So i have this very odd problem with my Beagle Board xM. I'm using the
demo/SD card that comes with the beagle board kit.
It has issue where initially it restarts continually for about a
minute trying to do the same thing. After that it gets to a point
where it says it its done booting Linux and it starts restarting
again.Finally, maybe 5 min later is starting booting the kernel and it
get the to the point below. After that it just keep and restarting and
doing the same thing. It seems really wierd that without me doing
anything it keep on restarting a little bit more and then it gets to
the final point shown below.
How are you powering the board? Via USB or the 5V plug? If its by USB, that’s known the cause various issues if it can’t supply enough power to the board.
try using a power supply which can supply minimum 1A. And unplug any USB
devices on the BB.
1 amp is borderline. Any PSU should really be capable of 2 amps or more.
Dave
> that's known the cause various issues if it can't supply enough power to
the
> board.
> -Michael
>> Hi Everyone,
>> Thanks for any help!
>> Dmitry
>> OUTPUT:
>> Texas Instruments X-Loader 1.5.0 (Mar 27 2011 - 17:37:56)
>> Beagle xM
>> Reading boot sector
>> Loading u-boot.bin from mmc
>> U-Boot 2011.03-rc1-00000-g9a3cc57-dirty (Apr 01 2011 - 17:41:42)
>> OMAP3630/3730-GP ES2.1, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
>> OMAP3 Beagle board + LPDDR/NAND
>> I2C: ready
>> DRAM: 512 MiB
>> NAND: 0 MiB
>> MMC: OMAP SD/MMC: 0
>> *** Warning - readenv() failed, using default environment
>> In: serial
>> Out: serial
>> Err: serial
>> Beagle xM Rev C
>> No EEPROM on expansion board
>> Die ID #6b4200029ff800000160a74506026016
>> Hit any key to stop autoboot: 0
>> The user button is currently NOT pressed.
>> SD/MMC found on device 0
>> reading uEnv.txt
>> 134 bytes read
>> Loaded environment from uEnv.txt
>> Importing environment from mmc ...
>> Loading file "/boot/uImage" from mmc device 0:2 (xxa2)
>> 3194256 bytes read
>> Booting from mmc ...
>> ## Booting kernel from Legacy Image at 80200000 ...
>> Image Name: Angstrom/2.6.32/beagleboard
>> Image Type: ARM Linux Kernel Image (uncompressed)
>> Data Size: 3194192 Bytes = 3 MiB
>> Load Address: 80008000
>> Entry Point: 80008000
>> Verifying Checksum ... OK
>> Loading Kernel Image ... OK
>> OK
>> Starting kernel ...
>> Uncompressing
that's known the cause various issues if it can't supply enough power to the
board.
-Michael
I've had several of this sort of power supply that can no longer supply
its rated maximum current; so, if you /are/ already using an external
supply, try swapping it for another.
Thanks for the replay guys, I'm powering it by a 5V 2A Linsys power
adapter. I was hoping that would be enough, but I'll try another one
to see if it makes a difference.
Alright I have it all figured out. All it was is a power supply issue
as you guys had suggested. The power brick was providing 5.13 V which
i guess it too much for the system, which was causing it to reset at
random times. As soon as I switched to running it on a USB phone
charger it started working perfectly.
