How can I enable 4xCAN and 2xGPIO on the BeagleBone Ai64
Problem:
I am able to configure and deploy device tree changes to enable 4x UART, 4x CAN, 2x GPIO. But I can only get the UARTs to function as outlined in this related post: How can I enable the 5 UARTs of the beaglebone AI-64? - #13 by mithunnj
Implementation details
Base image
  • The base image that we chose to go with: bbai64-debian-11.8-minimal-arm64-2023-10-07-4gb.img
    • This image enabled us to expose the necessary UART peripherals. We didn’t have success with newer images. More information can be found in the related post mentioned above.
CAN implementation:
Based on this CAN table: BeagleBone cape interface spec — BeagleBoard Documentation, we chose the following pins for our CAN Tx/Rx:
  • P8_10 → Tx, P8_09 → Rx
  • P8_08 → Tx, P8_07 → Rx
  • P9_20 → Tx, P9_19 → Rx
  • P8_05 → Tx, P8_06 → Rx
    As outlined in our UART node changes in k3-j721e-beagleboneai64-bone-buses.dtsi:
// CAN configuration for BeagleBone AI-64
/* BeagleBoard AI64 CAN Port Mapping Table as defined here: https://docs.beagleboard.org/boards/capes/cape-interface-spec.html#id50
 * | Bone Bus         | AI-64   | TX      | RX      | Overlay   |
 * | /dev/bone/can/0  | MAIN_MCAN0 | P9.20 | P9.19  | BONE-CAN0 |
 * | /dev/bone/can/1  | MAIN_MCAN4 | P9.26 | P9.24  | BONE-CAN1 |
 * | /dev/bone/can/2  | MAIN_MCAN5 | P8.08 | P8.07  | BONE-CAN2 |
 * | /dev/bone/can/3  | MAIN_MCAN6 | P8.10 | P8.09  | BONE-CAN3 |
 * | /dev/bone/can/4  | MAIN_MCAN7 | P8.05 | P8.06  | BONE-CAN4 |
 * Notes:
 * - The important fields are the AI-64, TX, and RX columns which map to the physical pins on the board and cannot be renamed or changed
/* CAN 1: Peripheral on Pins P8_10 (TX) and P8_09 (RX) */
bone_can_1: &main_mcan6 {
     * Description:
     * - Symlink "bone/can/1" corresponds to MOT_CAN_1_RX_AI64 an MOT_CAN_1_TX_AI64 as defined here: https://hub.allspice.io/Mytra/RTOS-Board-I/src/branch/main/RTOS-Board-I.kicad_sch
     * Notes:
     * - CAN is enabled in BONE-CAN1.dts
    pinctrl-names = "default";
    pinctrl-0 = <
        &P8_10_can_pin /* TX */
        &P8_09_can_pin /* RX */
    symlink = "bone/can/1";
    status = "disabled";
/* CAN 2: Peripheral on Pins P8_08 (TX) and P8_07 (RX) */
bone_can_2: &main_mcan5 {
     * Description:
     * - Symlink "bone/can/2" corresponds to MOT_CAN_2_RX_AI64 an MOT_CAN_2_TX_AI64 as defined here: https://hub.allspice.io/Mytra/RTOS-Board-I/src/branch/main/RTOS-Board-I.kicad_sch
     * Notes:
     * - CAN is enabled in BONE-CAN2.dts
    pinctrl-0 = <
        &P8_08_can_pin /* TX */
        &P8_07_can_pin /* RX */
    symlink = "bone/can/2";
/* CAN 3: Peripheral on Pins P9_20 (TX) and P9_19 (RX) */
bone_can_3: &main_mcan0 {
     * Description:
     * - Symlink "bone/can/3" corresponds to MOT_CAN_3_RX_AI64 an MOT_CAN_3_TX_AI64 as defined here: https://hub.allspice.io/Mytra/RTOS-Board-I/src/branch/main/RTOS-Board-I.kicad_sch
     * Notes:
     * - CAN is enabled in BONE-CAN3.dts
    pinctrl-0 = <
        &P9_20_can_pin /* TX */
        &P9_19_can_pin /* RX */
    symlink = "bone/can/3";
/* CAN 4: Peripheral on Pins P8_05 (TX) and P8_06 (RX) */
bone_can_4: &main_mcan7 {
     * Description:
     * - Symlink "bone/can/4" corresponds to BAT_CAN_RX_AI64 an BAT_CAN_TX_AI64 as defined here: https://hub.allspice.io/Mytra/RTOS-Board-I/src/branch/main/RTOS-Board-I.kicad_sch
     * Notes:
     * - CAN is enabled in BONE-CAN4.dts
    pinctrl-0 = <
        &P8_05_can_pin /* TX */
        &P8_06_can_pin /* RX */
    symlink = "bone/can/4";
I also made the following device tree modifications:
// SPDX-License-Identifier: GPL-2.0
 * Copyright (C) 2022 BeagleBoard.org - https://beagleboard.org/
 * Combined overlay to enable CAN1, CAN2, CAN3, and CAN4 on BeagleBone AI-64
/dts-v1/;
/plugin/;
#include <dt-bindings/pinctrl/k3.h>
#include <dt-bindings/board/k3-j721e-bone-pins.h>
 * Helper to show loaded overlays under: /proc/device-tree/chosen/overlays/
&{/chosen} {
    overlays {
        BONE-CAN1.kernel = __TIMESTAMP__;
        BONE-CAN2.kernel = __TIMESTAMP__;
        BONE-CAN3.kernel = __TIMESTAMP__;
        BONE-CAN4.kernel = __TIMESTAMP__;
 * Enable CAN1 Peripheral as defined in: k3-j721e-beagleboneai64-bone-buses.dtsi
&bone_can_1 {
    status = "okay"; // Enable CAN1
 * Enable CAN2 Peripheral as defined in: k3-j721e-beagleboneai64-bone-buses.dtsi
&bone_can_2 {
    status = "okay"; // Enable CAN2
 * Enable CAN3 Peripheral as defined in: k3-j721e-beagleboneai64-bone-buses.dtsi
&bone_can_3 {
    status = "okay"; // Enable CAN3
 * Enable CAN4 Peripheral as defined in: k3-j721e-beagleboneai64-bone-buses.dtsi
&bone_can_4 {
    status = "okay"; // Enable CAN4
Once the modifications were deployed to our BeagleBone Ai64, we were able to verify that the overlays were configured by checking the following:
$ sudo beagle-version | grep UBOOT
UBOOT: Booted Device-Tree:[k3-j721e-beagleboneai64.dts]
UBOOT: Loaded Overlay:[BONE-CAN1.kernel]
UBOOT: Loaded Overlay:[BONE-CAN2.kernel]
UBOOT: Loaded Overlay:[BONE-CAN3.kernel]
UBOOT: Loaded Overlay:[BONE-CAN4.kernel]
UBOOT: Loaded Overlay:[BONE-GPIO1.kernel]
UBOOT: Loaded Overlay:[BONE-GPIO2.kernel]
UBOOT: Loaded Overlay:[BONE-UART1.kernel]
UBOOT: Loaded Overlay:[BONE-UART2.kernel]
UBOOT: Loaded Overlay:[BONE-UART3.kernel]
UBOOT: Loaded Overlay:[BONE-UART4.kernel]
$ ip link show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
    link/ether 24:76:25:a0:d9:4e brd ff:ff:ff:ff:ff:ff
3: can0: <NO-CARRIER,NOARP,UP,ECHO> mtu 16 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 10
    link/can
4: can1: <NO-CARRIER,NOARP,UP,ECHO> mtu 16 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 10
    link/can
5: can2: <NO-CARRIER,NOARP,UP,ECHO> mtu 16 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 10
    link/can
6: can3: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UP mode DEFAULT group default qlen 10
    link/can
7: usb0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 1000
    link/ether 24:76:25:a0:d9:51 brd ff:ff:ff:ff:ff:ff
8: usb1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 1000
    link/ether 24:76:25:a0:d9:53 brd ff:ff:ff:ff:ff:ff
Issues with testing CAN:
To verify that CAN was configured properly, I connected a PCAN dongle and attempted to read/write commands over CAN channel 3.
I verified that the CAN bus was up and active, and both the BeagleBone and the PCAN Viewer were configured to the same CAN message type (ISO CAN FD), and Bitrate:
$ ip -details link show can3
    link/can  promiscuity 0 minmtu 0 maxmtu 0
    can <LOOPBACK> state ERROR-ACTIVE (berr-counter tx 0 rx 0) restart-ms 0
	  bitrate 500000 sample-point 0.875
	  tq 12 prop-seg 69 phase-seg1 70 phase-seg2 20 sjw 1
	  m_can: tseg1 2..256 tseg2 2..128 sjw 1..128 brp 1..512 brp-inc 1
	  m_can: dtseg1 1..32 dtseg2 1..16 dsjw 1..16 dbrp 1..32 dbrp-inc 1
	  clock 80000000 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
Any red flags in our implementation to make the CAN peripheral work ?
GPIO implementation details:
Based on this table: BeagleBone cape interface spec — BeagleBoard Documentation, we chose to use the following GPIO pins:
  • P8_19
  • P8_33
    And made the following changes to our k3-j721e-beagleboneai64-bone-buses.dtsi:
ocp: &main_pmx0 {
	p8_19_gpio_pin: pinmux_p8_19_gpio_pin {
			pinctrl-single,pins = <
					P8_19(PIN_INPUT, 7)
	p8_33_gpio_pin: pinmux_p8_33_gpio_pin {
					P8_33A(PIN_INPUT, 7)
&main_gpio0 {
		bone_gpio_1: bone-gpio-1 {
				compatible = "mytra,raw-gpio-pin";
				pinctrl-0 = <&p8_19_gpio_pin>;
				gpios = <&main_gpio0 88 GPIO_ACTIVE_HIGH>;
				symlink = "bone/gpio/1";
		bone_gpio_2: bone-gpio-2 {
				pinctrl-0 = <&p8_33_gpio_pin>;
				gpios = <&main_gpio0 25 GPIO_ACTIVE_HIGH>;
				symlink = "bone/gpio/2";
And the following device tree changes:
 * Combined overlay to enable GPIO1 and GPIO2 on BeagleBone AI-64
/dts-v1/;
/plugin/;
&{/chosen} {
    overlays {
        BONE-GPIO1.kernel = __TIMESTAMP__;
        BONE-GPIO2.kernel = __TIMESTAMP__;
 * Enable GPIO1 PRG_RST Peripheral as defined in: k3-j721e-beagleboneai64-bone-buses.dtsi
&bone_gpio_1 {
    status = "okay"; // Enable GPIO1
 * Enable GPIO2 PRG_BOOT Peripheral as defined in: k3-j721e-beagleboneai64-bone-buses.dtsi
&bone_gpio_2 {
    status = "okay"; // Enable GPIO2
Issues with testing GPIO:
As mentioned above, I was able to verify that the device tree modifications were built and loaded correctly as outlined in the logs below:
And:
$ ls /proc/device-tree/chosen/overlays/
BONE-CAN1.kernel  BONE-CAN4.kernel   BONE-UART1.kernel  BONE-UART4.kernel
BONE-CAN2.kernel  BONE-GPIO1.kernel  BONE-UART2.kernel  name
BONE-CAN3.kernel  BONE-GPIO2.kernel  BONE-UART3.kernel
But when using the gpioinfo utility I see the following:
$ gpioinfo gpiochip1
line  88:      "P8_19"       unused   input  active-high
$ gpioinfo gpiochip0
line  25:         "NC"       unused  output  active-high
As a result when I try to set the GPIO pins to high, they remain stuck in the low state, unresponsive.
Could I get assistance reviewing the implementation for our CAN and GPIO peripheral device tree modifications.
