guvcview -* /dev/video1 and/or another type listed... and mini DP to HDMI cable...
I am late to the party. It seems that the CSI-2 ports to the BBAI-64 have already been accomplished…
Are there specific instances or uses that can be used outside of programming via v4l?
I have been looking loosely for now on specifics. Also…
I have a startech MDP2HDMM1MB cable (mini DP to HDMI). I cannot get a screen showing just yet.
P.S. I guess my plight here is to get video up and running and then try to get that video on the screen via the cable. Anyway, off to search ideas again.
Update
I found decoding needs be done in h.264 and /dev/media0 or /dev/media1 may as well work but my commands are a bit off for now.
Would I need to program to make the codec work or would I need both a command and a script to handle the /dev/media0 file?
I guess a little background would help me. So, I will research some more and try to see if I can get the HDMI to mini DP cable adjusted properly from the BBAI-64 to the Screen w/ this startech cable in the meantime.
update
The cable is passive and not active. Blah.
