HDMI issue with beaglebone AI 64
I updated the debian to the latest one. Following the instructions didn’t work for updating from the version with kernel 5. It ended up using the flash micro SD method. every thing seems to work correcty if I have the 4K monitor on. If not and it is turned on during boot I get a resolution that is slighly better than that of a VIC20.
If I try to use an HDMI monitor instead of the 4K monitor which I don’t want to use because that is the monitor I use for my mac studio, it crashes.
I was trying to figure out why I can’t get a display with gentoo, I guess the problem is not with my gentoo but the video support since I have a video issue with the official debian release.
The monitor in question works perfectly with all my Odroid boards and another beagleboard I tried it on. I tried with the exact adapters suggested on the beagleboard site.
That is a small portable ACER monitor I got from Costco. I bought it recently at the Mishawaka Costco in Indiana.
[ OK ] Started plymouth-start.service - Show Plymouth Boot Screen.
[ OK ] Started systemd-ask-password-plymo…quests to Plymouth Directory Watch.
[ OK ] Reached target cryptsetup.target - Local Encrypted Volumes.
[ OK ] Reached target paths.target - Path Units.
[ OK ] Found device dev-ttyS2.device - /dev/ttyS2.
[ OK ] Found device dev-mmcblk0p2.device - /dev/mmcblk0p2.
Activating swap dev-mmcblk0p2.swap - /dev/mmcblk0p2…
[ OK ] Found device dev-mmcblk0p1.device - /dev/mmcblk0p1.
[ OK ] Activated swap dev-mmcblk0p2.swap - /dev/mmcblk0p2.
[ OK ] Reached target swap.target - Swaps.
Mounting boot-firmware.mount - /boot/firmware…
[ OK ] Mounted boot-firmware.mount - /boot/firmware.
[ OK ] Reached target local-fs.target - Local File Systems.
Starting apparmor.service - Load AppArmor profiles…
Starting console-setup.service - Set console font and keymap…
Starting plymouth-read-write.servi…ymouth To Write Out Runtime Data…
Starting systemd-binfmt.service - Set Up Additional Binary Formats…
Starting systemd-tmpfiles-setup.se…ate System Files and Directories…
Starting ufw.service - Uncomplicated firewall…
[ OK ] Finished plymouth-read-write.servi…Plymouth To Write Out Runtime Data.
[ OK ] Finished ufw.service - Uncomplicated firewall.
[ OK ] Reached target network-pre.target - Preparation for Network.
Starting systemd-networkd.service - Network Configuration…
[ OK ] Finished console-setup.service - Set console font and keymap.
Mounting proc-sys-fs-binfmt_misc.m…cutable File Formats File System…
[ OK ] Mounted proc-sys-fs-binfmt_misc.mo…xecutable File Formats File System.
[ OK ] Finished systemd-tmpfiles-setup.se…reate System Files and Directories.
[ OK ] Finished systemd-binfmt.service - Set Up Additional Binary Formats.
Starting systemd-resolved.service - Network Name Resolution…
Starting systemd-timesyncd.service - Network Time Synchronization…
Starting systemd-update-utmp.servi…ord System Boot/Shutdown in UTMP…
[ OK ] Finished systemd-update-utmp.servi…ecord System Boot/Shutdown in UTMP.
[ OK ] Finished apparmor.service - Load AppArmor profiles.
Starting networking.service - Raise network interfaces…
[ OK ] Finished networking.service - Raise network interfaces.
[ OK ] Started systemd-networkd.service - Network Configuration.
[ OK ] Started systemd-timesyncd.service - Network Time Synchronization.
[ OK ] Reached target time-set.target - System Time Set.
[ OK ] Started systemd-resolved.service - Network Name Resolution.
[ OK ] Reached target nss-lookup.target - Host and Network Name Lookups.
[ OK ] Reached target sysinit.target - System Initialization.
[ OK ] Started apt-daily.timer - Daily apt download activities.
[ OK ] Started apt-daily-upgrade.timer - …y apt upgrade and clean activities.
[ OK ] Started dpkg-db-backup.timer - Daily dpkg database backup timer.
[ OK ] Started e2scrub_all.timer - Period…Metadata Check for All Filesystems.
[ OK ] Started fstrim.timer - Discard unused blocks once a week.
[ OK ] Started logrotate.timer - Daily rotation of log files.
[ OK ] Started systemd-tmpfiles-clean.tim…y Cleanup of Temporary Directories.
[ OK ] Reached target timers.target - Timer Units.
[ OK ] Listening on avahi-daemon.socket -…DNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on dbus.socket - D-Bus System Message Bus Socket.
