can you help me answering these questions:
Is it possible to use the BBB to do the following operations:
-generate a signal with the PWM modulation
-read 2 analog signals with the ADC converter
-generate an analog signal with a DAC converter
I am new on this board and I would like to understand if it is possible to do those operations!
I saw the features of the Sitara, and it says there is an ADC of 12 bit of resolution, but I cannot understand if it possible to access to it from the BBB. Furthermore I don’t see a DAC, so or I use a PWM as a DAC, or can I link to the BBB an external DAC?
Thank you very much!
Alessandro