Additional information:
Below is our k3-j721e-beagleboneai64-bone-buses.dtsi"
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/input/linux-event-codes.h>
/* MYTRA NOTE: DO NOT MODIFY THE BUS PINMUX SETTINGS OUTLINED BELOW */
ocp: &main_pmx0 {
/* macro: BONE_PIN( <pin>, <mode_name>, <register_value_macro(s)>) */
#define BONE_PIN(XX,ZZ,QQ) \
	XX##_##ZZ##_pin: pinmux_##XX##_##ZZ##_pin { pinctrl-single,pins = < QQ >; };
	/* I2C: https://docs.beagleboard.io/latest/boards/capes/cape-interface-spec.html#i2c */
	/* bone_i2c_1 main_i2c6 P9.17 P9.18 */
	/* bone_i2c_2 main_i2c2 P9.19 P9.20 */
	/* bone_i2c_3 main_i2c4 P9.24 P9.26 */
	/* CAN: https://docs.beagleboard.io/latest/boards/capes/cape-interface-spec.html#can */
	/* bone_can_0 main_mcan0 P9.20 P9.19 */
	/* bone_can_1 main_mcan4 P9.26 P9.24 */
	/* bone_can_2 main_mcan5 P8.08 P8.07 */
	/* bone_can_3 main_mcan6 P8.10 P8.09 */
	/* bone_can_4 main_mcan7 P8.05 P8.06 */
	/* SPI : https://docs.beagleboard.io/latest/boards/capes/cape-interface-spec.html#spi */
	/* bone_spi_0 main_spi6 P9.18 P9.21 P9.22 P9.16 P9.23 */
	/* bone_spi_1 main_spi7 P9.30 P9.29 P9.31 P9.29 P9.42 */
	/* UART : https://docs.beagleboard.io/latest/boards/capes/cape-interface-spec.html#uart */
	/* bone_uart_1 main_uart2 P9.24 P9.22 */
	/* bone_uart_4 main_uart0 P9.13 P9.11 */
	/* bone_uart_5 main_uart5 P8.37 P8.38 P8.32 P8.31 */
	/* bone_uart_6 main_uart8 P8.29 P8.28 */
	/* bone_uart_7 main_uart2 P8.34 P8.22 */
	/* PWM: https://docs.beagleboard.io/latest/boards/capes/cape-interface-spec.html#pwm */
	/* bone_pwm_0 ehrpwm1 P9.22 P9.21 */
	/* bone_pwm_1 ehrpwm2 P9.14 P9.16 */
	/* bone_pwm_2 ehrpwm0 P8.19 P8.13 */
	/* Full P8/P9 header mode definitions */
	/* P8_01 - GND */
	/* P8_02 - GND */
	/* P8_03 (AH21) PRG1_PRU0_GPO19 (gpio0_20) AH21_MCAN6_TX */
	BONE_PIN(P8_03, default,   P8_03(PIN_INPUT, 7))
	BONE_PIN(P8_03, pruout,    P8_03(PIN_OUTPUT, 0))	/* prg1_pru0_gpo19 */
	BONE_PIN(P8_03, pruin,     P8_03(PIN_INPUT, 1))		/* prg1_pru0_gpi19 */
	BONE_PIN(P8_03, can,       P8_03(PIN_INPUT, 6))		/* mcan6_tx */
	BONE_PIN(P8_03, gpio,      P8_03(PIN_INPUT, 7))
	BONE_PIN(P8_03, gpio_pu,   P8_03(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_03, gpio_pd,   P8_03(PIN_INPUT_PULLDOWN, 7))
	/* P8_04 (AC29) PRG0_PRU0_GPO5 (gpio0_48) AC29_SYS_BOOTMODE2 */
	BONE_PIN(P8_04, default,   P8_04(PIN_INPUT, 7))
	BONE_PIN(P8_04, pruout,    P8_04(PIN_OUTPUT, 0))	/* prg0_pru0_gpo5 */
	BONE_PIN(P8_04, pruin,     P8_04(PIN_INPUT, 1))		/* prg0_pru0_gpi5 */
	BONE_PIN(P8_04, gpio,      P8_04(PIN_INPUT, 7))
	BONE_PIN(P8_04, gpio_pu,   P8_04(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_04, gpio_pd,   P8_04(PIN_INPUT_PULLDOWN, 7))
	/* P8_05 (AH25) PRG1_PRU1_GPO12 (gpio0_33) AH25_MCAN7_TX */
	BONE_PIN(P8_05, default,   P8_05(PIN_INPUT, 7))
	BONE_PIN(P8_05, pruout,    P8_05(PIN_OUTPUT, 0))	/* prg1_pru1_gpo12 */
	BONE_PIN(P8_05, pruin,     P8_05(PIN_INPUT, 1))		/* prg1_pru1_gpi12 */
	BONE_PIN(P8_05, can,       P8_05(PIN_INPUT, 6))		/* mcan7_tx */
	BONE_PIN(P8_05, gpio,      P8_05(PIN_INPUT, 7))
	BONE_PIN(P8_05, gpio_pu,   P8_05(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_05, gpio_pd,   P8_05(PIN_INPUT_PULLDOWN, 7))
	/* P8_06 (AG25) PRG1_PRU1_GPO13 (gpio0_34) AG25_MCAN7_RX */
	BONE_PIN(P8_06, default,   P8_06(PIN_INPUT, 7))
	BONE_PIN(P8_06, pruout,    P8_06(PIN_OUTPUT, 0))	/* prg1_pru1_gpo13 */
	BONE_PIN(P8_06, pruin,     P8_06(PIN_INPUT, 1))		/* prg1_pru1_gpi13 */
	BONE_PIN(P8_06, can,       P8_06(PIN_INPUT, 6))		/* mcan7_rx */
	BONE_PIN(P8_06, gpio,      P8_06(PIN_INPUT, 7))
	BONE_PIN(P8_06, gpio_pu,   P8_06(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_06, gpio_pd,   P8_06(PIN_INPUT_PULLDOWN, 7))
	/* P8_07 (AD24) PRG1_PRU0_GPO14 (gpio0_15) AD24_MCAN5_RX */
	BONE_PIN(P8_07, default,   P8_07(PIN_INPUT, 7))
	BONE_PIN(P8_07, pruout,    P8_07(PIN_OUTPUT, 0))	/* prg1_pru0_gpo14 */
	BONE_PIN(P8_07, pruin,     P8_07(PIN_INPUT, 1))		/* prg1_pru0_gpi14 */
	BONE_PIN(P8_07, can,       P8_07(PIN_INPUT, 6))		/* mcan5_rx */
	BONE_PIN(P8_07, gpio,      P8_07(PIN_INPUT, 7))
	BONE_PIN(P8_07, gpio_pu,   P8_07(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_07, gpio_pd,   P8_07(PIN_INPUT_PULLDOWN, 7))
	/* P8_08 (AG24) PRG1_PRU0_GPO13 (gpio0_14) AG24_MCAN5_TX */
	BONE_PIN(P8_08, default,   P8_08(PIN_INPUT, 7))
	BONE_PIN(P8_08, pruout,    P8_08(PIN_OUTPUT, 0))	/* prg1_pru0_gpo13 */
	BONE_PIN(P8_08, pruin,     P8_08(PIN_INPUT, 1))		/* prg1_pru0_gpi13 */
	BONE_PIN(P8_08, can,       P8_08(PIN_OUTPUT, 6))	/* mcan5_tx */
	BONE_PIN(P8_08, gpio,      P8_08(PIN_INPUT, 7))
	BONE_PIN(P8_08, gpio_pu,   P8_08(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_08, gpio_pd,   P8_08(PIN_INPUT_PULLDOWN, 7))
	/* P8_09 (AE24) PRG1_PRU0_GPO16 (gpio0_17) AE24_MCAN6_RX */
	BONE_PIN(P8_09, default,   P8_09(PIN_INPUT, 7))
	BONE_PIN(P8_09, pruout,    P8_09(PIN_OUTPUT, 0))	/* prg1_pru0_gpo16 */
	BONE_PIN(P8_09, pruin,     P8_09(PIN_INPUT, 1))		/* prg1_pru0_gpi16 */
	BONE_PIN(P8_09, can,       P8_09(PIN_INPUT, 6))		/* mcan6_rx */
	BONE_PIN(P8_09, gpio,      P8_09(PIN_INPUT, 7))
	BONE_PIN(P8_09, gpio_pu,   P8_09(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_09, gpio_pd,   P8_09(PIN_INPUT_PULLDOWN, 7))
	/* P8_10 (AC24) PRG1_PRU0_GPO15 (gpio0_16) AC24_MCAN6_TX */
	BONE_PIN(P8_10, default,   P8_10(PIN_INPUT, 7))
	BONE_PIN(P8_10, pruout,    P8_10(PIN_OUTPUT, 0))	/* prg1_pru0_gpo15 */
	BONE_PIN(P8_10, pruin,     P8_10(PIN_INPUT, 1))		/* prg1_pru0_gpi15 */
	BONE_PIN(P8_10, can,       P8_10(PIN_INPUT, 7))		/* mcan6_tx */
	BONE_PIN(P8_10, gpio,      P8_10(PIN_INPUT, 7))
	BONE_PIN(P8_10, gpio_pu,   P8_10(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_10, gpio_pd,   P8_10(PIN_INPUT_PULLDOWN, 7))
	/* P8_11 (AB24) PRG0_PRU0_GPO17 (gpio0_60) AB24_SYS_BOOTMODE7 */
	BONE_PIN(P8_11, default,   P8_11(PIN_INPUT, 7))
	BONE_PIN(P8_11, pruout,    P8_11(PIN_OUTPUT, 0))	/* prg0_pru0_gpo17 */
	BONE_PIN(P8_11, pruin,     P8_11(PIN_INPUT, 1))		/* prg0_pru0_gpi17 */
	BONE_PIN(P8_11, gpio,      P8_11(PIN_INPUT, 7))
	BONE_PIN(P8_11, gpio_pu,   P8_11(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_11, gpio_pd,   P8_11(PIN_INPUT_PULLDOWN, 7))
	/* P8_12 (AH28) PRG0_PRU0_GPO16 (gpio0_59) AH28_PRG0_PWM0_A2 */
	BONE_PIN(P8_12, default,   P8_12(PIN_INPUT, 7))
	BONE_PIN(P8_12, pruout,    P8_12(PIN_OUTPUT, 0))	/* prg0_pru0_gpo16 */
	BONE_PIN(P8_12, pruin,     P8_12(PIN_INPUT, 1))		/* prg0_pru0_gpi16 */
	BONE_PIN(P8_12, gpio,      P8_12(PIN_INPUT, 7))
	BONE_PIN(P8_12, gpio_pu,   P8_12(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_12, gpio_pd,   P8_12(PIN_INPUT_PULLDOWN, 7))
	/* P8_13 (V27) RGMII5_TD1 (gpio0_89) V27_EHRPWM0_B */
	BONE_PIN(P8_13, default,   P8_13(PIN_INPUT, 7))
	BONE_PIN(P8_13, gpio,      P8_13(PIN_INPUT, 7))
	BONE_PIN(P8_13, gpio_pu,   P8_13(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_13, gpio_pd,   P8_13(PIN_INPUT_PULLDOWN, 7))
	BONE_PIN(P8_13, pwm,       P8_13(PIN_OUTPUT, 6))	/* ehrpwm0_b */
	/* P8_14 (AF27) PRG0_PRU1_GPO12 (gpio0_75) AF27_PRG0_PWM1_A0 */
	BONE_PIN(P8_14, default,   P8_14(PIN_INPUT, 7))
	BONE_PIN(P8_14, pruout,    P8_14(PIN_OUTPUT, 0))	/* prg0_pru1_gpo12 */
	BONE_PIN(P8_14, pruin,     P8_14(PIN_INPUT, 1))		/* prg0_pru1_gpi12 */
	BONE_PIN(P8_14, gpio,      P8_14(PIN_INPUT, 7))
	BONE_PIN(P8_14, gpio_pu,   P8_14(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_14, gpio_pd,   P8_14(PIN_INPUT_PULLDOWN, 7))
	/* P8_15 (AB29) PRG0_PRU0_GPO18 (gpio0_61) AB29_PRG0_ECAP0_IN_APWM_OUT */
	BONE_PIN(P8_15, default,   P8_15(PIN_INPUT, 7))
	BONE_PIN(P8_15, pruout,    P8_15(PIN_OUTPUT, 0))	/* prg0_pru0_gpo18 */
	BONE_PIN(P8_15, pruin,     P8_15(PIN_INPUT, 1))		/* prg0_pru0_gpi18 */
	BONE_PIN(P8_15, gpio,      P8_15(PIN_INPUT, 7))
	BONE_PIN(P8_15, gpio_pu,   P8_15(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_15, gpio_pd,   P8_15(PIN_INPUT_PULLDOWN, 7))
	/* P8_16 (AB28) PRG0_PRU0_GPO19 (gpio0_62) AB28_PRG0_PWM0_TZ_OUT */
	BONE_PIN(P8_16, default,   P8_16(PIN_INPUT, 7))
	BONE_PIN(P8_16, pruout,    P8_16(PIN_OUTPUT, 0))	/* prg0_pru0_gpo19 */
	BONE_PIN(P8_16, pruin,     P8_16(PIN_INPUT, 1))		/* prg0_pru0_gpi19 */
	BONE_PIN(P8_16, gpio,      P8_16(PIN_INPUT, 7))
	BONE_PIN(P8_16, gpio_pu,   P8_16(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_16, gpio_pd,   P8_16(PIN_INPUT_PULLDOWN, 7))
	/* P8_17 (AF22) PRG1_PRU0_GPO2 (gpio0_3) AF22_PRG1_PWM2_A0 */
	BONE_PIN(P8_17, default,   P8_17(PIN_INPUT, 7))
	BONE_PIN(P8_17, pruout,    P8_17(PIN_OUTPUT, 0))	/* prg1_pru0_gpo2 */
	BONE_PIN(P8_17, pruin,     P8_17(PIN_INPUT, 1))		/* prg1_pru0_gpi2 */
	BONE_PIN(P8_17, gpio,      P8_17(PIN_INPUT, 7))
	BONE_PIN(P8_17, gpio_pu,   P8_17(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_17, gpio_pd,   P8_17(PIN_INPUT_PULLDOWN, 7))
	/* P8_18 (AJ23) PRG1_PRU0_GPO3 (gpio0_4) AJ23_PRG1_PWM3_A2 */
	BONE_PIN(P8_18, default,   P8_18(PIN_INPUT, 7))
	BONE_PIN(P8_18, pruout,    P8_18(PIN_OUTPUT, 0))	/* prg1_pru0_gpo3 */
	BONE_PIN(P8_18, pruin,     P8_18(PIN_INPUT, 1))		/* prg1_pru0_gpi3 */
	BONE_PIN(P8_18, gpio,      P8_18(PIN_INPUT, 7))
	BONE_PIN(P8_18, gpio_pu,   P8_18(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_18, gpio_pd,   P8_18(PIN_INPUT_PULLDOWN, 7))
	/* P8_19 (V29) RGMII5_TD2 (gpio0_88) V29_EHRPWM0_A */
	BONE_PIN(P8_19, default,   P8_19(PIN_INPUT, 7))
	BONE_PIN(P8_19, gpio,      P8_19(PIN_INPUT, 7))
	BONE_PIN(P8_19, gpio_pu,   P8_19(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_19, gpio_pd,   P8_19(PIN_INPUT_PULLDOWN, 7))
	BONE_PIN(P8_19, pwm,       P8_19(PIN_OUTPUT, 6))	/* ehrpwm0_a */
	/* P8_20 (AF26) PRG0_PRU1_GPO13 (gpio0_76) AF26_PRG0_PWM1_B0 */
	BONE_PIN(P8_20, default,   P8_20(PIN_INPUT, 7))
	BONE_PIN(P8_20, pruout,    P8_20(PIN_OUTPUT, 0))	/* prg0_pru1_gpo13 */
	BONE_PIN(P8_20, pruin,     P8_20(PIN_INPUT, 1))		/* prg0_pru1_gpi13 */
	BONE_PIN(P8_20, gpio,      P8_20(PIN_INPUT, 7))
	BONE_PIN(P8_20, gpio_pu,   P8_20(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_20, gpio_pd,   P8_20(PIN_INPUT_PULLDOWN, 7))
	/* P8_21 (AF21) PRG1_PRU1_GPO9 (gpio0_30) AF21_MCAN8_TX */
	BONE_PIN(P8_21, default,   P8_21(PIN_INPUT, 7))
	BONE_PIN(P8_21, pruout,    P8_21(PIN_OUTPUT, 0))	/* prg1_pru1_gpo9 */
	BONE_PIN(P8_21, pruin,     P8_21(PIN_INPUT, 1))		/* prg1_pru1_gpi9 */
	BONE_PIN(P8_21, gpio,      P8_21(PIN_INPUT, 7))
	BONE_PIN(P8_21, gpio_pu,   P8_21(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_21, gpio_pd,   P8_21(PIN_INPUT_PULLDOWN, 7))
	BONE_PIN(P8_21, spi,       P8_21(PIN_OUTPUT, 4))	/* spi6_cs3 */
	/* P8_22 (AH23) PRG1_PRU0_GPO4 (gpio0_5) AH23_UART2_RXD */
	BONE_PIN(P8_22, default,   P8_22(PIN_INPUT, 7))
	BONE_PIN(P8_22, pruout,    P8_22(PIN_OUTPUT, 0))	/* prg1_pru0_gpo4 */
	BONE_PIN(P8_22, pruin,     P8_22(PIN_INPUT, 1))		/* prg1_pru0_gpi4 */
	BONE_PIN(P8_22, gpio,      P8_22(PIN_INPUT, 7))
	BONE_PIN(P8_22, gpio_pu,   P8_22(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_22, gpio_pd,   P8_22(PIN_INPUT_PULLDOWN, 7))
	BONE_PIN(P8_22, uart,      P8_22(PIN_INPUT, 14))	/* uart2_rxd */
	/* P8_23 (AB23) PRG1_PRU1_GPO10 (gpio0_31) AB23_MCAN8_RX */
	BONE_PIN(P8_23, default,   P8_23(PIN_INPUT, 7))
	BONE_PIN(P8_23, pruout,    P8_23(PIN_OUTPUT, 0))	/* prg1_pru1_gpo10 */
	BONE_PIN(P8_23, pruin,     P8_23(PIN_INPUT, 1))		/* prg1_pru1_gpi10 */
	BONE_PIN(P8_23, pruuart,   P8_23(PIN_OUTPUT, 2))
	BONE_PIN(P8_23, gpio,      P8_23(PIN_INPUT, 7))
	BONE_PIN(P8_23, gpio_pu,   P8_23(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_23, gpio_pd,   P8_23(PIN_INPUT_PULLDOWN, 7))
	/* P8_24 (AD20) PRG1_PRU0_GPO5 (gpio0_6) AD20_SYS_BOOTMODE0 */
	BONE_PIN(P8_24, default,   P8_24(PIN_INPUT, 7))
	BONE_PIN(P8_24, pruout,    P8_24(PIN_OUTPUT, 0))	/* prg1_pru0_gpo5 */
	BONE_PIN(P8_24, pruin,     P8_24(PIN_INPUT, 1))		/* prg1_pru0_gpi5 */
	BONE_PIN(P8_24, gpio,      P8_24(PIN_INPUT, 7))
	BONE_PIN(P8_24, gpio_pu,   P8_24(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_24, gpio_pd,   P8_24(PIN_INPUT_PULLDOWN, 7))
	/* P8_25 (AH26) PRG1_PRU1_GPO14 (gpio0_35) AH26_PRG1_PRU1_GPO14 */
	BONE_PIN(P8_25, default,   P8_25(PIN_INPUT, 7))
	BONE_PIN(P8_25, pruout,    P8_25(PIN_OUTPUT, 0))	/* prg1_pru1_gpo14 */
	BONE_PIN(P8_25, pruin,     P8_25(PIN_INPUT, 1))		/* prg1_pru1_gpi14 */
	BONE_PIN(P8_25, gpio,      P8_25(PIN_INPUT, 7))
	BONE_PIN(P8_25, gpio_pu,   P8_25(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_25, gpio_pd,   P8_25(PIN_INPUT_PULLDOWN, 7))
	/* P8_26 (AC27) PRG0_PRU0_GPO8 (gpio0_51) AC27_PRG0_PWM2_A1 */
	BONE_PIN(P8_26, default,   P8_26(PIN_INPUT, 7))
	BONE_PIN(P8_26, pruout,    P8_26(PIN_OUTPUT, 0))	/* prg0_pru0_gpo8 */
	BONE_PIN(P8_26, pruin,     P8_26(PIN_INPUT, 1))		/* prg0_pru0_gpi8 */
	BONE_PIN(P8_26, gpio,      P8_26(PIN_INPUT, 7))
	BONE_PIN(P8_26, gpio_pu,   P8_26(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_26, gpio_pd,   P8_26(PIN_INPUT_PULLDOWN, 7))
	/* P8_27 (AA28) PRG0_PRU1_GPO8 (gpio0_71) AA28_PRG0_PRU1_GPO8 */
	BONE_PIN(P8_27, default,   P8_27(PIN_INPUT, 7))
	BONE_PIN(P8_27, pruout,    P8_27(PIN_OUTPUT, 0))	/* prg0_pru1_gpo8 */
	BONE_PIN(P8_27, pruin,     P8_27(PIN_INPUT, 1))		/* prg0_pru1_gpi8 */
	BONE_PIN(P8_27, gpio,      P8_27(PIN_INPUT, 7))
	BONE_PIN(P8_27, gpio_pu,   P8_27(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_27, gpio_pd,   P8_27(PIN_INPUT_PULLDOWN, 7))
	/* P8_28 (Y24) PRG0_PRU1_GPO9 (gpio0_72) Y24_PRG0_UART0_RXD */
	BONE_PIN(P8_28, default,   P8_28(PIN_INPUT, 7))
	BONE_PIN(P8_28, pruout,    P8_28(PIN_OUTPUT, 0))	/* prg0_pru1_gpo9 */
	BONE_PIN(P8_28, pruin,     P8_28(PIN_INPUT, 1))		/* prg0_pru1_gpi9 */
	BONE_PIN(P8_28, gpio,      P8_28(PIN_INPUT, 7))
	BONE_PIN(P8_28, gpio_pu,   P8_28(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_28, gpio_pd,   P8_28(PIN_INPUT_PULLDOWN, 7))
	BONE_PIN(P8_28, uart,      P8_28(PIN_INPUT, 14))	/* uart8_rx */
	/* P8_29 (AA25) PRG0_PRU1_GPO10 (gpio0_73) AA25_PRG0_UART0_TXD */
	BONE_PIN(P8_29, default,   P8_29(PIN_INPUT, 7))
	BONE_PIN(P8_29, pruout,    P8_29(PIN_OUTPUT, 0))	/* prg0_pru1_gpo10 */
	BONE_PIN(P8_29, pruin,     P8_29(PIN_INPUT, 1))		/* prg0_pru1_gpi10 */
	BONE_PIN(P8_29, gpio,      P8_29(PIN_INPUT, 7))
	BONE_PIN(P8_29, gpio_pu,   P8_29(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_29, gpio_pd,   P8_29(PIN_INPUT_PULLDOWN, 7))
	BONE_PIN(P8_29, uart,      P8_29(PIN_OUTPUT, 14))	/* uart8_tx */
