Hi everyone,
I forked the Edge AI Image Builder project and successfully built it locally using Docker — everything worked perfectly on my machine.
However, when I set up my own Docker runner in GitLab CI/CD, the pipeline consistently fails during the step “Building EdgeAI Apps Utils for Linux.”
I’m still new to GitLab Docker CI/CD, so I might be missing something in the runner configuration.
Does anyone know if the configuration for the docker-amd64-bigmem runner is publicly available?
It seems like I might be missing some environment setup in my Docker configuration.
I’ve attached the build logs and my runner configuration files for reference.
Thanks in advance for any help or tips!
cd /home/tisdk/ti-processor-sdk-rtos-j722s-evm-11_00_00_06/edgeai/edgeai-apps-utils/; \
mkdir -p LINUX/build; \
cd LINUX/build; \
CROSS_COMPILER_PATH=/home/tisdk/ti-processor-sdk-rtos-j722s-evm-11_00_00_06/toolchain/sysroots/x86_64-arago-linux/usr \
CROSS_COMPILER_PREFIX=aarch64-oe-linux- \
TARGET_FS=/home/tisdk/ti-processor-sdk-rtos-j722s-evm-11_00_00_06/targetfs/ \
TARGET_OS=LINUX \
cmake -DCMAKE_OUTPUT_DIR=/home/tisdk/ti-processor-sdk-rtos-j722s-evm-11_00_00_06/edgeai/edgeai-apps-utils//LINUX \
-DCMAKE_TOOLCHAIN_FILE=../../cmake/cross_compile_aarch64.cmake ../../; \
make install DESTDIR=/home/tisdk/ti-processor-sdk-rtos-j722s-evm-11_00_00_06/edgeai/LINUX
-- The C compiler identification is GNU 13.3.0
-- The CXX compiler identification is GNU 13.3.0
-- Detecting C compiler ABI info
CMake Error: Generator: execution of make failed. Make command was: /home/tisdk/ti-processor-sdk-rtos-j722s-evm-11_00_00_06/targetfs/usr/bin/make -f Makefile cmTC_a8e16/fast &&
-- Detecting C compiler ABI info - failed
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
CMake Error: Generator: execution of make failed. Make command was: /home/tisdk/ti-processor-sdk-rtos-j722s-evm-11_00_00_06/targetfs/usr/bin/make -f Makefile cmTC_5d40e/fast &&
-- Detecting CXX compiler ABI info - failed
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Warning (dev) at /usr/share/cmake-3.22/Modules/GNUInstallDirs.cmake:239 (message):
Unable to determine default CMAKE_INSTALL_LIBDIR directory because no
target architecture is known. Please enable at least one language before
including GNUInstallDirs.
Call Stack (most recent call first):
cmake/common.cmake:1 (include)
CMakeLists.txt:7 (include)
This warning is for project developers. Use -Wno-dev to suppress it.
-- CMAKE_BUILD_TYPE = Release PROJECT_NAME = edgeai-apps-utils
SOC=j722s
TARGET_CPU=A53
-- Configuring incomplete, errors occurred!
See also "/home/tisdk/ti-processor-sdk-rtos-j722s-evm-11_00_00_06/edgeai/edgeai-apps-utils/LINUX/build/CMakeFiles/CMakeOutput.log".
See also "/home/tisdk/ti-processor-sdk-rtos-j722s-evm-11_00_00_06/edgeai/edgeai-apps-utils/LINUX/build/CMakeFiles/CMakeError.log".
make[5]: Entering directory '/home/tisdk/ti-processor-sdk-rtos-j722s-evm-11_00_00_06/edgeai/edgeai-apps-utils/LINUX/build'
CMake Error: The source directory "/home/dockeruser/psdk_installer_build_top_workarea/scratch_workarea/ti-processor-sdk-rtos-j722s-evm-11_00_00_06/edgeai/edgeai-apps-utils" does not exist.
Specify --help for usage, or press the help button on the CMake GUI.
make[5]: *** [Makefile:417: cmake_check_build_system] Error 1
make[5]: Leaving directory '/home/tisdk/ti-processor-sdk-rtos-j722s-evm-11_00_00_06/edgeai/edgeai-apps-utils/LINUX/build'
make[4]: *** [makerules/makefile_edgeai.mak:43: edgeai_utils] Error 2
make[4]: Leaving directory '/home/tisdk/ti-processor-sdk-rtos-j722s-evm-11_00_00_06/sdk_builder'
make[3]: *** [makerules/makefile_edgeai.mak:31: edgeai] Error 2
make[3]: Leaving directory '/home/tisdk/ti-processor-sdk-rtos-j722s-evm-11_00_00_06/sdk_builder'
make[2]: *** [makerules/makefile_vision_apps.mak:15: edgeai_deps] Error 2
make[2]: Leaving directory '/home/tisdk/ti-processor-sdk-rtos-j722s-evm-11_00_00_06/sdk_builder'
make[1]: *** [Makefile:64: sdk] Error 2
make[1]: Leaving directory '/home/tisdk/ti-processor-sdk-rtos-j722s-evm-11_00_00_06/sdk_builder'
make: *** [makerules/makefile_linux_arm.mak:382: firmware] Error 2
config.toml:
concurrent = 1
check_interval = 0
connection_max_age = “15m0s”
shutdown_timeout = 0[session_server]
session_timeout = 1800[[runners]]
name = “HOST-02”
url = “https://gitlab.com/”
id = 50028444
token = “xxxxxxx”
token_obtained_at = 2025-10-04T12:21:53Z
token_expires_at = 0001-01-01T00:00:00Z
executor = “docker”
[runners.cache]
MaxUploadedArchiveSize = 0
[runners.cache.s3]
[runners.cache.gcs]
[runners.cache.azure]
[runners.docker]
tls_verify = false
image = “robertcnelson/ti-ubuntu:latest”
privileged = false
disable_entrypoint_overwrite = false
oom_kill_disable = false
disable_cache = false
volumes = [“/cache”]
shm_size = 0
network_mtu = 0build_log.txt (1.8 MB)
