Hi everybody,
for a university project I’m using a bbb with Linux 3.8.13 bone49, for a couple of months I was acquiring analog input using the internal adc of the beaglebone and the pruss, using as a starting point Derek Molloy’s example (exploringbeaglebone/chapter13) and ADCCollector.c /ADCCollector.p files, basically I sample the signal at tevery front end of a pru clock with a fixed frequency.
Before running my program I always load the two overlays EBB-PRU-Example.dtbo and BB-ADC.dtbo and modprobe uio_pruss.
I’ve no idea what’s happened yesterday night but today I’m not able anymore to get coerents values from the ADC (AIN0 and ground), with a positive sinusoid of 1 V module I’m getting values that after the conversion (*1.8/4095) are around 11 V. The code has not being modified andI’m 100% that strangely enough the problem is not in the prus overlay, since I’m monitoring the ‘sampling-clock’ using an oscilloscope.
Any idea about what is going on?
I’ve rebooted and resetted the bbb, removed and loaded the overlays, I don’t have the /sys/devices/platform/tsc directory and doing:
cat: /sys/bus/iio/devices/iio:device0/in_voltage: No such file or directory.
dmesg:
root@arm:/home/debian# dmesg
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.8.13-bone49 (root@imx6q-wandboard-2gb-0) (gcc ver sion 4.6.3 (Debian 4.6.3-14) ) #1 SMP Fri May 2 06:36:13 UTC 2014
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache
[ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 130816
[ 0.000000] free_area_init_node: node 0, pgdat c0828540, node_mem_map c08a300 0
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 129792 pages, LIFO batch:31
[ 0.000000] AM335X ES1.0 (neon )
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c0cb3000 s14080 r8192 d14592 u36864
[ 0.000000] pcpu-alloc: s14080 r8192 d14592 u36864 alloc=9*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 129792
[ 0.000000] Kernel command line: console=ttyO0,115200n8 capemgr.disable_partn o=BB-BONELT-HDMI,BB-BONELT-HDMIN,BB-SPI01-01 root=UUID=df5f218f-c512-4a0a-84fd-9 224c752d1e9 ro rootfstype=ext4 rootwait fixrtc ip= quiet init=/lib/systemd/syste md
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memor y cgroups
[ 0.000000] Memory: 511MB = 511MB total
[ 0.000000] Memory: 506200k/506200k available, 18088k reserved, 0K highmem
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf800000 - 0xbfe00000 ( 6 MB)
.text : 0xc0008000 - 0xc0766d14 (7548 kB)
.init : 0xc0767000 - 0xc07a2700 ( 238 kB)
.data : 0xc07a4000 - 0xc082b500 ( 542 kB)
.bss : 0xc082b500 - 0xc08a2c40 ( 478 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:0 nr_irqs:0 0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrup ts
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 17895 6ms
[ 0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000243] Calibrating delay loop… 993.47 BogoMIPS (lpj=969728)
[ 0.029175] pid_max: default: 32768 minimum: 301
[ 0.029320] Security Framework initialized
[ 0.029380] Mount-cache hash table entries: 512
[ 0.035641] Initializing cgroup subsys cpuacct
[ 0.035665] Initializing cgroup subsys memory
[ 0.035706] Initializing cgroup subsys blkio
[ 0.035796] CPU: Testing write buffer coherency: ok
[ 0.036189] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.036244] Setting up static identity map for 0x8045fa10 - 0x8045fa5c
[ 0.037283] Brought up 1 CPUs
[ 0.037298] SMP: Total of 1 processors activated (993.47 BogoMIPS).
[ 0.038030] devtmpfs: initialized
[ 0.047076] omap_hwmod: wd_timer2: _wait_target_disable failed
[ 0.099319] pinctrl core: initialized pinctrl subsystem
[ 0.099457] rstctl core: initialized rstctl subsystem
[ 0.099803] regulator-dummy: no parameters
[ 0.100133] NET: Registered protocol family 16
[ 0.100751] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.106496] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.107087] platform 49000000.edma: alias fck already exists
[ 0.107105] platform 49000000.edma: alias fck already exists
[ 0.107119] platform 49000000.edma: alias fck already exists
[ 0.107811] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[ 0.107910] OMAP GPIO hardware version 0.1
[ 0.108769] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[ 0.109538] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[ 0.110288] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[ 0.110557] of_get_named_gpio_flags exited with status 52
[ 0.110575] gpio-rctrl rstctl.4: loaded OK
[ 0.113972] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.115282] cpsw.0: No hwaddr in dt. Using 90:59:af:54:90:40 from efuse
[ 0.115301] cpsw.1: No hwaddr in dt. Using 90:59:af:54:90:42 from efuse
[ 0.124084] bio: create slab at 0
[ 0.130879] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.131032] of_get_named_gpio_flags: can’t parse gpios property
[ 0.131160] vmmcsd_fixed: 3300 mV
[ 0.132814] SCSI subsystem initialized
[ 0.133065] usbcore: registered new interface driver usbfs
[ 0.133130] usbcore: registered new interface driver hub
[ 0.133334] usbcore: registered new device driver usb
[ 0.134585] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.135577] input: tps65217_pwr_but as /devices/ocp.3/44e0b000.i2c/i2c-0/0-00 24/input/input0
[ 0.137223] DCDC1: at 1500 mV
[ 0.138070] vdd_mpu: 925 <–> 1325 mV at 1325 mV
[ 0.138944] vdd_core: 925 <–> 1150 mV at 1125 mV
[ 0.139769] LDO1: at 1800 mV
[ 0.140624] LDO2: at 3300 mV
[ 0.142142] LDO3: 1800 mV
[ 0.143017] LDO4: at 3300 mV
[ 0.143750] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.144210] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.144753] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.146165] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.146309] media: Linux media interface: v0.10
[ 0.146442] Linux video capture interface: v2.00
[ 0.146521] pps_core: LinuxPPS API ver. 1 registered