	/* P8_30 (AG26) PRG0_PRU1_GPO11 (gpio0_74) AG26_PRG0_PRU1_GPO11 */
	BONE_PIN(P8_30, default,   P8_30(PIN_INPUT, 7))
	BONE_PIN(P8_30, pruout,    P8_30(PIN_OUTPUT, 0))	/* prg0_pru1_gpo11 */
	BONE_PIN(P8_30, pruin,     P8_30(PIN_INPUT, 1))		/* prg0_pru1_gpi11 */
	BONE_PIN(P8_30, gpio,      P8_30(PIN_INPUT, 7))
	BONE_PIN(P8_30, gpio_pu,   P8_30(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_30, gpio_pd,   P8_30(PIN_INPUT_PULLDOWN, 7))
	/* P8_31 (AJ25/AE29) PRG1_PRU1_GPO11/PRG0_PRU1_GPO0 (gpio0_32/gpio0_63) AJ25_AE29 */
	BONE_PIN(P8_31, default,   P8_31A(PIN_INPUT, 7) P8_31B(PIN_INPUT, 7))
	BONE_PIN(P8_31, pruout,    P8_31A(PIN_OUTPUT, 0) P8_31B(PIN_INPUT, 7))
	BONE_PIN(P8_31, pruin,     P8_31A(PIN_INPUT, 1) P8_31B(PIN_INPUT, 7))
	BONE_PIN(P8_31, gpio,      P8_31A(PIN_INPUT, 7) P8_31B(PIN_INPUT, 7))	/* gpio0_32 */
	BONE_PIN(P8_31, gpio_pu,   P8_31A(PIN_INPUT_PULLUP, 7) P8_31B(PIN_INPUT, 7))
	BONE_PIN(P8_31, gpio_pd,   P8_31A(PIN_INPUT_PULLDOWN, 7) P8_31B(PIN_INPUT, 7))
	BONE_PIN(P8_31, qep,       P8_31A(PIN_INPUT, 9) P8_31B(PIN_INPUT, 7))	/* eqep1_i */
	BONE_PIN(P8_31, uart,      P8_31A(PIN_INPUT, 7) P8_31B(PIN_INPUT, 14))	/* uart5_rxd */
	/* P8_32 (AG21/AD28) PRG1_PRU1_GPO5/PRG0_PRU1_GPO1 (gpio0_26/gpio0_64) AG21_AD28 */
	BONE_PIN(P8_32, default,   P8_32A(PIN_INPUT, 7) P8_32B(PIN_INPUT, 7))
	BONE_PIN(P8_32, pruout,    P8_32A(PIN_OUTPUT, 0) P8_32B(PIN_INPUT, 7))
	BONE_PIN(P8_32, pruin,     P8_32A(PIN_INPUT, 1) P8_32B(PIN_INPUT, 7))
	BONE_PIN(P8_32, gpio,      P8_32A(PIN_INPUT, 7) P8_32B(PIN_INPUT, 7))	/* gpio0_26 */
	BONE_PIN(P8_32, gpio_pu,   P8_32A(PIN_INPUT_PULLUP, 7) P8_32B(PIN_INPUT, 7))
	BONE_PIN(P8_32, gpio_pd,   P8_32A(PIN_INPUT_PULLDOWN, 7) P8_32B(PIN_INPUT, 7))
	BONE_PIN(P8_32, qep,       P8_32A(PIN_INPUT, 9) P8_32B(PIN_INPUT, 7))	/* eqep1_s */
	BONE_PIN(P8_32, uart,      P8_32A(PIN_INPUT, 7) P8_32B(PIN_OUTPUT, 14))	/* uart5_txd */
	/* P8_33 (AH24/AA2) PRG1_PRU1_GPO4/SPI0_CS0 (gpio0_25/gpio0_111) AH24_AA2 */
	BONE_PIN(P8_33, default,   P8_33A(PIN_INPUT, 7) P8_33B(PIN_INPUT, 7))
	BONE_PIN(P8_33, pruout,    P8_33A(PIN_OUTPUT, 0) P8_33B(PIN_INPUT, 7))	/* prg1_pru1_gpo4 */
	BONE_PIN(P8_33, pruin,     P8_33A(PIN_INPUT, 1) P8_33B(PIN_INPUT, 7))	/* prg1_pru1_gpi4 */
	BONE_PIN(P8_33, gpio,      P8_33A(PIN_INPUT, 7) P8_33B(PIN_INPUT, 7))	/* gpio0_25 */
	BONE_PIN(P8_33, gpio_pu,   P8_33A(PIN_INPUT_PULLUP, 7) P8_33B(PIN_INPUT, 7))
	BONE_PIN(P8_33, gpio_pd,   P8_33A(PIN_INPUT_PULLDOWN, 7) P8_33B(PIN_INPUT, 7))
	BONE_PIN(P8_33, qep,       P8_33A(PIN_INPUT, 9) P8_33B(PIN_INPUT, 7))	/* eqep1_b */
	/* P8_34 (AD22) PRG1_PRU0_GPO6 (gpio0_7) AD22_UART2_TXD */
	BONE_PIN(P8_34, default,   P8_34(PIN_INPUT, 7))
	BONE_PIN(P8_34, pruout,    P8_34(PIN_OUTPUT, 0))	/* prg1_pru0_gpo6 */
	BONE_PIN(P8_34, pruin,     P8_34(PIN_INPUT, 1))		/* prg1_pru0_gpi6 */
	BONE_PIN(P8_34, gpio,      P8_34(PIN_INPUT, 7))
	BONE_PIN(P8_34, gpio_pu,   P8_34(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_34, gpio_pd,   P8_34(PIN_INPUT_PULLDOWN, 7))
	BONE_PIN(P8_34, uart,      P8_34(PIN_OUTPUT, 14))	/* uart2_txd */
	/* P8_35 (AD23/Y3) PRG1_PRU1_GPO3/SPI1_CS0 (gpio0_24/gpio0_116) AD23_Y3 */
	BONE_PIN(P8_35, default,   P8_35A(PIN_INPUT, 7) P8_35B(PIN_INPUT, 7))
	BONE_PIN(P8_35, pruout,    P8_35A(PIN_OUTPUT, 0) P8_35B(PIN_INPUT, 7))	/* prg1_pru1_gpo3 */
	BONE_PIN(P8_35, pruin,     P8_35A(PIN_INPUT, 1) P8_35B(PIN_INPUT, 7))	/* prg1_pru1_gpi3 */
	BONE_PIN(P8_35, gpio,      P8_35A(PIN_INPUT, 7) P8_35B(PIN_INPUT, 7))	/* gpio0_24 */
	BONE_PIN(P8_35, gpio_pu,   P8_35A(PIN_INPUT_PULLUP, 7) P8_35B(PIN_INPUT, 7))
	BONE_PIN(P8_35, gpio_pd,   P8_35A(PIN_INPUT_PULLDOWN, 7) P8_35B(PIN_INPUT, 7))
	BONE_PIN(P8_35, qep,       P8_35A(PIN_INPUT, 9) P8_35B(PIN_INPUT, 7))	/* eqep1_a */
	BONE_PIN(P8_35, uart,      P8_35A(PIN_INPUT, 7) P8_35B(PIN_INPUT, 3))	/* uart5_rxd */
	/* P8_36 (AE20) PRG1_PRU0_GPO7 (gpio0_8) AE20_MCAN4_TX */
	BONE_PIN(P8_36, default,   P8_36(PIN_INPUT, 7))
	BONE_PIN(P8_36, pruout,    P8_36(PIN_OUTPUT, 0))	/* prg1_pru0_gpo7 */
	BONE_PIN(P8_36, pruin,     P8_36(PIN_INPUT, 1))		/* prg1_pru0_gpi7 */
	BONE_PIN(P8_36, can,       P8_36(PIN_OUTPUT, 6))	/* mcan4_tx */
	BONE_PIN(P8_36, gpio,      P8_36(PIN_INPUT, 7))
	BONE_PIN(P8_36, gpio_pu,   P8_36(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_36, gpio_pd,   P8_36(PIN_INPUT_PULLDOWN, 7))
	/* P8_37 (Y27/AD21) RGMII6_RD2/PRG1_PRU0_GPO10 (gpio0_106/gpio0_11) Y27_AD21 */
	BONE_PIN(P8_37, default,   P8_37A(PIN_INPUT, 7) P8_37B(PIN_INPUT, 7))
	BONE_PIN(P8_37, pruout,    P8_37A(PIN_INPUT, 7) P8_37B(PIN_OUTPUT, 0))	/* prg1_pru0_gpo10 */
	BONE_PIN(P8_37, pruin,     P8_37A(PIN_INPUT, 7) P8_37B(PIN_INPUT, 1))	/* prg1_pru0_gpi10 */
	BONE_PIN(P8_37, gpio,      P8_37A(PIN_INPUT, 7) P8_37B(PIN_INPUT, 7))	/* gpio0_106 */
	BONE_PIN(P8_37, gpio_pu,   P8_37A(PIN_INPUT_PULLUP, 7) P8_37B(PIN_INPUT, 7))
	BONE_PIN(P8_37, gpio_pd,   P8_37A(PIN_INPUT_PULLDOWN, 7) P8_37B(PIN_INPUT, 7))
	BONE_PIN(P8_37, pwm,       P8_37A(PIN_OUTPUT, 6) P8_37B(PIN_INPUT, 7))	/* ehrpwm5_a */
	BONE_PIN(P8_37, spi,       P8_37A(PIN_INPUT, 7) P8_37B(PIN_OUTPUT, 4))	/* spi6_cs2 */
	BONE_PIN(P8_37, uart,      P8_37A(PIN_OUTPUT, 3) P8_37B(PIN_INPUT, 7))	/* uart5_txd */
	/* P8_38 (AJ20/Y29) PRG1_PRU0_GPO8/RGMII6_RD3 (gpio0_9/gpio0_105) Y29_AJ20 */
	BONE_PIN(P8_38, default,   P8_38A(PIN_INPUT, 7) P8_38B(PIN_INPUT, 7))
	BONE_PIN(P8_38, pruout,    P8_38A(PIN_OUTPUT, 0) P8_38B(PIN_INPUT, 7))	/* prg1_pru0_gpo8 */
	BONE_PIN(P8_38, pruin,     P8_38A(PIN_INPUT, 1) P8_38B(PIN_INPUT, 7))	/* prg1_pru0_gpi8 */
	BONE_PIN(P8_38, can,       P8_38A(PIN_INPUT, 6) P8_38B(PIN_INPUT, 7))	/* mcan4_rx */
	BONE_PIN(P8_38, gpio,      P8_38A(PIN_INPUT, 7) P8_38B(PIN_INPUT, 7))	/* gpio0_9 */
	BONE_PIN(P8_38, gpio_pu,   P8_38A(PIN_INPUT_PULLUP, 7) P8_38B(PIN_INPUT, 7))
	BONE_PIN(P8_38, gpio_pd,   P8_38A(PIN_INPUT_PULLDOWN, 7) P8_38B(PIN_INPUT, 7))
	BONE_PIN(P8_38, uart,      P8_38A(PIN_INPUT, 7) P8_38B(PIN_INPUT, 3))	/* uart5_rxd */
	/* P8_39 (AC26) PRG0_PRU1_GPO6 (gpio0_69) AC26_PRG0_PRU1_GPO6 */
	BONE_PIN(P8_39, default,   P8_39(PIN_INPUT, 7))
	BONE_PIN(P8_39, pruout,    P8_39(PIN_OUTPUT, 0))	/* prg0_pru1_gpo6 */
	BONE_PIN(P8_39, pruin,     P8_39(PIN_INPUT, 1))		/* prg0_pru1_gpi6 */
	BONE_PIN(P8_39, gpio,      P8_39(PIN_INPUT, 7))
	BONE_PIN(P8_39, gpio_pu,   P8_39(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_39, gpio_pd,   P8_39(PIN_INPUT_PULLDOWN, 7))
	/* P8_40 (AA24) PRG0_PRU1_GPO7 (gpio0_70) AA24_PRG0_PRU1_GPO7 */
	BONE_PIN(P8_40, default,   P8_40(PIN_INPUT, 7))
	BONE_PIN(P8_40, pruout,    P8_40(PIN_OUTPUT, 0))	/* prg0_pru1_gpo7 */
	BONE_PIN(P8_40, pruin,     P8_40(PIN_INPUT, 1))		/* prg0_pru1_gpi7 */
	BONE_PIN(P8_40, gpio,      P8_40(PIN_INPUT, 7))
	BONE_PIN(P8_40, gpio_pu,   P8_40(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_40, gpio_pd,   P8_40(PIN_INPUT_PULLDOWN, 7))
	BONE_PIN(P8_40, uart,      P8_40(PIN_OUTPUT, 14))	/* uart2_txd */
	/* P8_41 (AD29) PRG0_PRU1_GPO4 (gpio0_67) AD29_PRG0_PRU1_GPO4 */
	BONE_PIN(P8_41, default,   P8_41(PIN_INPUT, 7))
	BONE_PIN(P8_41, pruout,    P8_41(PIN_OUTPUT, 0))	/* prg0_pru1_gpo4 */
	BONE_PIN(P8_41, pruin,     P8_41(PIN_INPUT, 1))		/* prg0_pru1_gpi4 */
	BONE_PIN(P8_41, gpio,      P8_41(PIN_INPUT, 7))
