I've installed Ubuntu Oneiric 11.10 on my BB xM as described here:
http://elinux.org/BeagleBoardUbuntu (using NetIinstall method if it is
matter). In addition, I've installed gst-dsp also as described on the
same page. Everything seams to work fine:
$ uname -a
Linux t3 3.2.3-x4 #1 SMP Sat Feb 4 10:33:25 UTC 2012 armv7l armv7l
armv7l GNU/Linux
$ sudo dsp-test
copied 1000 times successfully
However, attempt to use dsph264enc leads to the following problems:
GST_DEBUG=2 gst-launch v4l2src !
video/x-raw-yuv,width=320,height=240,framerate=25/1 ! ffmpegcolorspace
! video/x-raw-yuv,format=\(fourcc\)UYVY ! dsph264enc ! avimux !
filesink location="ttt.avi"
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
create_node: dsp node allocate failed
0:00:01.412139893 1671 0x115fb8 ERROR dsp
gstdspvenc.c:142:create_node:<dsph264enc0> dsp node allocate failed
sink_setcaps: dsp node creation failed
0:00:01.414367676 1671 0x115fb8 ERROR dsp
gstdspvenc.c:399:sink_setcaps:<dsph264enc0> dsp node creation failed
0:00:01.415283203 1671 0x115fb8 WARN basesrc
gstbasesrc.c:2582:gst_base_src_loop:<v4l2src0> error: Internal data
flow error.
0:00:01.416625977 1671 0x115fb8 WARN basesrc
gstbasesrc.c:2582:gst_base_src_loop:<v4l2src0> error: streaming task
paused, reason not-negotiated (-4)
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Internal data flow error.
Additional debug info:
gstbasesrc.c(2582): gst_base_src_loop ():
streaming task paused, reason not-negotiated (-4)
Execution ended after 420501710 ns.
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
Looking at dmesg, I can see the following relevant messages:
[ 4955.190002] cod_open: error status 0xfffffff7, sz_coff_path:
/lib/dsp/h264venc_sn.dll64P flags: 0x0
[ 4955.302520] procwrap_detach: deprecated dspbridge ioctl
and there is no h264venc_sn.dll64P in /lib/dsp/. Only
h264vdec_sn.dll64P. Could it be the reason for the failure? If yes, I
would appreciate if someone can suggest the proper way to fix it.
I did not want to give up after the first problem
and decide to
try dspmp4venc instead of dsph264enc. Unfortunately it also does not
work. The pipeline runs for several seconds producing correct video
file, but then just stopped on it's own. The following is the complete
output:
GST_DEBUG=2 gst-launch v4l2src do-timestamp=true always-copy=FALSE !
! video/x-raw-yuv,format=\(fourcc\)UYVY ! dspmp4venc ! avimux !
0:00:01.380645752 1693 0x1285d50 WARN bin
gstbin.c:2380:gst_bin_do_latency_func:<pipeline0> did not really
configure latency of 0:00:00.000000000
dsp_thread: failed waiting for events: 5
0:00:08.119049071 1693 0x1267ba8 ERROR dsp
gstdspbase.c:645:dsp_thread:<dspmp4venc0> failed waiting for events: 5
gstdsp_got_error: unable to get event
0:00:08.121093749 1693 0x1267ba8 ERROR dsp
gstdspbase.c:614:gstdsp_got_error:<dspmp4venc0> unable to get event
ERROR: from element /GstPipeline:pipeline0/GstDspMp4VEnc:dspmp4venc0:
unable to get event
Execution ended after 7152709961 ns.
In the dmesg I can see the following:
[ 5298.419525] omap-dsp omap-dsp: bridge_deh_notify: DSP_MMUFAULT,
addr=0x21f3e000
[ 5298.486724] omap-dsp omap-dsp: ERR: clock id 2 already disabled
[ 5298.602966] proc_load: Processor Loaded /lib/dsp/baseimage.dof
[ 5298.615417] proc_start: dsp in running state
So here again I would kindly appreciate any hints how to fix or debug
the problem. I would prefer to use h264 for my project, but can also
leave with mp4 and will appreciate any help.
Thank you,
Andrey.
