Help! BBB show 3 solid LED after flashing
hi everyone.
i am having a serious problem, i had the BBB all setup and running using a keyboard mouse and hdmi monitor. it worked fine, then i decided i wanted to update using the instructions found here.
i then downloaded 12.04 LTS from here and completed the install/flash successfully as per the instructions. when i rebooted as per the link, nothing appears and I get 3 solid LEDs. after waiting a few minutes with no response, i removed the SD card and tried to reboot it to the onboard image, but the same thing has happened. 3 solid LEDs.
what am i doing wrong and how do i fix this?
i am on a mac and have all the drivers setup.
thanks for any help
jason
idk... Use an image that's actually supported?
http://elinux.org/BeagleBoardUbuntu#eMMC:_BeagleBone_Black
Just make sure to hold down the "microSD" boot button as it sounds
like you may have corrupted the bootloader..