	BONE_PIN(P8_41, gpio_pu,   P8_41(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_41, gpio_pd,   P8_41(PIN_INPUT_PULLDOWN, 7))
	/* P8_42 (AB27) PRG0_PRU1_GPO5 (gpio0_68) AB27_SYS_BOOTMODE6 */
	BONE_PIN(P8_42, default,   P8_42(PIN_INPUT, 7))
	BONE_PIN(P8_42, pruout,    P8_42(PIN_OUTPUT, 0))	/* prg0_pru1_gpo5 */
	BONE_PIN(P8_42, pruin,     P8_42(PIN_INPUT, 1))		/* prg0_pru1_gpi5 */
	BONE_PIN(P8_42, gpio,      P8_42(PIN_INPUT, 7))
	BONE_PIN(P8_42, gpio_pu,   P8_42(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_42, gpio_pd,   P8_42(PIN_INPUT_PULLDOWN, 7))
	/* P8_43 (AD27) PRG0_PRU1_GPO2 (gpio0_65) AD27_PRG0_PRU1_GPO2 */
	BONE_PIN(P8_43, default,   P8_43(PIN_INPUT, 7))
	BONE_PIN(P8_43, pruout,    P8_43(PIN_OUTPUT, 0))	/* prg0_pru1_gpo2 */
	BONE_PIN(P8_43, pruin,     P8_43(PIN_INPUT, 1))		/* prg0_pru1_gpi2 */
	BONE_PIN(P8_43, gpio,      P8_43(PIN_INPUT, 7))
	BONE_PIN(P8_43, gpio_pu,   P8_43(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_43, gpio_pd,   P8_43(PIN_INPUT_PULLDOWN, 7))
	/* P8_44 (AC25) PRG0_PRU1_GPO3 (gpio0_66) AC25_PRG0_PRU1_GPO3 */
	BONE_PIN(P8_44, default,   P8_44(PIN_INPUT, 7))
	BONE_PIN(P8_44, pruout,    P8_44(PIN_OUTPUT, 0))	/* prg0_pru1_gpo3 */
	BONE_PIN(P8_44, pruin,     P8_44(PIN_INPUT, 1))		/* prg0_pru1_gpi3 */
	BONE_PIN(P8_44, gpio,      P8_44(PIN_INPUT, 7))
	BONE_PIN(P8_44, gpio_pu,   P8_44(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_44, gpio_pd,   P8_44(PIN_INPUT_PULLDOWN, 7))
	/* P8_45 (AG29) PRG0_PRU1_GPO16 (gpio0_79) AG29_PRG0_PRU1_GPO16 */
	BONE_PIN(P8_45, default,   P8_45(PIN_INPUT, 7))
	BONE_PIN(P8_45, pruout,    P8_45(PIN_OUTPUT, 0))	/* prg0_pru1_gpo16 */
	BONE_PIN(P8_45, pruin,     P8_45(PIN_INPUT, 1))		/* prg0_pru1_gpi16 */
	BONE_PIN(P8_45, gpio,      P8_45(PIN_INPUT, 7))
	BONE_PIN(P8_45, gpio_pu,   P8_45(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_45, gpio_pd,   P8_45(PIN_INPUT_PULLDOWN, 7))
	/* P8_46 (Y25) PRG0_PRU1_GPO17 (gpio0_80) Y25_SYS_BOOTMODE3 */
	BONE_PIN(P8_46, default,   P8_46(PIN_INPUT, 7))
	BONE_PIN(P8_46, pruout,    P8_46(PIN_OUTPUT, 0))	/* prg0_pru1_gpo17 */
	BONE_PIN(P8_46, pruin,     P8_46(PIN_INPUT, 1))		/* prg0_pru1_gpi17 */
	BONE_PIN(P8_46, gpio,      P8_46(PIN_INPUT, 7))
	BONE_PIN(P8_46, gpio_pu,   P8_46(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P8_46, gpio_pd,   P8_46(PIN_INPUT_PULLDOWN, 7))
	/* Full P9 header mode definitions */
	/* P9_01 - GND */
	/* P9_02 - GND */
	/* P9_03 - VOUT_3V3 */
	/* P9_04 - VOUT_3V3 */
	/* P9_05 - VIN */
	/* P9_06 - VIN */
	/* P9_07 - VOUT_SYS */
	/* P9_08 - VOUT_SYS */
	/* P9_09 - RESET# */
	/* P9_10 - POWER# */
	/* P9_11 (AC23) PRG1_PRU0_GPO0 (gpio0_1) AC23_UART0_RXD */
	BONE_PIN(P9_11, default,   P9_11(PIN_INPUT, 7))
	BONE_PIN(P9_11, pruout,    P9_11(PIN_OUTPUT, 0))	/* prg1_pru0_gpo0 */
	BONE_PIN(P9_11, pruin,     P9_11(PIN_INPUT, 1))		/* prg1_pru0_gpi0 */
	BONE_PIN(P9_11, gpio,      P9_11(PIN_INPUT, 7))
	BONE_PIN(P9_11, gpio_pu,   P9_11(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P9_11, gpio_pd,   P9_11(PIN_INPUT_PULLDOWN, 7))
	BONE_PIN(P9_11, uart,      P9_11(PIN_INPUT, 14))	/* uart0_rxd */
	/* P9_12 (AE27) PRG0_PRU0_GPO2 (gpio0_45) AE27_MCASP0_ACLKR */
	BONE_PIN(P9_12, default,   P9_12(PIN_INPUT, 7))
	BONE_PIN(P9_12, pruout,    P9_12(PIN_OUTPUT, 0))	/* prg0_pru0_gpo2 */
	BONE_PIN(P9_12, pruin,     P9_12(PIN_INPUT, 1))		/* prg0_pru0_gpi2 */
	BONE_PIN(P9_12, gpio,      P9_12(PIN_INPUT, 7))
	BONE_PIN(P9_12, gpio_pu,   P9_12(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P9_12, gpio_pd,   P9_12(PIN_INPUT_PULLDOWN, 7))
	/* P9_13 (AG22) PRG1_PRU0_GPO1 (gpio0_2) AG22_UART0_TXD */
	BONE_PIN(P9_13, default,   P9_13(PIN_INPUT, 7))
	BONE_PIN(P9_13, pruout,    P9_13(PIN_OUTPUT, 0))	/* prg1_pru0_gpo1 */
	BONE_PIN(P9_13, pruin,     P9_13(PIN_INPUT, 1))		/* prg1_pru0_gpi1 */
	BONE_PIN(P9_13, gpio,      P9_13(PIN_INPUT, 7))
	BONE_PIN(P9_13, gpio_pu,   P9_13(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P9_13, gpio_pd,   P9_13(PIN_INPUT_PULLDOWN, 7))
	BONE_PIN(P9_13, uart,      P9_13(PIN_OUTPUT, 14))	/* uart0_txd */
	/* P9_14 (U27) RGMII5_RD3 (gpio0_93) U27_EHRPWM2_A */
	BONE_PIN(P9_14, default,   P9_14(PIN_INPUT, 7))
	BONE_PIN(P9_14, gpio,      P9_14(PIN_INPUT, 7))
	BONE_PIN(P9_14, gpio_pu,   P9_14(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P9_14, gpio_pd,   P9_14(PIN_INPUT_PULLDOWN, 7))
	BONE_PIN(P9_14, pwm,       P9_14(PIN_OUTPUT, 6))	/* ehrpwm2_a */
	/* P9_15 (AD25) PRG0_PRU0_GPO4 (gpio0_47) AD25_PRG0_PRU0_GPO4 */
	BONE_PIN(P9_15, default,   P9_15(PIN_INPUT, 7))
	BONE_PIN(P9_15, pruout,    P9_15(PIN_OUTPUT, 0))	/* prg0_pru0_gpo4 */
	BONE_PIN(P9_15, pruin,     P9_15(PIN_INPUT, 1))		/* prg0_pru0_gpi4 */
	BONE_PIN(P9_15, gpio,      P9_15(PIN_INPUT, 7))
	BONE_PIN(P9_15, gpio_pu,   P9_15(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P9_15, gpio_pd,   P9_15(PIN_INPUT_PULLDOWN, 7))
	/* P9_16 (U24) RGMII5_RD2 (gpio0_94) U24_EHRPWM2_B */
	BONE_PIN(P9_16, default,   P9_16(PIN_INPUT, 7))
	BONE_PIN(P9_16, pruout,    P9_16(PIN_OUTPUT, 0))
	BONE_PIN(P9_16, pruin,     P9_16(PIN_INPUT, 1))
	BONE_PIN(P9_16, gpio,      P9_16(PIN_INPUT, 7))
	BONE_PIN(P9_16, gpio_pu,   P9_16(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P9_16, gpio_pd,   P9_16(PIN_INPUT_PULLDOWN, 7))
	BONE_PIN(P9_16, pwm,       P9_16(PIN_OUTPUT, 6))	/* ehrpwm2_b */
	/* P9_17 (AC21/AA3) PRG1_PRU1_GPO7/SPI0_D1 (gpio0_28/gpio0_115) AC21_AA3 */
	BONE_PIN(P9_17, default,   P9_17A(PIN_INPUT, 7) P9_17B(PIN_INPUT, 7))
	BONE_PIN(P9_17, pruout,    P9_17A(PIN_OUTPUT, 0) P9_17B(PIN_INPUT, 7))	/* prg1_pru1_gpo7 */
	BONE_PIN(P9_17, pruin,     P9_17A(PIN_INPUT, 1) P9_17B(PIN_INPUT, 7))	/* prg1_pru1_gpi7 */
	BONE_PIN(P9_17, gpio,      P9_17A(PIN_INPUT, 7) P9_17B(PIN_INPUT, 7))	/* gpio0_28 */
	BONE_PIN(P9_17, gpio_pu,   P9_17A(PIN_INPUT_PULLUP, 7) P9_17B(PIN_INPUT, 7))
	BONE_PIN(P9_17, gpio_pd,   P9_17A(PIN_INPUT_PULLDOWN, 7) P9_17B(PIN_INPUT, 7))
	BONE_PIN(P9_17, i2c,       P9_17A(PIN_INPUT, 7) P9_17B(PIN_INPUT_PULLUP, 2))	/* i2c6_scl */
	BONE_PIN(P9_17, spi,       P9_17A(PIN_OUTPUT, 4) P9_17B(PIN_INPUT, 7))	/* spi6_cs0 */
	/* P9_18 (AH22/Y2) PRG1_PRU1_GPO19/SPI1_D1 (gpio0_40/gpio0_120) AH22_Y2 */
	BONE_PIN(P9_18, default,   P9_18A(PIN_INPUT, 7) P9_18B(PIN_INPUT, 7))
	BONE_PIN(P9_18, pruout,    P9_18A(PIN_OUTPUT, 0) P9_18B(PIN_INPUT, 7))	/* prg1_pru1_gpo19 */
	BONE_PIN(P9_18, pruin,     P9_18A(PIN_INPUT, 1) P9_18B(PIN_INPUT, 7))	/* prg1_pru1_gpi19 */
	BONE_PIN(P9_18, gpio,      P9_18A(PIN_INPUT, 7) P9_18B(PIN_INPUT, 7))	/* gpio0_40 */
	BONE_PIN(P9_18, gpio_pu,   P9_18A(PIN_INPUT_PULLUP, 7) P9_18B(PIN_INPUT, 7))
	BONE_PIN(P9_18, gpio_pd,   P9_18A(PIN_INPUT_PULLDOWN, 7) P9_18B(PIN_INPUT, 7))
	BONE_PIN(P9_18, i2c,       P9_18A(PIN_INPUT, 7) P9_18B(PIN_INPUT_PULLUP, 2))	/* i2c6_sda */
	BONE_PIN(P9_18, spi,       P9_18A(PIN_INPUT, 4) P9_18B(PIN_INPUT, 7))	/* spi6_d1 (tested PIN_INPUT) */
	/* P9_19 (W5/AF29) MCAN0_RX/PRG0_PRU1_GPO15 (gpio1_1/gpio0_78) W5_AF29 */
	BONE_PIN(P9_19, default,   P9_19A(PIN_INPUT, 7) P9_19B(PIN_INPUT, 7))
	BONE_PIN(P9_19, pruout,    P9_19A(PIN_INPUT, 7) P9_19B(PIN_OUTPUT, 0))	/* prg0_pru1_gpo15 */
