I’m using Putty
and i want to file transfer to my PC (window 7)
I want to run only the C language, without a separate program.
The file is 200kb bmp files.
Is there any way ??
BBB was installed Debian
I’m using Putty
Is there any way ??
e.g. winscp: https://winscp.net/
My solution to this problem was to mount an NFS share from another Linux machine, then this other Linux NFS server also has a Samba share. Perhaps overly complicated for the above mentioned situation. But it works great for working with a lot of source code. Especially since I can edit files live from a remote system, using whichever editor I prefer. e.g. the Samba share appears to a Windows machine as a local means of storage.
From Linux to Linux though, one can simply use sshfs. Which mounts a remote directory to a local mount point.
Use a flash drive or SD card.
SCP the file.
Thanks everyone
WinScp is very nice program !!
and SCP command is very good too.
2015년 10월 4일 일요일 오후 8시 18분 34초 UTC+9, 멘지 님의 말:
