Have anybody tried to connect a Nintendo Wii-controller to BeagleBoard?
Hi Everybody,
Without knowing a lot about BT the controller seem to be a standard BT HID device according to:
http://blogs.msdn.com/coding4fun/archive/2007/03/14/1879033.aspx
http://www.sparkfun.com/commerce/tutorial_info.php?tutorials_id=43&page=
a lot of other links can be found by a little searching using Google…
For somebody with a little knowledge of the upper BT layers I think it would be a great/fun task to integrate support for a Wii-controller based mouse or for controlling some simple games using the Wii-controller instead of using a joystick?
In case somebody jumps on the project – Please register it at: http://beagleboard.org/project
Best regards
Søren
I use a PS3 SIXAXIS BlueTooth joystick with my BeagleBoard. I found
instructions for getting the SIXAXIS working on standard Linux, and
followed them to the letter on Angstrom. I had to install the
Angstrom native compile tools, but then the instructions worked on the
first try.
It looks like the same thing should be possible with the Wiimote:
http://abstrakraft.org/cwiid/
Apparently, CWiid is already included in Debian. So if you want to
run Debian on the BeagleBoard, it might be even less work.
- Nathan
This should not be too difficult.
You could look at what I did for eeePC: http://wiki.eeeuser.com/howto:wiimote
There are also a few pages on nslu2-linux that might be useful:
http://www.nslu2-linux.org/wiki/HowTo/ConnectWiimote
http://www.nslu2-linux.org/wiki/HowTo/ConnectWiimoteDebian
Note that you need a sensor bar. You can use the one from your WII,
but it might be more convenient to get a wireless sensor bar (which is
actually not more than a piece of plastic with a few IR leds and maybe
a resistor or 2 and of course a battery compartment).
FM
