Hi I’m starting with BBB and trying to config pins with python and gpiod, I can modify de direction but the bias has no change, I tried LINE_REQ_FLAG_BIAS_DISABLE, LINE_REQ_FLAG_BIAS_PULL_DOWN, LINE_REQ_FLAG_BIAS_PULL_UP.
uname -a Linux BeagleBone 5.10.168-ti-r72 #1bullseye SMP PREEMPT Sat Sep 30 03:37:21 UTC 2023 armv7l GNU/Linux
import gpiod
import time
chip=gpiod.Chip('gpiochip0')
pin = chip.get_line(30)
pin.request(consumer='foobar', type=gpiod.LINE_REQ_DIR_IN, flags=gpiod.LINE_REQ_FLAG_BIAS_PULL_DOWN)
while True:
time.sleep(1)
Connect a 4.7k ohm resistor to the pin and the +3.3v bus.
$ sudo gpiodetect
[sudo] password for fred:
gpiochip0 [30200000.gpio] (32 lines)
gpiochip1 [30210000.gpio] (32 lines)
gpiochip2 [30220000.gpio] (32 lines)
gpiochip3 [30230000.gpio] (32 lines)
gpiochip4 [30240000.gpio] (32 lines)
gpiochip5 [2-0020] (8 lines)
find your pin and note the line and gpiochip
$sudo gpioinfo gpiochip1
gpiochip1 - 32 lines:
line 0: unnamed unused input active-high
line 1: unnamed unused input active-high
line 2: unnamed unused input active-high
line 3: unnamed unused input active-high
line 4: unnamed unused input active-high
line 5: unnamed unused input active-high
line 6: unnamed "scl" output active-high [used open-drain]
line 7: unnamed "sda" input active-high [used]
line 8: unnamed unused output active-high
line 9: unnamed unused output active-high
line 10: unnamed unused input active-high
line 11: unnamed unused input active-high
line 12: unnamed "VSD_VSEL" output active-high [used]
line 13: unnamed unused input active-high
Now, manually toggle the pin using this with your line number and gpiochip<n>
$sudo gpioset gpiochip1 <line number here>=1
$sudo gpioset gpiochip1 <line number here>=0
If you do not see any change you will have to modify the device tree.
When I execute the python file, I can see with gpioinfo the effect
debian@BeagleBone:~$ gpioinfo gpiochip0 | grep 30
line 30: "P9_11 [uart4_rxd]" "foobar" input active-high [used pull-down]
but I measure 3.3V on the pin and show-pins utility shows
debian@BeagleBone:~$ show-pins | grep P9.11
P9.11 28 fast rx up 7 gpio 0.30 << hi foobar (pinmux_P9_11_gpio_pu_pin)
if I use debian@BeagleBone:~$ config-pin P9_11 gpio_pd it works and I can see the change with show-pins command