Starting docker.socket - Docker Socket for the API…
[ OK ] Listening on gpsd.socket - GPS (Gl…Positioning System) Daemon Sockets.
[ OK ] Listening on docker.socket - Docker Socket for the API.
[ OK ] Reached target sockets.target - Socket Units.
[ OK ] Reached target basic.target - Basic System.
Starting avahi-daemon.service - Avahi mDNS/DNS-SD Stack…
Starting bb-symlinks.service - BeagleBoard Generate Symlinks…
Starting bb-usb-gadgets.service - BeagleBoard.org USB gadgets…
Starting bbbio-set-sysconf.service…oard Set up system configuration…
Starting beagle-camera-setup.service - BeagleBoard Camera Setup…
[ OK ] Started cron.service - Regular background program processing daemon.
Starting dbus.service - D-Bus System Message Bus…
Starting e2scrub_reap.service - Re…ne ext4 Metadata Check Snapshots…
Starting iwd.service - Wireless service…
[ OK ] Started mender-client.service - Mender OTA update service.
Starting systemd-logind.service - User Login Management…
Starting udisks2.service - Disk Manager…
[ OK ] Finished beagle-camera-setup.service - BeagleBoard Camera Setup.
[ OK ] Started dbus.service - D-Bus System Message Bus.
[ OK ] Finished bb-symlinks.service - BeagleBoard Generate Symlinks.
[ OK ] Started avahi-daemon.service - Avahi mDNS/DNS-SD Stack.
[ 6.597609] bbbio-set-sysconf[384]: Reading the system configuration settings from /boot/firmware/sysconf.txt
[ OK ] Finished e2scrub_reap.service - Re…line ext4 Metadata Check Snapshots.
[ OK ] Finished bbbio-set-sysconf.service…eBoard Set up system configuration.
Starting polkit.service - Authorization Manager…
[ OK ] Started iwd.service - Wireless service.
[ OK ] Reached target network.target - Network.
[ OK ] Reached target network-online.target - Network is Online.
Starting code-server@michel.service - code-server…
Starting containerd.service - containerd container runtime…
Starting nginx.service - A high pe…erver and a reverse proxy server…
Starting ssh.service - OpenBSD Secure Shell server…
Starting systemd-user-sessions.service - Permit User Sessions…
[ OK ] Started polkit.service - Authorization Manager.
[ 7.015625] remoteproc remoteproc0: request_firmware failed: -2
[ 7.021047] remoteproc remoteproc1: request_firmware failed: -2
[ 7.081608] remoteproc remoteproc2: request_firmware failed: -2
[ OK ] Started code-server@michel.service - code-server.
[ OK ] Started systemd-logind.service - User Login Management.
[ OK ] Finished systemd-user-sessions.service - Permit User Sessions.
[ OK ] Reached target usb-gadget.target - Hardware activated USB gadget.
Starting lightdm.service - Light Display Manager…
Starting plymouth-quit-wait.servic…d until boot process finishes up…
[ OK ] Started unattended-upgrades.service - Unattended Upgrades Shutdown.
[ OK ] Started ssh.service - OpenBSD Secure Shell server.
[ OK ] Started nginx.service - A high per… server and a reverse proxy server.
[ 7.403281] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
[ OK ] Started udisks2.service - Disk Manager.
[ 8.156478] remoteproc remoteproc4: request_firmware failed: -2
[ 10.183392] k3_r5_rproc bus@100000:r5fss@5c00000: Timed out waiting for 5c00000.r5f core to power up!
[ 10.256280] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -110
[ 10.688171] platform 5e00000.r5f: configured R5F for remoteproc mode
[ 10.690891] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[ 10.692651] remoteproc remoteproc17: 5e00000.r5f is available
[ 10.692811] remoteproc remoteproc17: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[ 10.692821] remoteproc remoteproc17: powering up 5e00000.r5f
[ 10.692841] remoteproc remoteproc17: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[ 10.692846] remoteproc remoteproc17: request_firmware failed: -2
[ 12.276066] cdns-mhdp8546 a000000.dp-bridge: Failed to read register
[ 12.276078] cdns-mhdp8546 a000000.dp-bridge: Failed to read CDNS_DPTX_CAR -110
[ 12.276183] Console: switching to colour frame buffer device 80x30
[ 12.276318] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000170
[ 12.276323] Mem abort info:
[ 12.276324] ESR = 0x0000000096000006
[ 12.276327] EC = 0x25: DABT (current EL), IL = 32 bits
[ 12.276329] SET = 0, FnV = 0
[ 12.276331] EA = 0, S1PTW = 0
[ 12.276333] FSC = 0x06: level 2 translation fault
[ 12.276335] Data abort info:
[ 12.276336] ISV = 0, ISS = 0x00000006, ISS2 = 0x00000000
[ 12.276338] CM = 0, WnR = 0, TnD = 0, TagAccess = 0
[ 12.276340] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
[ 12.276343] user pgtable: 4k pages, 48-bit VAs, pgdp=000000089ac5f000
[ 12.276347] [0000000000000170] pgd=080000089439a003, p4d=080000089439a003, pud=080000089aec7003, pmd=0000000000000000
[ 12.276358] Internal error: Oops: 0000000096000006 [#1] SMP
[ 12.276363] Modules linked in: xt_conntrack nft_chain_nat xt_MASQUERADE nf_nat nf_conntrack_netlink nf_conntrack irq_pruss_intc pru_rproc nf_defrag_ipv6 nf_defrag_ipv4 ti_am335x_adc xfrm_user xfrm_algo xt_addrtype nft_compat nf_tables nfnetlink br_netfilter bridge stp llc crct10dif_ce joydev ti_k3_r5_remoteproc(+) at24 vxe_enc vxd_dec videobuf2_dma_contig v4l2_mem2mem ti_am335x_tscadc videobuf2_dma_sg pruss videobuf2_memops videobuf2_v4l2 videodev videobuf2_common mc ti_k3_dsp_remoteproc algif_aead rti_wdt optee_rng cfg80211 efi_pstore loop dm_mod
[ 12.276440] CPU: 0 PID: 72 Comm: kworker/0:3 Not tainted 6.6.32-ti-arm64-r10 #1
[ 12.276446] Hardware name: BeagleBoard.org BeagleBone AI-64 (DT)
[ 12.276449] Workqueue: events cdns_mhdp_modeset_retry_fn
[ 12.276468] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=–)
[ 12.276473] pc : mutex_lock+0x4c/0x88
[ 12.276482] lr : mutex_lock+0x20/0x88
[ 12.276486] sp : ffff8000829b3d70
[ 12.276488] x29: ffff8000829b3d70 x28: 0000000000000000 x27: 0000000000000000
[ 12.276494] x26: ffff00087f78d828 x25: ffff000801a84680 x24: ffff000800116c05
[ 12.276500] x23: ffff00080291dcb0 x22: ffff00087f78d800 x21: ffff000800116c00
[ 12.276506] x20: ffff00080291d0f8 x19: 0000000000000170 x18: ffffffffffffffff
[ 12.276511] x17: ffff8007fddcb000 x16: 0000000000000020 x15: 0000000000000000
[ 12.276517] x14: 0000000000000000 x13: 0000000000000030 x12: 0101010101010101
[ 12.276523] x11: 7f7f7f7f7f7f7f7f x10: fefefefefefefeff x9 : ffff80008126cda0
[ 12.276529] x8 : 8080808080808080 x7 : ffff000801a84680 x6 : 8080000000000000
[ 12.276534] x5 : ffff00087f77cd08 x4 : ffff00080291dcb0 x3 : ffff00087f78d828
[ 12.276540] x2 : 0000000000000000 x1 : ffff000800d7d000 x0 : 0000000000000000
[ 12.276545] Call trace:
[ 12.276548] mutex_lock+0x4c/0x88
[ 12.276553] cdns_mhdp_modeset_retry_fn+0x2c/0x68
[ 12.276558] process_one_work+0x174/0x3d8
[ 12.276564] worker_thread+0x2b8/0x3d8
[ 12.276567] kthread+0x11c/0x128
[ 12.276572] ret_from_fork+0x10/0x20
[ 12.276580] Code: d50323bf d65f03c0 d2800002 f9800271 (c85ffe60)
[ 12.276585] —[ end trace 0000000000000000 ]—
[ 12.675401] tidss 4a00000.dss: [drm] fb0: tidssdrmfb frame buffer device
[ 12.734997] k3_r5_rproc bus@100000:r5fss@5e00000: Timed out waiting for 5e00000.r5f core to power up!
[ 12.956258] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 12.982310] configfs-gadget.g_multi gadget.0: HOST MAC 1c:ba:8c:a2:ed:6a
[ 12.989144] configfs-gadget.g_multi gadget.0: MAC 1c:ba:8c:a2:ed:6b
[ 12.996129] configfs-gadget.g_multi gadget.0: HOST MAC 1c:ba:8c:a2:ed:6c
[ 13.002974] configfs-gadget.g_multi gadget.0: MAC 1c:ba:8c:a2:ed:6d
Oh my, I had one of those.
