How can I give higher priority to user-space signal which emits data by usig PySide Signal class over the interrupt which reads value from a sensor when edge is rising of beaglebone black(BBB) gpio. The sensor rate is set to 860, so in every second it reads 860 data, consequently changes the flow of the process 860 times, and when 860 data has been read from the sensor it takes average of that values and emits PySide Signal with data (we should not return values from interrupt handler function and they have to have really short execution time period, that is why I used Pyside’s Signal class to emit signal with data). This signal emitted is connected to printWeight() data in the server-side, and expected to execute when signal is emitted. But since interrupt is generated 860 times per second cpu usage is not given to server-side. How can I handle this issue? my server.py is as follows
from bottle import redirect,get,post,request,response,template,run,route,Bottle,static_file
from bottle.ext.websocket import GeventWebSocketServer
from bottle.ext.websocket import websocket
import time
import signal
from HardwareInterrupt import Hardware
from Signals import _Signal_DataArrived
import signal
hardware = None
def printWeight(data):
global hardware
print "data = ",data
#signal.signal(signal.SIGALRM,printWeight)
@route('/')
def websocket():
global hardware
hardware = Hardware()
hardware.setups()
#hardware.startReadingValue()
print "hardware..."
_Signal_DataArrived.run(printWeight)
run(host='0.0.0.0',port=8001,server=GeventWebSocketServer)
and HardwareInterrupt.py is like this
def setups(self):
#setting Gpio setups
Gpio.setup("P9_24", Gpio.IN,pull_up_down=Gpio.PUD_DOWN)
Gpio.add_event_detect("P9_24", Gpio.RISING)
self.setupI2cSettings()
Gpio.add_event_callback(_SensorValueDetectedPin,self.readValueFromSensor)
def readValueFromSensor(self,channel):
if (self.count == 860):
result=self.total/self.count
weight = result * self.sensorValueToGramConverter
weight = self.doCalibration(weight,self.prev_weight)#currentVal)#,previousVal)
self.prev_weight = weight
print '%.2f' % (weight)
self.count = 0
result = 0
self.total = 0
obj = {'weight':weight}
self._weight = weight
_Signal_DataArrived.emitIt(weight)
import time
time.sleep(0.1)
self.count = self.count + 1
MSB, LSB = self.i2c.readList(0x00, 2)
combined = (MSB << 8) | LSB # gelen verinin decimal hali
self.total +=combined
