help on EAGLEBOARD+ANGSTROM+QT+OPENGL
Hello. I hope i write to the address. I need help with configuring
BEAGLEBOARD+ANGSTROM+QT+OPENGL
i have error message when trying to configure qt 4.7.3:
opengl functionality test failed!
i am using image by narcissus form angstrom-distribution.org.
parameters:
opkg list-installed "libgles*"
libgles-omap3 - 4.03.00.02-r15.6
libgles-omap3-blitwsegl - 4.03.00.02-r15.6
libgles-omap3-dev - 4.03.00.02-r15.6
libgles-omap3-flipwsegl - 4.03.00.02-r15.6
libgles-omap3-frontwsegl - 4.03.00.02-r15.6
libgles-omap3-linuxfbwsegl - 4.03.00.02-r15.6
libgles-omap3-rawdemos - 4.03.00.02-r15.6
libgles-omap3-x11demos - 4.03.00.02-r15.6
libgles-omap3-x11wsegl - 4.03.00.02-r15.6
configure command:
./configure -embedded arm -xplatform /qws/linux-arm-g++ -fast -opengl
es2 -plugin-gfx-powervr -opensource -confirm-license
qmake.conf file content:
include(../../common/qws.conf)
# modifications to g++.conf
QMAKE_CFLAGS_RELEASE = -O3 -march=armv7-a -mtune=cortex-a8
-mfpu=neon -mfloat-abi=softfp
QMAKE_CXXFLAGS_RELEASE = $$QMAKE_CFLAGS_RELEASE
QMAKE_CC = arm-angstrom-linux-gnueabi-gcc
QMAKE_CXX = arm-angstrom-linux-gnueabi-g++
QMAKE_LINK = arm-angstrom-linux-gnueabi-g++
QMAKE_LINK_SHLIB = arm-angstrom-linux-gnueabi-g++
# modifications to linux.conf
QMAKE_INCDIR = /usr/include
QMAKE_LIBDIR = /usr/lib
QMAKE_LIBS_EGL = -lEGL -lIMGegl -lsrv_um
QMAKE_LIBS_OPENGL_QT = -lEGL -lGLESv2 -lGLES_CM -lIMGegl -lsrv_um
QMAKE_LIBS_OPENVG = -lEGL -lGLESv2 -lGLES_CM -lIMGegl -lsrv_um
-lOpenVG -lOpenVGU
QMAKE_AR = arm-angstrom-linux-gnueabi-ar cqs
QMAKE_OBJCOPY = arm-angstrom-linux-gnueabi-objcopy
QMAKE_STRIP = arm-angstrom-linux-gnueabi-strip
#These defines are documented in the powervr README, please read it
DEFINES += QT_QWS_CLIENTBLIT QT_NO_QWS_CURSOR
load(qt_config)
what am I doing wrong??? thanks for any info
You're not using the prebuilt qt in angstrom that already have opengl enabled for beagle
Hello, Koen.
i am torturing Narcissus for already a month! i tried all precompiled
toolchains. they compile QT applications, but they don't have opengl
support. toolchains compiled by me and Narcissus don't want to run
correctly at all. I already compiled about a hundred images with
Narcissus. It means I'am doing something wrong. can you compile one
image and give me a link? or give an advice. I learned all topics on
my theme. But it was useless. I already have my working QT
application. but without OPENGL part, which is very important. I
almost despaired
thanks for any info.
