Going back to Ubuntu 13 dilemma
After trouble getting PWM pins work on Ubuntu 14, I took the advices in this forum to install 13. So I moved BBB back to 13. Got 3.8.13-bone20 kernel. Wanted to upgrade further as suggested by many other posts by doing:
sudo apt-get update
sudo apt-get install linux-3.8.13-bone68
sudo reboot
But “sudo apt-get update” itself would fail as below. Then I realized this was the original reason I moved to Ubuntu 14. Why would the support for Ubuntu 13 be removed so fast when Ubuntu 14 is not yet mature? Working of sudo apt-get update is important for me also to get "sudo apt-get install build-essential python-dev python-setuptools python-pip python-smbus -y " work as required by “http://learn.adafruit.com/downloads/pdf/setting-up-io-python-library-on-beaglebone-black.pdf”. Any help is greatly appreciated.
ubuntu@ubuntu-armhf:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 13.04
Release: 13.04
Codename: raring
ubuntu@ubuntu-armhf:~$ uname -a
Linux ubuntu-armhf 3.8.13-bone20 #1 SMP Wed May 29 06:14:59 UTC 2013 armv7l armv7l armv7l GNU/Linux
ubuntu@ubuntu-armhf:~$ sudo ntpdate pool.ntp.org
[sudo] password for ubuntu:
27 Dec 22:40:59 ntpdate[596]: adjust time server 129.250.35.251 offset -0.003883 sec
ubuntu@ubuntu-armhf:~$ date
Sat Dec 27 22:41:08 UTC 2014
ubuntu@ubuntu-armhf:~$ sudo apt-get update
Ign http://ports.ubuntu.com raring Release.gpg
Ign http://ports.ubuntu.com raring-updates Release.gpg
Ign http://ports.ubuntu.com raring-security Release.gpg
Err http://ports.ubuntu.com raring/main Sources
404 Not Found [IP: 91.189.88.140 80]
Err http://ports.ubuntu.com raring/restricted Sources
Err http://ports.ubuntu.com raring/universe Sources
Err http://ports.ubuntu.com raring/main armhf Packages
Err http://ports.ubuntu.com raring/restricted armhf Packages
Err http://ports.ubuntu.com raring/universe armhf Packages
Ign http://ports.ubuntu.com raring/main Translation-en_US
Ign http://ports.ubuntu.com raring/restricted Translation-en_US
22% [Working]^Cubuntu@ubuntu-armhf:~$
sudo apt-get update
sudo reboot
But "sudo apt-get update" itself would fail as below. Then I realized this
Well first, "ubuntu-armhf" images are not supported by my repo on
rcn-ee.net, talk to "armhf.com".. That's why the above doesn't work..
Well, "Ubuntu 13.04" is so mature, it went EOL a year ago:
http://fridge.ubuntu.com/2014/01/28/ubuntu-13-04-raring-ringtail-end-of-life-reached-on-january-27-2014/
That means it has all the fun "shellshock", "heartbleed", etc's too!!!
Ubuntu only supports a non-lts for up to 9 months after release..
Thus you'll never see me release a non-lts ubuntu release, I'm done
with them. (and there's no point for embedded users)..
Working of
work as required by
"http://learn.adafruit.com/downloads/pdf/setting-up-io-python-library-on-beaglebone-black.pdf"\.
Release: 13.04
Codename: raring
-0.003883 sec
