GSOC 2016: ScratchX extension for bonescript
Hello BeagleBoard group!
I am Raghav Jajodia, and I have expressed my interest to work on ScratchX extension on the IRC Channel. I talked to Jason Kridner on IRC, but it is becoming difficult to synchronize there. Hence posting here.
Jason: Thanks for your reply for the github suggestion.
But it looks like the Bonescript.js you gave (which had setTargetAddress function) is a client side script. I have added the https support and error handling as you asked, but I couldn’t find this script in the repository (for making pull request). Can you please share the link of this script in the repository?
Raghav
http://beagleboard.org/static/bonescript.js is a reference implementation of setTargetAddress(). It is under a github project at https://github.com/jadonk/bone101/blob/master/static/bonescript.js. It is a client side script, but it is expressly for the purpose of invoking setTargetAddress() to load an ADDITIONAL client side script.
https://github.com/jadonk/bonescript/blob/master/src/bonescript.js is the client side script that setTargetAddress() loads. This one loads socket.io on the client and establishes the connection.
The main routine for the host side script is https://github.com/jadonk/bonescript/blob/master/src/server.js. You’ll see it does a “require(‘…/main’)” to pull in https://github.com/jadonk/bonescript/blob/master/main.js.
The https support is actually required in the server.
Thanks Jason! This is exactly what I needed!
I have created a pull request for this. Please check.
Also, since I don’t have beagleboard with me right now, I tested this script by creating a localhost server on my machine. This works fine, please verify on beagleboard too.
Thanks!
Hello everyone!
I have submitted the draft of my proposal for scratchx extension on the GSOC website. I will be really glad if someone could review it and suggest if any changes should be made.
Jason: Can you please review my proposal?
Here is the link for the proposal :- https://docs.google.com/document/d/1rW9m53AF_YsVHh_zFMaklv0qrdSFmJvGsqo5QBzrC1c/edit?usp=sharing
Thank you for your time.
Raghav Jajodia
raghavjajodia@gmail.com
