I am having trouble using the v4l2h264dec with an RTSP stream on an AI-64.
The v4l2h264 works with all the demos, just not the RTSP stream demo.
Could it be the stream source? I am using a source from a Hikvision DVR. The stream loads when using a standard decodebin, but in the dot file it shows it is using the software decoder. I have also tried using the explicit caps on the video size and decode type etc and it still doesn’t work.
So do you think it is the driver or the stream source. I will still try setup a location local stream source to seeing that fixes it.
Any suggestions will be great.
Thanks.
