Has anyone had any difficulty outputting GPIO,UART, I2C, signals from the BB-X15’s expansion header? I haven’t yet been able to successfully get GPIO and/or UART data to come out on the associated pins of the 4 expansion ports of the am572xEVM/BB-X15. We made a PCBA breakout board which breaks out 30/60 signals on each header.
If you were able to get this working, what were some of the key considerations?
I stumbled across this post on TI E2E, where others were encountering issues with this as well.
https://e2e.ti.com/support/embedded/linux/f/354/p/595855/2206686#pi317016=1
Here I THINK the TI employee indicated that one of the critical steps is specifying the correct offset in the device tree for the pad configuration register of interest. But when I look at the device tree, am57xx-evm-reva3, and the associated included dtsi and dts files, I didn’t see this kind of thing for GPIO pins:
gpio5_pins: pinmux_gpio5_pins {
pinctrl-single,pins = <
DRA7XX_CORE_IOPAD(0xNNNN, (PIN_INPUT | MUX_MODEX))
DRA7XX_CORE_IOPAD(0xNNNN, (PIN_OUTPUT| MUX_MODE3))
in the case of attempting to set GPIO5_8, and using sysfs commands, echo 1,0 > /sys/class/gpio/gpio136/value (after setting the direction to OUT), the value and direction files always jive with what gets echo’d into the file - however the state of the line doesn’t change.
I DO have a modified board.c file, but I’m pretty confident the pinmux in mux_data.h for GPIO5_8 is the same as the development board. Granted this maybe an older revision, as I grabbed one of the earlier revisions of u-boot 2017.01.
I even tried hacking, am57xx-beagle-x15-common.dtsi by adding another phantom LED fragment/cluster.
leds {
led@4 {
label = “gpio_jeff_test”;
gpios = <&gpio5 8 GPIO_ACTIVE_HIGH>;
linux,default-trigger = “ide-disk”;
default-state = “off”;
The good news is, the gpio line is 3.3V with this statement.
The bad news: When I change this to GPIO_ACTIVE_LOW, gpio5_8 is still stuck at 3.3V…
The only luck I’ve had to date is on our custom hardware board, coupling GPIO5_8 with UART5 for the rts line, and then toggle the GPIO line via sysfs commands and by toggling the state of the rtscts flag in Pyserial in Python (This after swapping out the 8250 serial driver for the OMAP driver):
&uart5 {
pinctrl-names = “default”;
pinctrl-0 = <&uart5_pins>;
status = “okay”;
rts-gpio = <&gpio5 8 GPIO_ACTIVE_HIGH>;
rs485-rts-active-high;
rs485-rts-delay = <0 0>;
linux,rs485-enabled-at-boot-time;
Can you maybe provide any clues to steer us in the right direction?
Thanks!!!
Jeff
