Help with Perl serial communication
Here is my code
use Device::SerialPort;
my $port=Device::SerialPort->new("/dev/ttyO1");
$port->baudrate(9600);
$port->databits(8);
$port->parity(“none”);
$port->stopbits(1);
$port->write(“Hello”);
exit;
When I run the code I get this error
Can’t locate Device/SerialPort.pm in @INC (@INC contains: /etc/perl /usr/lib/perl/site_perl/5.14.2/ /usr/lib/perl/site_perl/5.14.2 /usr/lib/perl/vendor_perl/5.14.2/ /usr/lib/perl/vendor_perl/5.14.2 /usr/lib/perl/5.14.2/ /usr/lib/perl/5.14.2 /usr/local/lib/site_perl /usr/lib/perl/5.14.2 .) at p.pl line 1.
BEGIN failed–compilation aborted at p.pl line 1.
Anybody have a solution or another way to communicate via serial?
root@bbb:~# cpan -i Device::SerialPort
that will install the missing perl module
