 13 not upgraded.
192 not fully installed or removed.
Need to get 3,530 kB of archives.
After this operation, 14.2 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://repos.rcn-ee.com/debian stretch/main armhf libtiopencl1 armhf 01.01.17.01-git20181129.0-0rcnee0~stretch+20190103 [3,530 kB]
Fetched 3,530 kB in 2s (1,712 kB/s)
(Reading database … 74664 files and directories currently installed.)
Preparing to unpack …/libtiopencl1_01.01.17.01-git20181129.0-0rcnee0~stretch+20190103_armhf.deb …
Unpacking libtiopencl1 (01.01.17.01-git20181129.0-0rcnee0~stretch+20190103) …
dpkg: error processing archive /var/cache/apt/archives/libtiopencl1_01.01.17.01-git20181129.0-0rcnee0~stretch+20190103_armhf.deb (–unpack):
trying to overwrite ‘/usr/share/ti/opencl/clc.h’, which is also in package libopencl1 01.01.15.03-r0.0rcnee7~stretch+20180809
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@beaglebone:~#
root@beaglebone:~#
root@beaglebone:~#
Firstly, I didn’t see an “apt update” command in your listing. This updates the package lists and should be executed before installing any packages.
Secondly, there’s a conflict between packages “libopencl1” and “libtiopencl1”. You need to choose one or the other. Remove the other with “apt purge …”.
root@beaglebone:/# apt update
Get:1 http://repos.rcn-ee.com/debian stretch InRelease [3,061 B]
Ign:2 http://deb.debian.org/debian stretch InRelease
Get:3 http://deb.debian.org/debian stretch-updates InRelease [91.0 kB]
Get:4 http://deb.debian.org/debian-security stretch/updates InRelease [94.3 kB]
Hit:5 http://deb.debian.org/debian stretch Release
Get:6 http://repos.rcn-ee.com/debian stretch/main armhf Packages [904 kB]
Get:7 http://deb.debian.org/debian-security stretch/updates/main i386 Packages [601 kB]
Get:8 http://deb.debian.org/debian-security stretch/updates/main amd64 Packages [601 kB]
Fetched 2,294 kB in 7s (314 kB/s)
13 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
root@beaglebone:/# apt purge libtiopencl1
Package ‘libtiopencl1’ is not installed, so not removed
root@beaglebone:/# apt-get install gdbserver
root@beaglebone:/#
root@beaglebone:/# apt purge libopencl1
root@beaglebone:/#
root@beaglebone:/#
root@beaglebone:/# apt --fix-broken install
libtiopencl1
libtiopencl1
Fetched 3,530 kB in 1s (2,803 kB/s)
root@beaglebone:/#
root@beaglebone:/#
root@beaglebone:/#
