U-Boot SPL 2017.05-rc2 (May 02 2017 - 08:53:40)
Trying to boot from MMC1
** First descriptor is NOT a primary desc on 1:1 **
*** Warning - bad CRC, using default environment
reading u-boot.img
reading u-boot.img
U-Boot 2017.05-rc2 (May 02 2017 - 08:53:40 +0530)
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
<ethaddr> not set. Validating first E-fuse MAC
Net: cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
355 bytes read in 4 ms (85.9 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 ...
Running uenvcmd ...
Booting from microSD ...
reading uImage
10957376 bytes read in 689 ms (15.2 MiB/s)
reading am335x-boneblack.dtb
56827 bytes read in 10 ms (5.4 MiB/s)
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-5.10.162
Created: 2023-09-11 18:16:19 UTC
Data Size: 10957312 Bytes = 10.4 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 88000000
Loading Kernel Image ... OK
Loading Device Tree to 8ffef000, end 8ffffdfa ... OK
Starting kernel ...
2017.05-rc2 and 5.10.162 is probably passing the wrong name in console in your bootargs… in /boot/uEnv.txt and uenvcmd make sure to use the newer ttySx
vs ttyOx