	BONE_PIN(P9_19, pruin,     P9_19A(PIN_INPUT, 7) P9_19B(PIN_INPUT, 1))	/* prg0_pru1_gpi15 */
	BONE_PIN(P9_19, can,       P9_19A(PIN_INPUT, 0) P9_19B(PIN_INPUT, 7))	/* mcan0_rx */
	BONE_PIN(P9_19, gpio,      P9_19A(PIN_INPUT, 7) P9_19B(PIN_INPUT, 7))	/* gpio1_1 */
	BONE_PIN(P9_19, gpio_pu,   P9_19A(PIN_INPUT_PULLUP, 7) P9_19B(PIN_INPUT, 7))
	BONE_PIN(P9_19, gpio_pd,   P9_19A(PIN_INPUT_PULLDOWN, 7) P9_19B(PIN_INPUT, 7))
	BONE_PIN(P9_19, i2c,       P9_19A(PIN_INPUT_PULLUP, 4) P9_19B(PIN_INPUT, 7))	/* i2c2_scl */
	/* P9_20 (W6/AE25) MCAN0_TX/PRG0_PRU1_GPO14 (gpio1_2/gpio0_77) W6_AE25 */
	BONE_PIN(P9_20, default,   P9_20A(PIN_INPUT, 7) P9_20B(PIN_INPUT, 7))
	BONE_PIN(P9_20, pruout,    P9_20A(PIN_INPUT, 7) P9_20B(PIN_OUTPUT, 0))	/* prg0_pru1_gpo14 */
	BONE_PIN(P9_20, pruin,     P9_20A(PIN_INPUT, 7) P9_20B(PIN_INPUT, 1))	/* prg0_pru1_gpi14 */
	BONE_PIN(P9_20, can,       P9_20A(PIN_OUTPUT, 0) P9_20B(PIN_INPUT, 7))	/* mcan0_tx */
	BONE_PIN(P9_20, gpio,      P9_20A(PIN_INPUT, 7) P9_20B(PIN_INPUT, 7))	/* gpio1_2 */
	BONE_PIN(P9_20, gpio_pu,   P9_20A(PIN_INPUT_PULLUP, 7) P9_20B(PIN_INPUT, 7))
	BONE_PIN(P9_20, gpio_pd,   P9_20A(PIN_INPUT_PULLDOWN, 7) P9_20B(PIN_INPUT, 7))
	BONE_PIN(P9_20, i2c,       P9_20A(PIN_INPUT_PULLUP, 4) P9_20B(PIN_INPUT, 7))	/* i2c2_sda */
	/* P9_21 (AJ22/U28) PRG1_PRU1_GPO18/RGMII5_TD0 (gpio0_39/gpio0_90) AJ22_U28 */
	BONE_PIN(P9_21, default,   P9_21A(PIN_INPUT, 7) P9_21B(PIN_INPUT, 7))
	BONE_PIN(P9_21, pruout,    P9_21A(PIN_OUTPUT, 0) P9_21B(PIN_INPUT, 7))	/* prg1_pru1_gpo18 */
	BONE_PIN(P9_21, pruin,     P9_21A(PIN_INPUT, 1) P9_21B(PIN_INPUT, 7))	/* prg1_pru1_gpi18 */
	BONE_PIN(P9_21, gpio,      P9_21A(PIN_INPUT, 7) P9_21B(PIN_INPUT, 7))	/* gpio0_39 */
	BONE_PIN(P9_21, gpio_pu,   P9_21A(PIN_INPUT_PULLUP, 7) P9_21B(PIN_INPUT, 7))
	BONE_PIN(P9_21, gpio_pd,   P9_21A(PIN_INPUT_PULLDOWN, 7) P9_21B(PIN_INPUT, 7))
	BONE_PIN(P9_21, pwm,       P9_21A(PIN_INPUT, 7) P9_21B(PIN_OUTPUT, 6))	/* ehrpwm1_a */
	BONE_PIN(P9_21, spi,       P9_21A(PIN_OUTPUT, 4) P9_21B(PIN_INPUT, 7))	/* spi6_d0 */
	/* P9_22 (AC22/U29) PRG1_PRU1_GPO17/RGMII5_TXC (gpio0_38/gpio0_91) AC22_U29 */
	BONE_PIN(P9_22, default,   P9_22A(PIN_INPUT, 7) P9_22B(PIN_INPUT, 7))
	BONE_PIN(P9_22, pruout,    P9_22A(PIN_OUTPUT, 0) P9_22B(PIN_INPUT, 7))	/* prg1_pru1_gpo17 */
	BONE_PIN(P9_22, pruin,     P9_22A(PIN_INPUT, 1) P9_22B(PIN_INPUT, 7))	/* prg1_pru1_gpi17 */
	BONE_PIN(P9_22, gpio,      P9_22A(PIN_INPUT, 7) P9_22B(PIN_INPUT, 7))	/* gpio0_38 */
	BONE_PIN(P9_22, gpio_pu,   P9_22A(PIN_INPUT_PULLUP, 7) P9_22B(PIN_INPUT, 7))
	BONE_PIN(P9_22, gpio_pd,   P9_22A(PIN_INPUT_PULLDOWN, 7) P9_22B(PIN_INPUT, 7))
	BONE_PIN(P9_22, i2c,       P9_22A(PIN_INPUT, 7) P9_22B(PIN_INPUT_PULLUP, 2))	/* i2c6_scl */
	BONE_PIN(P9_22, pwm,       P9_22A(PIN_INPUT, 7) P9_22B(PIN_OUTPUT, 6))	/* ehrpwm1_b */
	BONE_PIN(P9_22, spi,       P9_22A(PIN_OUTPUT, 4) P9_22B(PIN_INPUT, 7))	/* spi6_clk */
	/* P9_23 (AG20) PRG1_PRU0_GPO9 (gpio0_10) AG20_SPI6_CS1 */
	BONE_PIN(P9_23, default,   P9_23(PIN_INPUT, 7))
	BONE_PIN(P9_23, pruout,    P9_23(PIN_OUTPUT, 0))	/* prg1_pru0_gpo9 */
	BONE_PIN(P9_23, pruin,     P9_23(PIN_INPUT, 1))		/* prg1_pru0_gpi9 */
	BONE_PIN(P9_23, gpio,      P9_23(PIN_INPUT, 7))
	BONE_PIN(P9_23, gpio_pu,   P9_23(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P9_23, gpio_pd,   P9_23(PIN_INPUT_PULLDOWN, 7))
	BONE_PIN(P9_23, spi,       P9_23(PIN_OUTPUT, 4))	/* spi6_cs1 */
	/* P9_24 (Y5/AJ24) SPI1_D0/PRG1_PRU0_GPO12 (gpio0_119/gpio0_13) Y5_AJ24 */
	BONE_PIN(P9_24, default,   P9_24A(PIN_INPUT, 7) P9_24B(PIN_INPUT, 7))
	BONE_PIN(P9_24, pruout,    P9_24A(PIN_INPUT, 7) P9_24B(PIN_OUTPUT, 0))	/* prg1_pru0_gpo12 */
	BONE_PIN(P9_24, pruin,     P9_24A(PIN_INPUT, 7) P9_24B(PIN_INPUT, 1))	/* prg1_pru0_gpi12 */
	BONE_PIN(P9_24, can,       P9_24A(PIN_INPUT, 7) P9_24B(PIN_INPUT, 6) )	/* mcan4_rx */
	BONE_PIN(P9_24, gpio,      P9_24A(PIN_INPUT, 7) P9_24B(PIN_INPUT, 7))	/* gpio0_119 */
	BONE_PIN(P9_24, gpio_pu,   P9_24A(PIN_INPUT_PULLUP, 7) P9_24B(PIN_INPUT, 7))
	BONE_PIN(P9_24, gpio_pd,   P9_24A(PIN_INPUT_PULLDOWN, 7) P9_24B(PIN_INPUT, 7))
	BONE_PIN(P9_24, i2c,       P9_24A(PIN_INPUT_PULLUP, 2) P9_24B(PIN_INPUT, 7))	/* i2c4_scl */
	BONE_PIN(P9_24, uart,      P9_24A(PIN_OUTPUT, 3) P9_24B(PIN_INPUT, 7))	/* uart2_txd */
	/* P9_25 (AC4/W26) UART1_CTSn/RGMII6_RXC (gpio0_127/gpio0_104) AC4_W26 */
	BONE_PIN(P9_25, default,   P9_25A(PIN_INPUT, 7) P9_25B(PIN_INPUT, 7))
	BONE_PIN(P9_25, gpio,      P9_25A(PIN_INPUT, 7) P9_25B(PIN_INPUT, 7))	/* gpio0_127 */
	BONE_PIN(P9_25, gpio_pu,   P9_25A(PIN_INPUT_PULLUP, 7) P9_25B(PIN_INPUT, 7))
	BONE_PIN(P9_25, gpio_pd,   P9_25A(PIN_INPUT_PULLDOWN, 7) P9_25B(PIN_INPUT, 7))
	BONE_PIN(P9_25, pwm,       P9_25A(PIN_INPUT, 7) P9_25B(PIN_OUTPUT, 6))	/* ehrpwm4_b */
	BONE_PIN(P9_25, qep,       P9_25A(PIN_INPUT, 5) P9_25B(PIN_INPUT, 7))	/* eqep0_s */
	/* P9_26 (Y1/AF24) SPI1_CLK/PRG1_PRU0_GPO11 (gpio0_118/gpio0_12) Y1_AF24 */
	BONE_PIN(P9_26, default,   P9_26A(PIN_INPUT, 7) P9_26B(PIN_INPUT, 7))
	BONE_PIN(P9_26, pruout,    P9_26A(PIN_INPUT, 7) P9_26B(PIN_OUTPUT, 0))	/* prg1_pru0_gpo11 */
	BONE_PIN(P9_26, pruin,     P9_26A(PIN_INPUT, 7) P9_26B(PIN_INPUT, 1))	/* prg1_pru0_gpi11 */
	BONE_PIN(P9_26, can,       P9_26A(PIN_INPUT, 7) P9_26B(PIN_OUTPUT, 6) )	/* mcan4_tx */
	BONE_PIN(P9_26, gpio,      P9_26A(PIN_INPUT, 7) P9_26B(PIN_INPUT, 7))	/* gpio0_118 */
	BONE_PIN(P9_26, gpio_pu,   P9_26A(PIN_INPUT_PULLUP, 7) P9_26B(PIN_INPUT, 7))
	BONE_PIN(P9_26, gpio_pd,   P9_26A(PIN_INPUT_PULLDOWN, 7) P9_26B(PIN_INPUT, 7))
	BONE_PIN(P9_26, i2c,       P9_26A(PIN_INPUT_PULLUP, 2) P9_26B(PIN_INPUT, 7))	/* i2c4_sda */
	BONE_PIN(P9_26, uart,      P9_26A(PIN_INPUT, 3) P9_26B(PIN_INPUT, 7))	/* uart2_rxd */
	/* P9_27 (AD26/AB1) PRG0_PRU0_GPO3/UART0_RTSn (gpio0_46/gpio0_124) AD26_AB1 */
	BONE_PIN(P9_27, default,   P9_27A(PIN_INPUT, 7) P9_27B(PIN_INPUT, 7))
	BONE_PIN(P9_27, pruout,    P9_27A(PIN_OUTPUT, 0) P9_27B(PIN_INPUT, 7))	/* prg0_pru0_gpo3 */
	BONE_PIN(P9_27, pruin,     P9_27A(PIN_INPUT, 1) P9_27B(PIN_INPUT, 7))	/* prg0_pru0_gpi3 */
	BONE_PIN(P9_27, gpio,      P9_27A(PIN_INPUT, 7) P9_27B(PIN_INPUT, 7))	/* gpio0_46 */
	BONE_PIN(P9_27, gpio_pu,   P9_27A(PIN_INPUT_PULLUP, 7) P9_27B(PIN_INPUT, 7))
	BONE_PIN(P9_27, gpio_pd,   P9_27A(PIN_INPUT_PULLDOWN, 7) P9_27B(PIN_INPUT, 7))
	BONE_PIN(P9_27, qep,       P9_27A(PIN_INPUT, 7) P9_27B(PIN_INPUT, 5))	/* eqep0_b */
	/* P9_28 (U2/AF28) ECAP0_IN_APWM_OUT/PRG0_PRU0_GPO0 (gpio1_11/gpio0_43) U2_AF28 */
	BONE_PIN(P9_28, default,   P9_28A(PIN_INPUT, 7) P9_28B(PIN_INPUT, 7))
	BONE_PIN(P9_28, pruout,    P9_28A(PIN_INPUT, 7) P9_28B(PIN_OUTPUT, 0))	/* prg0_pru0_gpo0 */
	BONE_PIN(P9_28, pruin,     P9_28A(PIN_INPUT, 7) P9_28B(PIN_INPUT, 1))	/* prg0_pru0_gpi0 */
	BONE_PIN(P9_28, gpio,      P9_28A(PIN_INPUT, 7) P9_28B(PIN_INPUT, 7))	/* gpio1_11 */
	BONE_PIN(P9_28, gpio_pu,   P9_28A(PIN_INPUT_PULLUP, 7) P9_28B(PIN_INPUT, 7))
	BONE_PIN(P9_28, gpio_pd,   P9_28A(PIN_INPUT_PULLDOWN, 7) P9_28B(PIN_INPUT, 7))
	BONE_PIN(P9_28, spi,       P9_28A(PIN_OUTPUT, 6) P9_28B(PIN_INPUT, 7))	/* spi7_cs0 */
	/* P9_29 (V5/AB25) TIMER_IO1/PRG0_PRU0_GPO10 (gpio1_14/gpio0_53) V5_AB25 */
	BONE_PIN(P9_29, default,   P9_29A(PIN_INPUT, 7) P9_29B(PIN_INPUT, 7))
