Iam using Beagle board rev.C3 as target, connecting with XDS510PPPlus
emulator in CCS4.
now with this one iam able to connect the target to emulator and iam
using given omap3530_cortexA.gel file by disabling auto booting in u-
boot in beagle board with out any errors, but the problem is failed
to load program in memory saying Data Verfication Failed.
But when we checked at given gel file it is mentioned that to use
samsungDDRmemory type, but for beagle board we have micronDDRmemory,
so to use this memory type I need to use a GEL FILE which exactly
matches.
1. If any one has correct GEL File for beagle board, give me the link
or suggest me any change to my GEL FILE which will also work.
2. Another one I think normally Data verfication problem comes with
mapping memory address and loading program correctly to RAM address.
so if any had a cmd file which matches the omap3530 cortexA8 RAM
address in beagle board to load a program with out errors in CCS4.
Hello.
I modify the gel files for CCS3 (http://rapidshare.com/files/362437007/
Ficheros_gel_omap3530.rar.html). Files with the name finished with the
label "OUR" are my modifications.
Hello.
Thanks for this contribution! I hope this helps several people.
I'd recommend putting the original files in something like
gitorious.org and then patching it. I think it would allow people to
get it easier. It'll be on my to-do list to compare this with what is
in CCS and see if these changes should be applied.
Thanks for ur reply, i opened the link u given in ur reply, there iam
unable to open or save the file, it is giving ERROR file not found, so
can u please give me a link other than this link. If possible provide
the link which is not in rapidshare.
