getty: exit stuck forever
I just flashed my BeagleBone Black (hereafter referred to as BBB) image to the internal eMMC and successfully booted from it.
I modified /boot/uEnv.txt and add kernel param “video=HDMI-A-1:1024x768@60e“ to make my display work.
I connected the HDMI to the BBB and was able to log in. However, I discovered that using the exit command causes the system to freeze.
The issue can be reproduced with both of the following images:
  • am335x-debian-13.2-base-v6.17-armhf-2025-11-18-4gb.img.xz
  • am335x-debian-13.2-base-v6.12-armhf-2025-11-18-4gb.img.xz
I executed systemctl enable --now getty@tty{2,3,4,5,6} to enable login from tty2, tty3, etc.
I first logged in from tty1, then tty2, and then tty3. When I executed exit from tty1, it displayed “logout” and then froze. I could only press Ctrl + Alt + F2 to switch to tty2 and continue operations.
  • Running systemctl status getty@tty1 hangs for a long time and eventually shows “Transport endpoint is not connected.”
  • Executing ps -aux takes a long time before outputting results.
  • The reboot command fails to restart the system; I had to switch to tty3 and execute reboot -f to force a restart.
  • Attempting to log in from tty4 results in a “logout timeout” message.
I have no idea what’s causing this issue. I tried adjusting the cmdline from uEnv.txt, but it didn’t help.
cat /proc/cmdline
console=ttyS0,115200n8 root=/dev/mmcblk1p3 ro rootfstype=ext4 rootwait fsck.repair=yes video=HDMI-A-1:1024x768@60e
By default, this should not even be required to manually force that the alt ttyX’s…
looking at: Transport endpoint is not connected · Issue #36192 · systemd/systemd · GitHub not really helpful, something is failing…
Updated: Successfully tested the am335x-debian-12.12-base-v6.17-armhf-2025-11-18-4gb.img.xz image; getty functionality is confirmed working.
So it’s a systemd bug…
Debian: 12 - (our backport) 254.16-1~bpo12 : repos-armhf/debian-12-systemd/suite/bookworm/debian/changelog at master · beagleboard/repos-armhf · GitHub
Debian 13 - 257.9-1 Debian -- Details of package systemd in trixie