	BONE_PIN(P9_29, pruout,    P9_29A(PIN_INPUT, 7) P9_29B(PIN_OUTPUT, 0))	/* prg0_pru0_gpo10 */
	BONE_PIN(P9_29, pruin,     P9_29A(PIN_INPUT, 7) P9_29B(PIN_INPUT, 1))	/* prg0_pru0_gpi10 */
	BONE_PIN(P9_29, gpio,      P9_29A(PIN_INPUT, 7) P9_29B(PIN_INPUT, 7))	/* gpio1_14 */
	BONE_PIN(P9_29, gpio_pu,   P9_29A(PIN_INPUT_PULLUP, 7) P9_29B(PIN_INPUT, 7))
	BONE_PIN(P9_29, gpio_pd,   P9_29A(PIN_INPUT_PULLDOWN, 7) P9_29B(PIN_INPUT, 7))
	/* https://forum.beagleboard.org/t/bbai-64-bone-spi1-0-overlay-development-and-debug/34113/10 */
	BONE_PIN(P9_29, spi,       P9_29A(PIN_INPUT, 6) P9_29B(PIN_INPUT, 7))   /* spi7_d1 (tested PIN_INPUT) */
	/* P9_30 (V6/AE28) TIMER_IO0/PRG0_PRU0_GPO1 (gpio1_13/gpio0_44) V6_AE28 */
	BONE_PIN(P9_30, default,   P9_30A(PIN_INPUT, 7) P9_30B(PIN_INPUT, 7))
	BONE_PIN(P9_30, pruout,    P9_30A(PIN_INPUT, 7) P9_30B(PIN_OUTPUT, 0))	/* prg0_pru0_gpo1 */
	BONE_PIN(P9_30, pruin,     P9_30A(PIN_INPUT, 7) P9_30B(PIN_INPUT, 1))	/* prg0_pru0_gpi1 */
	BONE_PIN(P9_30, gpio,      P9_30A(PIN_INPUT, 7) P9_30B(PIN_INPUT, 7))	/* gpio1_13 */
	BONE_PIN(P9_30, gpio_pu,   P9_30A(PIN_INPUT_PULLUP, 7) P9_30B(PIN_INPUT, 7))
	BONE_PIN(P9_30, gpio_pd,   P9_30A(PIN_INPUT_PULLDOWN, 7) P9_30B(PIN_INPUT, 7))
	BONE_PIN(P9_30, spi,       P9_30A(PIN_OUTPUT, 6) P9_30B(PIN_INPUT, 7))	/* spi7_d0 */
	/* P9_31 (U3/AB26) EXT_REFCLK1/PRG0_PRU0_GPO9 (gpio1_12/gpio0_52) U3_AB26 */
	BONE_PIN(P9_31, default,   P9_31A(PIN_INPUT, 7) P9_31B(PIN_INPUT, 7))
	BONE_PIN(P9_31, pruout,    P9_31A(PIN_INPUT, 7) P9_31B(PIN_OUTPUT, 0))	/* prg0_pru0_gpo9 */
	BONE_PIN(P9_31, pruin,     P9_31A(PIN_INPUT, 7) P9_31B(PIN_INPUT, 1))	/* prg0_pru0_gpi9 */
	BONE_PIN(P9_31, gpio,      P9_31A(PIN_INPUT, 7) P9_31B(PIN_INPUT, 7))	/* gpio1_12 */
	BONE_PIN(P9_31, gpio_pu,   P9_31A(PIN_INPUT_PULLUP, 7) P9_31B(PIN_INPUT, 7))
	BONE_PIN(P9_31, gpio_pd,   P9_31A(PIN_INPUT_PULLDOWN, 7) P9_31B(PIN_INPUT, 7))
	BONE_PIN(P9_31, spi,       P9_31A(PIN_OUTPUT, 6) P9_31B(PIN_INPUT, 7))	/* spi7_clk */
	/* P9_32 - ADC_REF_OUT */
	/* P9_33 (K24/AC28) MCU_ADC0_AIN4/PRG0_PRU0_GPO7 (gpio0_50) K24_AC28 */
	BONE_PIN(P9_33, default,   P9_33B(PIN_INPUT, 7))
	BONE_PIN(P9_33, pruout,    P9_33B(PIN_OUTPUT, 0))	/* prg0_pru0_gpo7 */
	BONE_PIN(P9_33, pruin,     P9_33B(PIN_INPUT, 1))	/* prg0_pru0_gpi7 */
	BONE_PIN(P9_33, gpio,      P9_33B(PIN_INPUT, 7))
	BONE_PIN(P9_33, gpio_pu,   P9_33B(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P9_33, gpio_pd,   P9_33B(PIN_INPUT_PULLDOWN, 7))
	/* P9_34 - ADC_GND */
	/* P9_35 (K29/AH27) MCU_ADC0_AIN6/PRG0_PRU0_GPO12 (gpio0_55) K29_AH27 */
	BONE_PIN(P9_35, default,   P9_35B(PIN_INPUT, 7))
	BONE_PIN(P9_35, pruout,    P9_35B(PIN_OUTPUT, 0))	/* prg0_pru0_gpo12 */
	BONE_PIN(P9_35, pruin,     P9_35B(PIN_INPUT, 1))	/* prg0_pru0_gpi12 */
	BONE_PIN(P9_35, gpio,      P9_35B(PIN_INPUT, 7))
	BONE_PIN(P9_35, gpio_pu,   P9_35B(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P9_35, gpio_pd,   P9_35B(PIN_INPUT_PULLDOWN, 7))
	/* P9_36 (K27/AH29) MCU_ADC0_AIN5/PRG0_PRU0_GPO13 (gpio0_56) K27_AH29 */
	BONE_PIN(P9_36, default,   P9_36B(PIN_INPUT, 7))
	BONE_PIN(P9_36, pruout,    P9_36B(PIN_OUTPUT, 0))	/* prg0_pru0_gpo13 */
	BONE_PIN(P9_36, pruin,     P9_36B(PIN_INPUT, 1))	/* prg0_pru0_gpi13 */
	BONE_PIN(P9_36, gpio,      P9_36B(PIN_INPUT, 7))
	BONE_PIN(P9_36, gpio_pu,   P9_36B(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P9_36, gpio_pd,   P9_36B(PIN_INPUT_PULLDOWN, 7))
	/* P9_37 (K28/AG28) MCU_ADC0_AIN2/PRG0_PRU0_GPO14 (gpio0_57) K28_AG28 */
	BONE_PIN(P9_37, default,   P9_37B(PIN_INPUT, 7))
	BONE_PIN(P9_37, pruout,    P9_37B(PIN_OUTPUT, 0))	/* prg0_pru0_gpo14 */
	BONE_PIN(P9_37, pruin,     P9_37B(PIN_INPUT, 1))	/* prg0_pru0_gpi14 */
	BONE_PIN(P9_37, gpio,      P9_37B(PIN_INPUT, 7))
	BONE_PIN(P9_37, gpio_pu,   P9_37B(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P9_37, gpio_pd,   P9_37B(PIN_INPUT_PULLDOWN, 7))
	BONE_PIN(P9_37, uart,      P9_37A(PIN_INPUT, 7) P9_37B(PIN_INPUT, 8))	/* uart4_rxd */
	/* P9_38 (L28/AG27) MCU_ADC0_AIN3/PRG0_PRU0_GPO15 (gpio0_58) L28_AG27 */
	BONE_PIN(P9_38, default,   P9_38B(PIN_INPUT, 7))
	BONE_PIN(P9_38, pruout,    P9_38B(PIN_OUTPUT, 0))	/* prg0_pru0_gpo15 */
	BONE_PIN(P9_38, pruin,     P9_38B(PIN_INPUT, 1))	/* prg0_pru0_gpi15 */
	BONE_PIN(P9_38, gpio,      P9_38B(PIN_INPUT, 7))
	BONE_PIN(P9_38, gpio_pu,   P9_38B(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P9_38, gpio_pd,   P9_38B(PIN_INPUT_PULLDOWN, 7))
	BONE_PIN(P9_38, uart,      P9_38A(PIN_INPUT, 7) P9_38B(PIN_OUTPUT, 8))	/* uart4_txd */
	/* P9_39 (K25/AJ28) MCU_ADC0_AIN0/PRG0_PRU0_GPO11 (gpio0_54) K25_AJ28 */
	BONE_PIN(P9_39, default,   P9_39B(PIN_INPUT, 7))
	BONE_PIN(P9_39, pruout,    P9_39B(PIN_OUTPUT, 0))	/* prg0_pru0_gpo11 */
	BONE_PIN(P9_39, pruin,     P9_39B(PIN_INPUT, 1))	/* prg0_pru0_gpi11 */
	BONE_PIN(P9_39, gpio,      P9_39B(PIN_INPUT, 7))
	BONE_PIN(P9_39, gpio_pu,   P9_39B(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P9_39, gpio_pd,   P9_39B(PIN_INPUT_PULLDOWN, 7))
	/* P9_40 (K26/AA26) MCU_ADC0_AIN1/PRG0_PRU1_GPO18 (gpio0_81) K26_AA26 */
	BONE_PIN(P9_40, default,   P9_40B(PIN_INPUT, 7))
	BONE_PIN(P9_40, pruout,    P9_40B(PIN_OUTPUT, 0))	/* prg0_pru1_gpo18 */
	BONE_PIN(P9_40, pruin,     P9_40B(PIN_INPUT, 1))	/* prg0_pru1_gpi18 */
	BONE_PIN(P9_40, gpio,      P9_40B(PIN_INPUT, 7))
	BONE_PIN(P9_40, gpio_pu,   P9_40B(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P9_40, gpio_pd,   P9_40B(PIN_INPUT_PULLDOWN, 7))
	BONE_PIN(P9_40, uart,      P9_40B(PIN_INPUT, 14))	/* uart2_rxd */
	/* P9_41 (AD5) UART1_RTSn (gpio1_0) AD5_EQEP0_I */
	BONE_PIN(P9_41, default,   P9_41(PIN_INPUT, 7))
	BONE_PIN(P9_41, pruout,    P9_41(PIN_OUTPUT, 0))
	BONE_PIN(P9_41, pruin,     P9_41(PIN_INPUT, 1))
	BONE_PIN(P9_41, gpio,      P9_41(PIN_INPUT, 7))
	BONE_PIN(P9_41, gpio_pu,   P9_41(PIN_INPUT_PULLUP, 7))
	BONE_PIN(P9_41, gpio_pd,   P9_41(PIN_INPUT_PULLDOWN, 7))
	BONE_PIN(P9_41, qep,       P9_41(PIN_INPUT, 5))	/* eqep0_i */
	/* P9_42 (AC2/AJ21) UART0_CTSn/PRG1_PRU0_GPO17 (gpio0_123/gpio0_18) AC2_AJ21 */
	BONE_PIN(P9_42, default,   P9_42A(PIN_INPUT, 7) P9_42B(PIN_INPUT, 7))
	BONE_PIN(P9_42, pruout,    P9_42A(PIN_INPUT, 7) P9_42B(PIN_OUTPUT, 0))	/* prg1_pru0_gpo17 */
	BONE_PIN(P9_42, pruin,     P9_42A(PIN_INPUT, 7) P9_42B(PIN_INPUT, 1))	/* prg1_pru0_gpi17 */
	BONE_PIN(P9_42, can,       P9_42A(PIN_INPUT, 7) P9_42B(PIN_OUTPUT, 6) )	/* mcan5_tx */
	BONE_PIN(P9_42, gpio,      P9_42A(PIN_INPUT, 7) P9_42B(PIN_INPUT, 7))	/* gpio0_123 */
	BONE_PIN(P9_42, gpio_pu,   P9_42A(PIN_INPUT_PULLUP, 7) P9_42B(PIN_INPUT, 7))
	BONE_PIN(P9_42, gpio_pd,   P9_42A(PIN_INPUT_PULLDOWN, 7) P9_42B(PIN_INPUT, 7))
	BONE_PIN(P9_42, qep,       P9_42A(PIN_INPUT, 5) P9_42B(PIN_INPUT, 7))	/* eqep0_a */
	/* P9_43 - GND */
	/* P9_44 - GND */
	/* P9_45 - GND */
	/* P9_46 - GND */
	// Additional Pinmux for UART6 (used by BONE-UART4)
	uart6_pins_default: uart6-pins-default {
			P9_14(PIN_INPUT, 3)   /* UART6 RX */
			P9_16(PIN_OUTPUT, 3)  /* UART6 TX */
					P8_19(PIN_INPUT, 7)
 * Mytra Peripheral Configuration for BeagleBone AI-64
 * This file maps the UART, CAN, GPIO peripherals to their respective hardware resources,
 * such as pins, power domains, and symlink aliases.
