I'm working on building a "universal" device tree overlay that can be
used to enable and switch between most of the various interesting pin
functions (uart, timers, spi, gpio, pru in/out, etc). One problem is
the BeagleBone specific gpio_of_helper driver designed to make it easy
to export GPIO pins via the device tree is forcing a fixed direction of
input or output on the GPIO pins.
Before I start hacking on the driver, I'm wondering why the pins weren't
either exported with the GPIOF_EXPORT_CHANGEABLE flag set, or why some
provision wasn't made to allow specifying the direction could be changed.
I verified the attached minor patch does what I need and allows the user
to change the GPIO direction after the pin is exported by the
gpio-of-helper driver.
Without this patch, any pins exported to sysfs by the gpio-of-helper
driver are missing the /sys/class/gpio/gpio<N>/direction file and are
stuck in either input or output mode.
Yes, but it's so simple I fear I'm missing something. There are
definitely times when you might not want an I/O pin to change direction,
and other times (like my use) where it's OK.
I think maybe I should add a new property to allow the direction to be
changed, so DT stubs would look something like:
Comments?
Great! It looks so obvious, this makes me wonder why it wasn't
implemented the first time...!
That's what I meant to say. But since modern programmers do not write comments, we'll always keep wondering whether it was a design decision or an oversight. :-/
I have limited knowledge of what you're trying to do, but you probably never want to make gpio3 an output on a BeBoPr because that creates two outputs fighting the signal!
Yep! <sigh>
That's why I added the flag, so it can be left off of I/O pins that
really shouldn't be able to change direction. It still wound up being a
simple 2-line patch. I've tested the change works as expected and have
pushed the patch to my linux-dev github repo:
