I have flashed my BeagleY-AI kit using the bb-imager tool with the image BeagleY-AI Debian 13 v6.1.x-ti XFCE and the kernel version present is 6.1.83-ti-arm64-r72.
I have written and V4L2 driver for my camera sensor and used the CSI0 port. I can able to get the V4L2 stream properly now.
Now my requirement is I need to push the stream to display using GStreamer. I have tried the below command but it has so much latency and throws the below attached logs.
GStreamer command - gst-launch-1.0 v4l2src device=/dev/video1 ! video/x-raw,width=1920,height=1080,format=UYVY ! videoconvert ! autovideosink
Logs - Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Got context from element ‘autovideosink0’: gst.gl.GLDisplay=context, gst.gl.GLDisplay=(GstGLDisplay)“(GstGLDisplayX11)\ gldisplayx11-0”;
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Redistribute latency…
WARNING: from element /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstGLImageSinkBin:autovideosink0-actual-sink-glimage/GstGLImageSink:sink: A lot of buffers are being dropped.
Additional debug info:
../libs/gst/base/gstbasesink.c(3146): gst_base_sink_is_too_late (): /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstGLImageSinkBin:autovideosink0-actual-sink-glimage/GstGLImageSink:sink:
There may be a timestamping problem, or this computer is too slow.
What is the proper GStreamer command to use. Kindly help me with this.
Naveen.