 * Structure of Configuration:
 * <label>: &<reference_node> {
 *     pinctrl-names: Defines the pinctrl state (e.g., "default").
 *     pinctrl-0:     Specifies the pinmux settings for this peripheral.
 *     symlink:       Defines the alias used for this peripheral (e.g., bone/uart/X).
 *     power-domains: Specifies the power domain for the UART peripheral.
 *     status:        Enables ("okay") or disables ("disabled") the peripheral.
 * Notes:
 * - Labels (e.g., bone_uart_0, bone_uart_1) are logical names used for referencing.
 * - References (e.g., &main_uart0, &main_uart2) point to the base hardware definitions in the SoC-level .dtsi file as defined in: k3-j721e-main.dtsi
 * - Symlinks (e.g., bone/uart/1) naming convention based on RTOS board schematic outlined here: https://hub.allspice.io/Mytra/RTOS-Board-I/src/branch/main/RTOS-Board-I.kicad_sch
// UART configuration for BeagleBone AI-64
/* BeagleBoard AI64 UART Port Mapping Table as defined here: https://docs.beagleboard.org/boards/capes/cape-interface-spec.html#id48
 * | Bone Bus        | DT Symbol   | AI-64   | TX      | RX      | Overlay             |
 * | /dev/bone/uart/0| bone_uart_0 | MAIN_UART0 | P9.24 | P9.26  | Console Debug       |
 * | /dev/bone/uart/1| bone_uart_1 | MAIN_UART2 | P9.24 | P9.26  | BONE-UART1          |
 * | /dev/bone/uart/2| bone_uart_2 | n/a       | P9.21 | P9.22  | BONE-UART2          |
 * | /dev/bone/uart/3| bone_uart_3 | n/a       | P9.42 | n/a    | BONE-UART3          |
 * | /dev/bone/uart/4| bone_uart_4 | MAIN_UART0| P9.13 | P9.11  | BONE-UART4          |
 * | /dev/bone/uart/5| bone_uart_5 | MAIN_UART5| P8.37 | P8.38  | BONE-UART5          |
 * | /dev/bone/uart/6| bone_uart_6 | MAIN_UART8| P8.29 | P8.30  | BONE-UART6          |
 * | /dev/bone/uart/7| bone_uart_7 | MAIN_UART2| P8.34 | P8.22  | BONE-UART7          |
 * Notes:
/* UART 1: Peripheral on Pins P9_24 (TX) and P9_26 (RX) */
bone_uart_1: &main_uart2 {
     * Description:
     * - Symlink "bone/uart/1" corresponds to BONE_UART1_TX an BONE_UART1_RX as defined here: https://hub.allspice.io/Mytra/RTOS-Board-I/src/branch/main/RTOS-Board-I.kicad_sch
     * Notes:
     * - UART is enabled in BONE-UART1.dts
    pinctrl-0 = <
        &P9_24_uart_pin /* TX */
        &P9_26_uart_pin /* RX */
    symlink = "bone/uart/1";
/* UART 2: Peripheral on Pins P8_37 (TX) and P8_38 (RX) */
bone_uart_2: &main_uart5 {
     * Description:
     * - Symlink "bone/uart/2" corresponds to BONE_UART2_TX an BONE_UART2_RX as defined here: https://hub.allspice.io/Mytra/RTOS-Board-I/src/branch/main/RTOS-Board-I.kicad_sch
     * Notes:
     * - UART is enabled in BONE-UART2.dts
    pinctrl-0 = <
        &P8_37_uart_pin /* TX */
        &P8_38_uart_pin /* RX */
    symlink = "bone/uart/2";
/* UART 3: Peripheral on Pins P8_29 (TX) and P8_28 (RX) */
bone_uart_3: &main_uart8 {
     * Description:
     * - Symlink "bone/uart/2" corresponds to BONE_UART3_TX an BONE_UART3_RX as defined here: https://hub.allspice.io/Mytra/RTOS-Board-I/src/branch/main/RTOS-Board-I.kicad_sch
     * Notes:
     * - UART is enabled in BONE-UART3.dts
    pinctrl-0 = <
        &P8_29_uart_pin /* TX */
        &P8_28_uart_pin /* RX */
    symlink = "bone/uart/3";
/* UART4 Configuration */
bone_uart_4: &main_uart6 {
	pinctrl-0 = <&uart6_pins_default>;
	symlink = "bone/uart/4";
	status = "disabled"; // Default disabled; enabled via overlay
 * Notes:
     * Description:
     * Notes:
    pinctrl-0 = <
     * Description:
     * Notes:
    pinctrl-0 = <
     * Description:
     * Notes:
    pinctrl-0 = <
     * Description:
     * Notes:
    pinctrl-0 = <
// GPIO configuration for BeagleBone AI-64
/* BeagleBoard AI-64 GPIO Mapping Table as defined here:
 * https://docs.beagleboard.org/boards/capes/cape-interface-spec.html#digital-gpio
 * | SYSFS link           | AI-64     | Header Pin |
 * | /sys/class/leds/P8_19| gpio0_88  | P8.19      |
 * | /sys/class/leds/P8_33| gpio0_25  | P8.33      |
 * Notes:
 * - The important fields are the AI-64 values, which map to the physical pins
 *   on the board and cannot be renamed or changed.
 * - Header pin specifications come from:
 *   https://hub.allspice.io/Mytra/RTOS-Board-I/src/branch/main/RTOS-Board-I.kicad_sch
&main_gpio0 {
cc: @benedict.hewson @willtmakinen
Ok a couple of things to check. Firstly is using mcan0 and mcan4 make sure the alternative pin muxing for the shared pins are set to GPIO input or un-expected stuff could happen.
I am also not sure the symlink clause has any effect for the CAN peripherals.
However it should be noted that the interface numbering will depend on the order that the modules are enabled (and not the symlink), also if you decide to disable one of the CAN modules or add one, the ordering will change yet again. This could be why your testing failed. I assume you had terminating resistors.
To get around this I added a udev rule such that the interface name more closely matched the hardware name. Of course you can change the name to anything you wish but suggest keeping it aligned with the hardware peripheral.
I created /etc/udev/rules.d/11-can.rules
KERNELS=="2701000.can", ACTION=="add", NAME="CAN0"
KERNELS=="2741000.can", ACTION=="add", NAME="CAN4"
KERNELS=="2761000.can", ACTION=="add", NAME="CAN6"
KERNELS=="2781000.can", ACTION=="add", NAME="CAN8"
KERNELS=="2751000.can", ACTION=="add", NAME="CAN5"
KERNELS=="2771000.can", ACTION=="add", NAME="CAN7"
Thanks for the follow up @benedict.hewson , these are the notes from my investigation, and some additional questions:
Response to your point about checking the pinouts for mcan0 and mcan4:
Just to make a clarification, we are using main_mcan0, main_mcan5, main_mcan6 and main_mcan7 as outlined in the peripheral configuration code that I’ve left in the Additonal Information → Peripheral configuration section. But for main_mcan0, we have defined the shared pin to PIN_INPUT, mode 0 (GPIO) as outlined below:
Question:
Is the pinmux mode 7 (Default/GPIO) for CAN valid ? Shouldn’t the pinmux mode be mode 6 (CAN) for BeagleBone AI-64 which uses TI J721E-family TDA4VM system-on-chip (SoC) ? I see throughout the pinmux configuration in our k3-j721e-beagleboneai64-bone-buses.dtsi the pin mode varies between 6 and 7 for the CAN pins that we’ve defined:
ex. main_mcan5: Seems correct with the pinmux configured to mode 6:
ex. main_mcan6: Seems incorrect with the pinmux configured to mode 6 an 7:
A lot of the other CAN pinmux modes follow a similar pattern by defining one or both pinmux modes to 7, which seems incorrect. This is based on my understanding of Pinmux modes from this table:
Peripheral configuration:
As defined in /k3-j721e-beagleboneai64-bone-buses.dtsi:
     * Description:
     * Notes:
    pinctrl-0 = <
     * Description:
     * Notes:
    pinctrl-0 = <
     * Description:
     * Notes:
    pinctrl-0 = <
     * Description:
     * Notes:
    pinctrl-0 = <
In the mean time I’m going try changing the pinmux modes to 6, set the udev rules, and test on my bench.
Thank you for your help @benedict.hewson - I was able to get CAN to work by following your advice and making sure the pinmux modes matched the spreadsheet: https://docs.google.com/spreadsheets/d/1ZT7bMv2Rd4WO4ZwPkMrQEo2V5p42tNj_kOVv27-TJ84/edit?gid=0#gid=0
cc: @willtmakinen
