I am Ashwin Raut, currently doing my M.S. in Computer Engineering with
specialization in wireless embedded systems.
I have been working on Beagleboard and GNU Radio for almost a year now
but all my work was on two different platforms(USRP and PC for GNU
Radio and Beagleboard as a separate platform).I would like to
integrate these platforms and work on using GNU Radio with
Beagleboard.
I would like to work on using DSP support to run GNU Radio on
Beagleboard.I was able to use DSP link to run a sample calculator
application on Beagleboard(I used DVSDK and Android (rowboat
distribution) to enable DSP link.).Currently my work also consists
of writing a MAC Scheduler on GNU Radio for my Sensor Networks
project.
What i would like to do in GSoC is to run a GNU Radio signal
processing block on DSP.I was thinking of using DSP link to do that.
As i haven't yet enabled GNU Radio on Beagleboard , i am wondering if
there is support for grc when we use GNU Radio on Beagleboard. If
support is present what i would also like to do is run the FFT and
other GRC plots using DSP (as they consume lot of processing power
when used on a normal processor).
But there is one question, in existing support for GNU Radio on
Beagle board what OS is being used on Beagleboard?
Ashwin Raut.
Beagleboard.
project.
I haven't tried grc on the beagle board yet. Hopefully, by the time summer is here, I can make it work on the beagle. You should be able to create flowgraphs using grc on a pc and copy them to the Beagleboard though.
We are using Angstrom to run gnuradio on the Beagleboard. You can build gnuradio on the BeagleBoard. It takes a while to build, but you should be able to compile modified code in a "reasonable" amount of time.
Let us know if you have any more questions.
Thanks for your interest!
Philip
